Question about Cycling
Shimano c201 left shifter
I am looking for the cover & screw for the left shifter shimano c201
  • 18 Answers
SOURCE: Shimano st 7900 shifter,left lever apart and how to reassemble
You can download an exploded diagram of the 7900 series STI shifters here:
http://techdocs.shimano.com/media/techdocs/content/cycle/EV/bikecomponents/ST/EV-ST-7900-2874E_v1_m56577569830670749.pdf
You can reassemble them according to this diagram.
Posted on Jul 07, 2009
  • 5 Answers
SOURCE: My left shifter (Shimano 105) is
Front changers are crude little things and do not sound like their cousins at the back. However, if the changer is successfully moving the chain from one 'ring to the next, the "pop" may be from the cable adjusted a hair tight. Shift onto the big 'ring, find the adjuster barrel in the cable run, and back the tension down 1/4 turn. Did the front changer move toward the bike? No? Now your pop should be milder. You might be able to take out another 1/4, but if the changer moves in when you do, you might be messing up the shifting, too.
There's some voodoo involved in front changers, still - bike mechanics have it and mechanically-inclined folks can get it.
Posted on Dec 05, 2009
SOURCE: shimano lx m569 shifter assembly diagrams
http://techdocs.shimano.com/techdocs/index.jsp
try here
Posted on Feb 18, 2010
johnegan84
  • 73 Answers
SOURCE: require assembly schematic for shimano dura ace
log onto Shimano.com, it is probably the limit screws (the two screws that limit travel) or you have a faulty ratchet in the lever, try the shimano website anyway they have great tutorial and manual support
Posted on Mar 27, 2010
Coachphil
  • 347 Answers
SOURCE: With Shimano 6603 Group can you use Shimano 5703
The answer is yes and no.
The 5703 shifters will work both derailleurs and match the 6603 group as they are both 10spd.
The Tiagra will not work because it is 9spd, it will functionally shift the derailluer but you will not be able to line up the gearing.
The rear shifter needs to match the number of gears on the back (cassette) in the case of the 6603 group that is 10spd, so you can use any 10spd rear shifter from shimano. The Tiagra is either an 8spd or 9spd depending on the model and will not work with the cassette. You can use a 6603 rear derailleur with a Tiagra group, as long as the shifter and cassette are both the same.
Posted on Dec 14, 2010
Exploded view of parts diagram for shimano tourney st-ef40 shifters for re-assembly?
If you can't find with a search for st-ef40 diagram or on the Shimano site then it does not exist. Although not identical carefully disassembling the other shifter may give you enough insight.
Apr 08, 2015 | Shimano Tourney ST-EF40 3x7 Speed Brake...
I need to see how to put a Schwinn 21 speed left hand shifter back together.
Schwinn doesn't make the shifter. Maybe Shimano? Determine the model and look it up at
http://techdocs.shimano.com/techdocs/index.jsp or the applicable manufacturer's website.
Jun 05, 2011 | Cycling
"shimano c201 crankset" Are
If your talking about this crankset http://www.bikepedia.com/pa/Item.aspx?itemid=516990 Then: Yes it is a bonded chainring set-up. YOU CAN NOT REMOVE THE CHAINRINGS.
Shimano generally only provides exploded views of parts that can be disassembled. Since this is essentially a one piece unit, there is no exploded view. The link has the relevant tech specs.
Dec 05, 2010 | Cycling
Require assembly schematic for shimano dura ace shifter . left shifter lever failed, will not activate the front derailler, disassembled, found nothing broken, require advice regarding proper reassembly...
Nov 14, 2009 | Shimano Dura Ace Front Derailleur Fd 7800
Install Shimano revoshift. bike came with shift cable not attached. how do I attach it? thanks, barry lentz
Front or rear? Is the cable not in the shifter?
If the cable is not in the shifter, there will be a screw in the shifter (made of plastic, usually black) facing outward. You open this and shift the shifter into the highest gear, then slip the cable through and out the side that accepts the cable sleeve. Then you run it through the sleeve and to its appropriate derailleur (left hand=front, right hand=rear).
Sep 12, 2009 | Mountain Shimano Revoshift Bicycle...
May 11, 2009 | Shimano 2008 Dura-Ace BR7800 Rear Road...
Cycling Logo
44 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
