Question about Uspeed WIFI Repeater Access Point 300/150/54 Mbit and Range Extend
My repeater does not find the wifi network - Uspeed WIFI Repeater Access Point 300/150/54 Mbit and Range Extend
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 72 Answers
It is possible that the repeater isn't in the range of the wifi. Watch out for the range of wifi router and then place the repeater in that range.
Posted on Aug 01, 2013
SOURCE:
How to do i find pin number for wireless n wifi repeater
here's the manual: http://sgcdn.startech.com/005329/media/sets/WFREPEAT300N_Manual/WFREPEAT300N.pdf
Mar 11, 2015 | Generic Wireless-N Wifi Repeater IEEE...
How do I CONFIGURE WI FI REPEATER
You'll need to configure your wifi adapter to the same network range as the repeater.
192.168.10.2 will work.
Jan 20, 2015 | Generic Wireless-N Wifi Repeater IEEE...
How extend in built wifi
You can purchase a wifi repeater fairly inexpensively now if you are trying to extend the WIFI range of your existing network. They are pretty easy to setup. They mirror your existing network and you then place them on the outer most area that your network is able to reach. It then extends your primary network further out in that direction. You can add multiple WIFI extenders to a network to cover large areas like a motel or apartment complex.
Sep 24, 2014 | HP Computers & Internet
How to connect two wifi routers using modem....In home on one network???
while two WiFi connections can work, if youdo it that way you will need to disconnect from one and reconnect to other everytime you move from one extreme to the other. also you only extend your range by the distance from one to the other.
what you need (for a weak signal) is a repeater. it is a box designed to listen on one WiFi channel and repeat it on another. bin turn it also listens on the repeated channel for communication from your remote device and repeats it onto the original channel so it is as if the new channel is the original channel... place this repeater at half strength distance (power source will be needed but wires to base computer not needed) and you have extended your range by about half the distance...
to go further out just add another repeater (or more)
I googled "WiFi repeater" and was presented with a wide range of options (see photo for partial screenie)... generally the more expensive the further or wider the range... without even looking further i would suspect that the more expensive ones likely could even cover more range than two of that modem you showed combined
a few shown might be the kind with two units that you plug one near base computer and plug other farthest away from base... they not only use house wiring to power the units but also use the electric wire as an antenna for comunicating as if there were an ethernet connection between them.
fd91a783-bc64-463b-8de7-62ed56adbb31.pngMy
Jul 02, 2014 | Computers & Internet
Netgear extender not connecting
There's quite a bit to know about using WIFI network extenders / repeaters. Have a look here;
Simple Wireless WIFI range extender expander repeater
Apr 07, 2014 | NetGear Computers & Internet
Dap 1360
1- first distance between Dap-1360 from the router wifi Nilox should be max the signal length around 50 meter,
2- try to update the Dap-1360 software from the internet then test the network cable again and the electric cable..
hope it help ...
Mar 19, 2014 | Computers & Internet
Excellent signal low speed transfer
You can boost the signal range of a WiFi computer network in several ways: Answer:
  • reposition your router (or access point) to avoid obstructions and radio interference. Both reduce the range of WiFi network equipment. Common sources of interference in residences include brick or plaster walls, microwave ovens, and cordless phones. Additionally, consider changing the WiFi channel number on your equipment to avoid interference.
  • upgrade the antenna on your router (or access point). WiFi antennas on most wireless base stations can be removed and replaced with more powerful ones.
  • add another access point (or router). Large residences typically require no more than two APs, whereas businesses may employ dozens of APs. In a home, this option requires connecting your primary wireless router (access point) to the second one with Ethernet cable; home wireless routers and/or APs don't normally communicate with each other directly.
  • add a bi-directional WiFi signal amplifier to wireless devices as needed. A WiFi signal amplifier (sometimes called "signal booster") attaches to a router, access point or Wi-Fi client at the place where the antenna connects. Bi-directional antennas amplify the wireless signal in both transmit and receive directions. These should be used as WiFi transmissions are two-way radio communications.
  • add a WiFi repeater. A wireless repeater is a stand-alone unit positioned within range of a wireless router (access point). Repeaters (sometimes called "range expanders") serve as a two-way relay station for WiFi signals. Clients too far away from the original router / AP can instead associate with the WLAN through the repeater.
Nov 19, 2009 | Sony Computers & Internet
Uspeed WIFI Repeater Access Point 300/150/54 Mbit and Range Extend Logo
167 people viewed this question
Top Uspeed Computers & Internet Experts
Alun Cox
Are you an Uspeed Computer and Internet Expert? Answer questions, earn points and help others
