Question about Pride Health & Beauty
I have a flat tire on my scooter which i would like to fix but unable to get the rim apart can you help me
    Habit-Forming:
    New Friend:
  • 88 Answers
Yes. Be careful! Only remove the wheel's central nut, NOT the outer ring of nuts yet. Remove the tyre valve slowly and with care to empty the inner tube. Remove the wheel by tapping the rear of the wheel as necessary - be careful to remove the axle key and keep it safely to one side. Remove the remaining wheel nuts split the wheel and remove the tube from the tyre and wheel. Check the wheel inner surfaces for rough spots and clean. Insert the new tube and making sure that nothing is pinched reassemble the wheel inflate the tyre to the recommended pressure in stages gently bounce the wheel once or twice to help the tyre to seat properly. Inflate to just above the recommended pressure and release surplus air. Offer the wheel up to the axle with the wheel and axle key slots exactly opposite each other. Insert the "key" in the slot and gently hammer it home.
Voila, you have done it!
Posted on Aug 02, 2016
2 Suggested Answers
  • 456 Answers
SOURCE: Having problems w/ panther lx
hi.
two piece rims are often VERY tight, and it can seem that they are too big for the tyres.
i tend to use a lot of washing up liquid to put these back together. it can be messy, but it makes the tyres slip on easier, and will not damage the rubber.
if you are not sure, or still cannot get the tyres on, try visiting your local bike shop. they should be able to help you out
good luck.
Posted on Jun 29, 2011
How to fix a tire on a gas scooter
what is wrong with tire --is it flat -off rim -if solid tire damaged /cracked --if flat and tube will need to break down tire to either replace tube or patch it --if tubeless either plug it or depending what caused flat replace tire --if solid tire notify manufacturer for replacement or ask for local parts distributor and their is always the internet sites --for parts
Aug 29, 2016 | Health & Beauty
How do I put air in the tires?
It is possible that your scooter may have solid tires which means no air is required. You should be able to see a hole in the wheel rim where, if air tires were fitted, the valve would come out. No Valve=No Air. The rims are of the split type which you have to take the bolts out in the middle of the wheel to split the wheel to change the tires.
Jun 11, 2014 | Pride Mobility Products Maxima 3 Wheel...
How do you get the rubber tire off the rim?
Get the rim / tire of the frame. Let all the air out of the tube, Using two flat blade screw drivers, put them between the rim and tire about 3 inches apart, (be careful not to puncture the tube) Pry the tire over the rim, leave one in place and move the other about 3 more inches and pry the tire over the rim again, keep moving around the rim until the side is off. Reach in and pull the tube out, fish the stem through the hole. Finish pulling the tire off the rim, you can use liquid soap to help make things easy. Put the rim back together the same way. Hope this helps Fix Ya up.
Jun 18, 2011 | Mongoose Cycling
Please help the air valve on my tire broke off and the tire is flat. i can't get the tire off
Granny you will have to get someone with a tie rod tool to try to pry the tire off the axle for ya the rims are probably rusted to the axles and need some persuasion to get off now if they are rusted pretty badly they might never come off and other means will have to be used to fix your scooter like replacing the whole motor/transaxle assembly If the scooter is old it might be time to get another one Hope this helps
Apr 15, 2011 | Health & Beauty
My scooter is making loud clicking sounds as though something has come loose & hitting something in the rear wheels as it goes around. The repair tech rotated the rear tires last week & this helped...
Its quite common for Pride scooters to be assembled using little or no grease on the rear axle. If the noise is like a stone stuck in the tyre, its probably a 'Dry Axle' as mentioned above. Try just removing the rear wheel(s) and greasing the axle. This normally cures the problem. When removing the wheel, be careful not to lose the hub key which slots into the axle and wheel to stop the wheel spinning freely on the axle. Hope this helps.
Jun 29, 2010 | Pride Go Go Elite Traveller Plus HD 4...
Back wheels make a loud clicking noise
Hi. Loud clicking noises from the rear wheels are usually caused by movement of the square steel key that fits into a groove on the axle inside the wheel hub. This is what drives the wheels.
You will probably get a click for each revolution of the wheels.
To fix it, remove the rear wheels and wipe a thin smear of grease on the key and axle, then replace the wheels.
The grease will allow the key to move slightly without making a noise, and help stop it from wearing.
It sometimes helps to also remove the front wheels, and wipe a thin smear of grease onto the front stub axles. There is no key in the front hubs, but the grease helps to prevent the bearings siezing on to the axles.
Good luck. Neil.
Jun 24, 2010 | Pride New Mobility Legend 4 Wheel Scooter
Have a flat tire on a Chauffeur Scooter rear wheel.
I just removed the right rear wheel from my Chaffeur scooter. I first removed seat, plastic cover and batteries. Then removed wheel center bolt, set scooter on it\'s side and used a short 2x4 and rubber mallet to drive the wheel off. A shot of penetration oil helped. It is an extremely tight fit.Can\'t figure the two piece rim out though. Anyone have suggestions on why it is a two piece and how to remove tire from rim?
Apr 28, 2010 | Health & Beauty
How to fix flat tire.
Hi:
I have a rascal 3 wheel chair and the tire is flat on back, how do they come apart for repair, thanks.
Leroy
Mar 28, 2010 | Razor E100 Electric Scooters Red
Clicking, first noticed on carpeted surfaces. Sounds like it is coming from rear end. Scooter has been used outdoors mostly over some rough terrain. No leaks visable. Was recently purchased used from a...
Clicking from the tires is usally due to one of two things. First, check to see that the nuts holding the wheel onto the axle are tight by removing the plastic cover and tightening them as hard as you can. Drive and see if it quit clicking. If not, check the air in the tires; they should be kept at the stated range on the tire. If they are foam-filled, flat-free tires, these can often click when the tire chages against the wheel. It doesn't affect the safety of the scooter but can be annoying. Spraying some WD-40 around the rims inside and out will often clear it up. If not, you'll need to pull the tire and tighten the 4 bolts that hold the split-rims together.
Oct 07, 2009 | Invacare Supply Group Health & Beauty
Click and clunk when moving from right rear wheel Pride Elite +
This can be caused by two things usually. One cause is the bolt holding wheel to the axle is a little loose so check to make sure it is very tight on the axle. The second click comes from flat-free tires. The tires have an adhesive applied at the factory and if you hit a bump, or if there's not enough to hold the tire tight to the rim, the tire will make a grinding click noise when it rolls and passes over this area. Pneumatic tires properly inflated don't make this noise since the air pressure keeps the tire fixed to the rim at the bead; flat free tires lack this pressure. Simply lubricate the area around the tire where it meets the rim on inside and outside, and drive it...noise should dissipate.
Aug 28, 2009 | Pride Go-Go Ultra X 3-Wheel Travel Scooter
Health & Beauty Logo
73 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
