Question about Dehumidifiers
I have a hunter dehumidifier and need to know where to get new filters
  • 1,013 Answers
Amazon.com is the best place to get filters for the Hunter. Try here:
http://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Daps&field-keywords=hunter%20dehumidifier%20filters
Posted on Jul 30, 2013
How do I change the filter on my dehumidifier lad704tdl
The filter on the Frigidaire LAD704TDL is behind the louvered section of the housing above the water bucket. Remove the water bucket by pressing the sides gently to release the bucket from the dehumidifier. Then pull the bucket towards you and use the handle to move it away. Then reach up and pull the filter down. You can wash the filter or replace it with a new one.
For pictures, see the manual: manuals.frigidaire.com/prodinfo_pdf/Edison/66166042enaen.pdf . The filter maintenance is shown on page 8.
I hope this helps.
Mar 09, 2015 | Dehumidifiers
Do I have a filter I need to change in my dehumidifier MHDW
i assume you have a humidifier and not a DEhumidifier? putting water in a dehumidifier defeats the purpose. it should remove the water from the air. don't fill the tank on the bottom. empty it. as for the filter, just use a vacuum across the front fins to remove the dust.
May 10, 2012 | Windchaser MDH-W Dehumidifier
Need to clean filter
Hazel, I assume you want to know how to find and remove the filter for cleaning.
The filter is located behind the front air intake louvers and depending on which model you have, the filter can be accessed one of two ways. Before you attempt to remove the filter turn the unit OFF and unplug it.
1. Remove the bucket from it's holder. Look up inside the bucket cavity, just inside the unit behind the louvers and you will see a tab type pull handle. This is the handle to the frame of the filter. Pull it down and out.
2. As you're facing the unit on the fight side just behind the louvers, there will appear to be a trap type door. Open this door and you will have access to pull the filter out.
You can clean the filter in one of two ways: Vacuum it or it it's really dirty, wash it in warm soapy (dish washing liquid), rinse and dry thoroughly. NEVER operate the dehumidifier without the filter in place. Doing so, can cause damage to the unit.
Hope this helped you. Please let me know.
Jul 05, 2011 | Haier Dehumidifiers
Quit running and displays E2 in the F/C window.
E2 error indicates that the air intake filter needs to be removed and cleaned. Turn the Master ON/OFF Switch to OFF and unplug the unit, before removing the filter. If you wash the filter, it must be completely dry, before reinstalling it. DO NOT run the dehumidifier without the clean filter installed.
Hope this helped you to solve the problem. Please let me know. Thanks.
Jun 19, 2011 | Haier 45-Pint Dehumidifier
Dehumidifier runs for approx. 15 min works fine then shuts off and doesn't come back on.
run it without the filter with a 1 part vinegar 4 parts water. then try it with a clean or new filter. You may need to run it a few (5-6) times before it stops shutting off by its self.
Aug 22, 2010 | Kenmore 54351 Dehumidifier
I need to know how to clean filter. Lost book
follow the below instructions:
Turn off the dehumidifier machine and unplug it from the wall.
Lift the water bucket up and out of the dehumidifier.
Locate the filter located under the compartment that houses the water bucket. Lift the filter straight up and out of the dehumidifier.
Vacuum as much of the visible dirt and debris as possible.
Fill a sink half full with water. Place the filter in the water and allow it to soak for one to two minutes.
Wipe both sides of the filter with a wet sponge to remove any remaining dirt and debris. Rinse the filter with clean water.
Wipe the filter with a dry cloth to remove excess moisture. Allow it to air dry for approximately 30 minutes before inserting it back into the dehumidifier.
Good luck.
Aug 11, 2010 | Frigidaire Dehumidifiers
Our LG LHD45EL dehumidifier stopped working. The bucket full light flashes, though the bucket is empty and the filters clean. The display shows CH01. The manual does not say what CH01 means. Any...
I don't know what CHO1 is either! My husband and I had the same problem a couple years ago. We just ended up buying a new one.
http://www.donmurraysbobcatandtipperhire.com.au
Jul 22, 2010 | LG LHD45EL Dehumidifier
Do i just clean the air filter or buy a new one?
clean it - pull out the bucket, look under the front panel lower lip, remove any tape, and pull down the slide-in filter (it fits behind front grill) - just vaccuum and/or rinse and put back in - the tape was just for shipping.
Nov 17, 2009 | Maytag M7DH65B2A Dehumidifier
Hi Fixya: The Filter on my Danby DDR7009REE Room dehumidifier never seems to accumulate any dust. It is supposed to need to be cleaned every two weeks by vacuuming or soaking, but the filter is always...
How often does the unit run? Does the fan run when the unit is suppose to be running(as the fan pulls the air thru the filter). If every thing operates correctly and the filter is in the right location on the unit then all I can say is that you keep a clean house. Personally I only need to clean the air filter on my dehumidifier about once a summer. I wouldn't be overly concerned if it isn't getting very dirty.
Nov 10, 2009 | Dehumidifiers
Dehumidifiers Logo
48 people viewed this question
Top Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Dehumidifier Expert? Answer questions, earn points and help others
