Question about Exercise & Fitness
My t6i treadmill speed up and down continuosly
    Top Expert:
  • 12,223 Answers
Please Run the software calibration for easy diagnostic and fix it.
Go under the HOOD cover motor, and follow the steps .
God bless you
Posted on Jul 31, 2013
2 Suggested Answers
SOURCE: No Power To Console
treadmill will not start
Posted on Mar 10, 2009
In program mode why can't I program shift on my t6i. I turn the main dial and nothing is there.
You need to be in the creative modes e.g. Av, Tv etc. Functionality in program mode is limited
Nov 03, 2016 | Canon EOS T6i DSLR Camera with EF-S...
T6i speed problem
pleaSE Run the software calibration for fix it. Go under the HOOD cover and see the steps for s.calibration.
God bless you
Jul 30, 2013 | Exercise & Fitness
I have a roger black treadmill the belt stops working after 5 - 6 minutes, the display still continues counting as normal, I have to wait for acouple of hours to start it again to last for 5 mins. please...
1) this a problem by lack of LUBE maintenance, you must LUBE about 5 hours continuosly of use. Otherwise you may have a worn DECK BELT, and time to replace. By that reason the treadmill shut down, to due the software has protection itself for electronic system
2) LUBE the rollers bearing.
3) test the bearing from the main motor, and replace too.
God bless you
Nov 14, 2012 | Exercise & Fitness
Incline reads 0.0 but is not all the way down
Renee, Here is how to recalibrate the incline motor. Read all of it It will be good to keep.
Plug in your treadmill, do not stand on the walking belt. Hold down the "Stop" and "Speed +" key and insert the safety key or magnet, let go of the two keys. Now press "Stop" key once. This puts you into the level 2 of calibration. Press the "Speed +" key slowly until you see 85 on the console, (at this point the display is going to show the percentage of motor usage and also the actual walking belt speed) at 85% motor usage your top speed should be between 10 and 10.5 MPH or (of 12 and 12.5) depending on the treadmill. You must know your treadmills top speed. (Important the motor may be damaged if you set the maximum speed higher than the maximum speed that your treadmill is made for). If the speed is higher than 10.5 or 12.5 then you need to turn the potentiometer down to the correct level. If the speed it to low you need to turn the potentiometer higher. Once the speed is correct you are done calibrating the speed. Press the (-) speed key to lower the percentage to (0). Next press the incline (+) button, this will make the incline motor go all the way to the maximum incline and come all the way down to the level position. Then remove the safety key and the treadmill will reset into the normal manual mode, when you re-insert the safety key. Matt
Dec 04, 2011 | Nordic Track NordicTrack Treadmill, A2550
Treadmill not working
Belt speed Loss:
This condition indicates that the speed pickup signal was lost continuosly by during 1 second after the motor successfuly started.Normally indicate a failure of speed pickup or abrupt belt stoppage to due any motor, wiring,or motor controller failure.
Oct 24, 2011 | York Barbell Home Use Fold-Up Treadmill
E2 warning light. tried reset no luck
This conditions indicates that speed pickup signal was lost continuosly for longer
more than 1 seg, after the motor successfully started.Indicate that failure in the
speed pickup or and abrupt belt stoppage,due to any motor, wiring, or motor controller failure.
http://www.fixya.com/support/r10786838-test_procedure_dc_motor
http://www.youtube.com/watch?v=bF3OyQ3HwfU&feature=related
http://www.youtube.com/watch?v=GPI6dFJCUA4
http://www.youtube.com/watch?v=-oeXTKqWECw&feature=related
Aug 17, 2011 | Proform 730 Folding Treadmill Model...
Will not move belt
Press the Stop and the Speed Up keys down while inserting the safety key.
Press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, or the like. This means that it passes the EPROM test.
Press either incline key and the incline will calibrate automatically.
BE CAREFUL, THE TREADMILL WILL RUN AT FULL SPEED IN THIS NEXT MODE! DO NOT STAND ON THE WALKING BELT. Press the Speed Up key and hold it down until 85 is shown in the Distance window (some models may show the 85 number in another window).
If the top speed of the treadmill does not match the displayed speed on the computer console, adjust the max speed potentiometer (pot) on the motor control board. This is the board that the red and black motor wires connect directly into in the motor area. The Max Speed pot is clearly labeled. The max speed potentiometer is a small square with a mobile center and is located in one corner of the board and is labeled MAX SPD. It is near the harness that carries the speed signal labeled H,W,L. Using a small insulated screwdriver adjust this potentiometer clockwise to speed up and counter-clockwise to slow down the max speed of the treadmill. A tiny turn of this potentiometer will make a big difference in speed so be careful when making adjustments. It is not important to get the speed set exactly at the max speed of the treadmill but do make sure to get the speed within .2 MPH of the max speed of the treadmill. For instance if the max speed of the treadmill is 10 MPH, make sure to have the speed set between 9.8 MPH and 10.2 MPH. Some models have a 12 MPH top speed, so please check your manual if you aren’t sure. THIS IS A VERY IMPORTANT STEP BECAUSE YOU WILL GET AN ERROR MESSAGE IF THIS STEP IS SKIPPED. After completing calibration of the speed, press the Speed Down key. The treadmill will automatically return to 0 MPH. Please allow the unit to stop completely before continuing. Press the Stop key once and remove the safety key.
May 27, 2010 | Proform 560hr Treadmill Walking Belt
Treadmill speed control does not work - only max.
visit www.iconfitness.com and enter your full model number to print out a speed calibration procedure. Sounds like it needs it. We are a service dealer for them.
Aug 10, 2009 | Proform Crosswalk 3.0 XT Treadmill
No Power To Console
Dec 16, 2008 | Endurance TF6iHRC Treadmill
Exercise & Fitness Logo
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
