Question about MSI 945GCM7L (945GCM7F) Motherboard
My msi1996 7507 could not display anything in monitor
Not displaying anything
Sounds like the monitor is dead. Replace it.
Mar 25, 2014 | AOC Monitor
The monitor works ok, but I have to switch it on and off to display anything on the screen. I have changed the graphics card but to no avail. The display info is getting to the monitor but doesn't
Check your cable between the computer and the monitor, It may be a non-sensing cable which will be missing one of the pins so the monitor is not getting the correct data from the computer.
Mar 06, 2012 | ASUS P5VD2-MX SE Motherboard
My newer flat screen monitor went black but works fine when hooked up to another computer and I have an older monitor that I hooked up and the older one works fine...??
That sounds like a display/resolution setting problem on your PC. I doubt there is anything actually wrong with the PC or the monitor, since both work with different combinations, so its most likely just a setting.
Some monitors don't display anything when they get a signal/resolution that is not compatible with their displays. I would try changing the display settings on your computer with your old monitor, then switch monitors and see if your newer monitor works.
Here's how to adjust the display resolution:
If in XP, right-click on the desktop and go to Properties, and select the tab for display settings and adjust/lower the resolution. If in Vista/Win7 right-click the desktop and select Screen Resolution/Display Settings and adjust it there.
Feb 15, 2010 | Rosewill R900J 19" Flat Panel LCD Monitor
Monitor has quit displaying anything. I hooked up
you can go to any local computer store for reoair but i would suggest you to replace the monitor.
Oct 27, 2009 | HP Compaq WF1907 Monitor
24" CRT HP A7217A Monitor stopped working
hello sir your vertical or horizal IC damaged.......... thats why its showing multi colour ...... just do one thing sir.......... fit your new IC
if your problem not solved..... type in comment
Apr 29, 2009 | HP A7217A (White) 24" CRT Monitor
No driver
Monitors do not need drivers, the drivers are used on the video display adapter.
If monitor does not display full definition, then it is the display adapter driver.
If the monitor does not display anything, then the monitor is faulty or the cable is not well connected or faulty.
Provide video adapter model to get drivers for your video adapter.
Apr 01, 2009 | Computers & Internet
My samsung monitor syncmaster 743nx is not turning on..plss help me...tnx
How to troubleshoot a Samsung SyncMaster 743NX LCD Monitor? My Samsung SyncMaster 743NX monitor turns on slowly. I mean,last week when I started up my pc,it took 5-10 mins before my monitor displayed anything. I know the pc is already turned on because I've already heard the Windows Vista start up tune play. The problem is now getting worse as it now takes 20-30 mins before my monitor displays anything. Please help.
Mar 11, 2009 | Computers & Internet
Monitor no display
try lowering the display resolution 1024 x 768 usually is a good start
May 11, 2008 | Smart Modular SV3170A
RECTIFYING MONITOR PROBLEM
sir,
i am having the problem of displaying the like following given in my monitor always and i cant see the anything displaying on the center .i dont know,how to rectify it.please give solutions to rectifying that.
Nov 21, 2007 | Samsung SyncMaster 720N Monitor
MSI 945GCM7L (945GCM7F) Motherboard Logo
12 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
