Question about Sony TA-E9000ES Amplifier
No sound or picture
Hi i bought ta-e9000e from goodwill with no sound or picture . i just wondering if any one has an idea what is the fault.and i also try to download a software on it but ido not have the software version or a link to it my software is 1.1A . THANK YOU IN ADVANCE.
    Champion:
  • 287 Answers
I always look for back stk Ic's in these. not the outputs but in the output driver stage. copare voltages with the other stk's . Does one of them have higher voltages? Like instead of 1.3 volts it has 4 or 5volts? if so it's bad. you can find these Ic's on ebay , I did. also upc2581 driver ic's can do this. Larry
Posted on Sep 18, 2007
Where can i get a display panel for a sony ta-ve110
Go to www.sony.com contact customer support and the technical department to see if they can help, also try www.ebay.com type make and model and go through the list if available.
Sep 24, 2012 | Sony TA-E9000ES Amplifier
Popping sounds when changing volume
The cracking and humming sound is because of the improper earthing
Sep 10, 2008 | Sony TA-E9000ES Amplifier
We look for remote control use fro TA-E9000ES
Try the Sony consumer website or a place call mrremote (dot) com
Nov 30, 2010 | Sony TA-E9000ES Amplifier
Sony TA-E9000es. No Display, No Sound. Software Ver 1.18. Has Bulletin HIFI1-99-028R1 performed. (Add capacitor, replace resistor)
also replace Q108 @ Q109 on power board. If that does not fix it then also replace PH101 & PH102. Also on Power board.
Jan 14, 2010 | Sony TA-E9000ES Amplifier
I have 2 questions will my SONY TA-E9000ES preamp work with my SONY STR-DG720 7.1 RECIVER and what SONY ES Amplifer was spefically made to work with the TA-E9000ES WHEN IT WAS ORIGANLY PRODUCED
Here's a page for the 1st one
http://home.online.no/~espen-b/ta-e9000es/
It will work with your 7.1 receiver. Just use one of the inputs on the 7.1 to connect to the Pre-amp
PLease rate my help if this helps
Thanks
Nov 04, 2009 | Sony TA-E9000ES Amplifier
No sound to speakers but it does power up
try to connect all your cables again but step by step and make sure you connect it in the right way and correct location of every cable.
Oct 05, 2009 | Sony TA-E9000ES Amplifier
Sony e9000es preamp. no LCD light
Hi John. It can be fixed, and most probably relates to the power supply. There is a Sony repair doc that lists low or no display, but also associated with no audio.
Here is the information regarding the problem.
The power supply is the main culprit for most of the TA-E9000ES failures. Symptoms of this are no sound and a very dim or no display. Apparently the power board has several weaknesses which have caused Sony to supply a modified version in later production units.The circuit around transistors Q108 and Q109 are prone to oscillation, which will cause one or both transistors to break down, as well as resistor R124. This resistor is originally a surface mounted device capable of 1/10 watts of heat dissipation. The modification suggested by Sony is to replace this 4.7 k ohm resistor with a 1 watt rated version. Also, to prevent further oscillations a 100 pF capacitor is added in parallel with R153.
(Some suggests that also transistor Q110 is a candidate for replacement.)
The US issued service bulletin from Sony suggest that this fault may occur with units having a serial number in the range 800001 - 802746.
If you still have sound, then there may well be a problem elsewhere. It is a great Preamp, and I recommend you get it fixed. A Sony Authorised service center would be the best place to take it. They supply good inside information about this most problems that occur on their gear. There is good info on your preamp controller here
Feb 02, 2009 | Sony TA-E9000ES Amplifier
Power on but no led display
"Power board:
The power supply is the main culprit for most of the TA-E9000ES failures. Symptoms of this are no sound and a very dim or no display. Apparently the power board has several weaknesses which have caused Sony to supply a modified version in later production units. The circuit around transistors Q108 and Q109 are prone to oscillation, which will cause one or both transistors to break down, as well as resistor R124. This resistor is originally a surface mounted device capable of 1/10 watts of heat dissipation. The modification suggested by Sony is to replace this 4.7 k ohm resistor with a 1 watt rated version. Also, to prevent further oscillations a 100 pF capacitor is added in parallell with R153. (Some suggests that also transistor Q110 is a candidate for replacement.) The US issued service bulletin from Sony suggest that this fault may occur with units having a serial number in the range 800001 - 802746.
Serial numbers 80#### are for the US/Canadian version.
Serial numbers 50#### are for the european version."
http://home.online.no/~espen-b/ta-e9000es/#faults
Aug 26, 2008 | Sony TA-E9000ES Amplifier
Zone B of Sony amplifer seems to have stopped sending most of signal
Hi, please have a look at your supply. The voltage might have gone below 21V on your newer models and 42V on your older models. This you will find near the pre-amp. Look for 2 big Cap's and start from there.
May 27, 2008 | Sony TA-E9000ES Amplifier
TA-N9000ES Amp - Standby light constantly blinks - no sound
The flashing light is indicating that a fault has been detected, and it is staying in "protect mode". First disconnect all cables from the processor (except the power cord) and then power up the processor. This will eliminate the possibility of a shorted cable or a problem with any connected components. f the light still flashes, there is an internal problem and the processor will require profesional service.
Oct 09, 2007 | Sony TA-E9000ES Amplifier
Sony TA-E9000ES Amplifier Logo
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
