Question about Sony CMT-BX20i Shelf System
Reset factory settings - Sony CMT-BX20i Shelf System
Kobo frozen. Willl not respond to touching button
Performing a basic reset A basic reset will force your eReader to restart properly. In many cases, this is enough to restore your eReader to normal.
  1. If possible, turn off your eReader.
  2. Locate the small hole on the bottom of your eReader.
  3. Unfold a paperclip and slide an end into the hole.
  4. Press gently until you feel a click. Your eReader should restart.
Performing a factory reset If a basic reset doesn't work, you can perform a factory reset to restore your eReader to its original settings. After a factory reset, you'll have to set up and sync your eReader again.
If you perform a factory reset on your eReader, you'll:
  • Remove all books from your eReader. Any books you purchased from Kobo can be re-downloaded from the Kobo Cloud after a factory reset.
  • Lose any bookmarks and annotations you made in your books since you last synced your eReader.
  • Sign out of your account on your eReader.
  • Reset all of your settings and preferences.
  • Return your eReader to its original settings.
  1. If possible, back up any books or documents that you added to your eReader using Adobe Digital Editions, or that you manually added using your computer. You do not need to back up any books you bought from Kobo. Any books you purchased from Kobo can be re-downloaded from the Kobo Cloud after a factory reset.
  2. Go to your Home screen.
  3. Tap the ios-menu.svg Menu icon at the top of the screen.
    The Quick Settings panel will appear.
  4. Tap Settings.
  5. Tap Device information.
  6. Tap Factory Reset under Advanced.
  7. Performing a factory reset If a basic reset doesn't work, you can perform a factory reset to restore your eReader to its original settings. After a factory reset, you'll have to set up and sync your eReader again.
    4. Tap Settings.
kobo com help Resetting your Kobo Glo HD
Jun 30, 2016 | Kobo eReader
How to delete previous owner WiFi data and security code
Resetting the Printer to Factory Default
Settings
Resetting the printer to factory default settings can be useful when
you are troubleshooting with the printer.
CAUTION Resetting factory defaults clears the page buffer, removes downloaded
fonts and macros, and returns all print menu settings to factory defaults.
To reset the printer to factory default settings
1 Press MENU until RESETS MENU displays.
2 Press ITEM until RESTORE FACTORY SETTINGS displays.
3 Press SELECT until the following message appears:
RESTORING
FACTORY SETTINGS
This message displays until the printer has completed the
initialization
Mar 26, 2015 | HP LaserJet 4500 Printer
How to delete former owners wireless data on HP 4500 - G510n wireless printer.
Settings
RESTORING
FACTORY SETTINGS
initialization
Mar 26, 2015 | HP Office Jet 4500 G510n
How do i reset my digital2
To factory reset your tablet - Open system "Settings", then "Backup & Reset", then "Factory data reset". Once reset, all settings will be restored to factory default settings and user will be required to do the initial setting.
Oct 19, 2014 | Digital2 7 inch Tablet with 4GB Memory
Netflix com
Performing a factory reset erases all of your settings and account information and restores your
1 Press home to go to the Home screen. 2 Highlight settings , and then press select to display the Settings screen.
3 Highlight factory reset, and then press select .
4 To continue with the reset, select factory reset. To cancel the reset, select back.
  • 5 When prompted, highlight yes to confirm that you want to reset your player, and then press
    select
Aug 21, 2014 | Roku Televison & Video
Mfc7340 where is factory reset
Restoring all settings to the factory settings, you can restore all the settings you have changed to the factory settings. These settings will stay until you change them again.1 Press Print Setting.2 Press a or b to display Factory Reset.3 Press Factory Reset. 4Press Yes to confirm.5 Press Stop/Exit.
Jun 10, 2014 | Office Equipment & Supplies
Reset factory settings on hp deskjet 1050
Reset the Printer to Factory Default Settings Restore factory settings Restoring the factory-set defaults returns most of the settings to the factory defaults. It will not reset the page count, tray size, or language. To restore the product to the factory-default settings, follow these steps.
  1. Turn the product off. Disconnect the power cable from the product for 30 seconds and then reconnect.
  2. Turn the product on while you press and hold the Resume c02469297.gif button for 10-20 seconds. The Attention c02469293.gif light turns on.
  3. Release the Resume c02469297.gif button. The Attention c02469293.gif and Ready c02469296.gif lights cycle while the product restores factory defaults.
Reset HP 1050 DeskJet Series Cartridge
Jun 07, 2012 | HP Office Equipment & Supplies
My vizio has input locked
Hello
Reset the device to its factory settings. To reset it to factory settings, enter "Setup", select 'Reset All Settings", press [=>] button to reset the TV to its factory settings. All parameters, except the parential lock will be reset to it original factory settings. If you for got the pass code, just enter its factory reset passcode [0000]; Eventhough the set will report this to be wrong passcode, input [0000] once again. This will unlock the passcode, and you have to set a new passcode. OK.
Sep 02, 2011 | Vizio VX20L 20 in. LCD TV
I forgot the lock code to my rumor touch and can still access the phone but cannot lock it because i forgot the code... what do i do?
hi dear.. please help me.. i forgot my NOKIA E63 restore factory settings lock code. please send the how to reset my lock code to manikanta.art@gmail.com
May 24, 2011 | LG Rumor Touch
Sony CMT-BX20i Shelf System Logo
43 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
