Does azo standard contain nsaids and is so what type
What can iuse for blader spasm
You can try AZO, its otc. But much better to see your Doctor.
Apr 20, 2017 | Health & Beauty
Tip
Super Duplex Valve Manufacturers
Super Duplex Valves are used to provide a leak free connection between tubes and fittings for a seamless flow of liquids and gases. Internally it consists of several parts depending on the type and application of the Super Duplex Valves Manufacturers. Externally the nuts are crimped to the body with the use of ferrules. The ferrules are swaged to the tube. This is the reason of seamless leak free connection between the fitting and the tube. The buying experience using intelligent technology modules is available at our work station.
Super duplex stainless steels are mainly developed to be used in extreme-stress environments. The properties of this alloy are very high which include, toughness, strength, corrosion resistance to a decent number of organic and inorganic acids. Super duplex steels are similar to the standard duplex types, but they contain a higher content of chromium which enhances the mechanical properties as well as its corrosion resistance. Normally a super duplex stainless steel contains 25% of chromium, 4% of molybdenum and 7% of nickel. It is particularly suited for warm-water chlorinated environments and acidic, chloric containing systems. Super duplex types always show good fatigue strength and that's why they are always much preferred over standard duplex ones. Om Tubes being Super Duplex Valve Manufacturers provides you with the best quality & services.
on Jul 12, 2016 | Miscellaneous
Tip
Super Duplex Tubes Manufacturers
Super Duplex Tube are mainly developed to be used in extreme stress environments. The properties of this alloy are very high which include, toughness, strength, corrosion resistance to a decent number of organic and inorganic acids. Super Duplex Tube are similar to the standard duplex types, but they contain a higher content of chromium which enhances the mechanical properties as well as its corrosion resistance. Normally a Super Duplex Tube contains 25% of chromium, 4% of molybdenum and 7% of nickel. It is particularly suited for warm-water chlorinated environments and acidic, chloric containing systems. Super Duplex types always show good fatigue strength and that's why they are always much preferred over standard duplex ones.
A Super Duplex Tube is a long, thin container made of soft metal or plastic that is closed at one end and has a small hole at the other, usually with a cover, used for storing thick liquids. It looks like a long narrow plastic or metal container with a lid at one end that you squeeze in order to push out the soft substance inside. Om Tubes being Super Duplex Tubes Manufacturers provides you with best quality & services.
on Jul 11, 2016 | Miscellaneous
What is meloxicam prescribed to treat?
Meloxicam is a nonsteroidal anti-inflammatory **** (NSAID) that is used to treat pain or inflammation caused by rheumatoid arthritis and osteoarthritis. I hope this helps!
Dec 29, 2016 | Dogs
What oil do I use on a 08 buick lucerne cxl
OIL TYPE
1.GM6094M Your vehicle's engine requires oil meeting GM Standard GM6094M.
2.SAE 5W-30 is best for your vehicle. These numbers on an oil container show its viscosity, or thickness. Do not use other viscosity oils such as SAE 20W-50. Oils meeting these requirements should also have the starburst symbol on the container. This symbol indicates that the oil has been certified by the American Petroleum Institute (API). You should look for this information on the oil container, and use only those oils that are identified as meeting GM Standard GM6094M and have the starburst symbol on the front of the oil container.
NOTICE: Use only engine oil identified as meeting GM Standard GM6094M and showing the American Petroleum Institute Certified For Gasoline Engines starburst symbol. Failure to use the recommended oil can result in engine damage not covered by your warranty.
GM Goodwrench oil meets all the requirements for your vehicle.
If you are in an area of extreme cold, where the temperature falls below -20°F (-29°C), it is recommended that you use either an SAE 5W-30 synthetic oil or an SAE 0W-30 oil. Both will provide easier cold starting and better protection for your engine at extremely low temperatures.
ENGINE OIL ADDITIVES
Do not add anything to your oil. The recommended oils with the starburst symbol that meet GM Standard GM6094M are all you will need for good performance and engine protection.
Jul 03, 2015 | Buick Cars & Trucks
Tip
What is the Registry?
The Registry is a database used to store settings and options for the 32 bit versions of Microsoft Windows including Windows 95, 98, ME and NT/2000. It contains information and settings for all the hardware, software, users, and preferences of the PC. Whenever a user makes changes to a Control Panel settings, or File Associations, System Policies, or installed software, the changes are reflected and stored in the Registry.
The physical files that make up the registry are stored differently depending on your version of Windows; under Windows 95 & 98 it is contained in two hidden files in your Windows directory, called USER.DAT and SYSTEM.DAT, for Windows Me there is an additional CLASSES.DAT file, while under Windows NT/2000 the files are contained seperately in the %SystemRoot%\System32\Config directory. You can not edit these files directly, you must use a tool commonly known as a "Registry Editor" to make any changes (using registry editors will be discussed later in the article).
The Structure of The Registry
The Registry has a hierarchal structure, although it looks complicated the structure is similar to the directory structure on your hard disk, with Regedit being similar to Windows Explorer.
Each main branch (denoted by a folder icon in the Registry Editor, see left) is called a Hive, and Hives contains Keys. Each key can contain other keys (sometimes referred to as sub-keys), as well as Values. The values contain the actual information stored in the Registry. There are three types of values; String, Binary, and DWORD - the use of these depends upon the context.
There are six main branches, each containing a specific portion of the information stored in the Registry. They are as follows:
* HKEY_CLASSES_ROOT - This branch contains all of your file association mappings to support the drag-and-drop feature, OLE information, Windows shortcuts, and core aspects of the Windows user interface.
* HKEY_CURRENT_USER - This branch links to the section of HKEY_USERS appropriate for the user currently logged onto the PC and contains information such as logon names, desktop settings, and Start menu settings.
* HKEY_LOCAL_MACHINE - This branch contains computer specific information about the type of hardware, software, and other preferences on a given PC, this information is used for all users who log onto this computer.
* HKEY_USERS - This branch contains individual preferences for each user of the computer, each user is represented by a SID sub-key located under the main branch.
* HKEY_CURRENT_CONFIG - This branch links to the section of HKEY_LOCAL_MACHINE appropriate for the current hardware configuration.
* HKEY_DYN_DATA - This branch points to the part of HKEY_LOCAL_MACHINE, for use with the Plug-&-Play features of Windows, this section is dymanic and will change as devices are added and removed from the system.
Each registry value is stored as one of five main data types:
* REG_BINARY - This type stores the value as raw binary data. Most hardware component information is stored as binary data, and can be displayed in an editor in hexadecimal format.
* REG_DWORD - This type represents the data by a four byte number and is commonly used for boolean values, such as "0" is disabled and "1" is enabled. Additionally many parameters for device driver and services are this type, and can be displayed in REGEDT32 in binary, hexadecimal and decimal format, or in REGEDIT in hexadecimal and decimal format.
* REG_EXPAND_SZ - This type is an expandable data string that is string containing a variable to be replaced when called by an application. For example, for the following value, the string "%SystemRoot%" will replaced by the actual location of the directory containing the Windows NT system files. (This type is only available using an advanced registry editor such as REGEDT32)
* REG_MULTI_SZ - This type is a multiple string used to represent values that contain lists or multiple values, each entry is separated by a NULL character. (This type is only available using an advanced registry editor such as REGEDT32)
* REG_SZ - This type is a standard string, used to represent human readable text values.
Other data types not available through the standard registry editors include:
* REG_DWORD_LITTLE_ENDIAN - A 32-bit number in little-endian format.
* REG_DWORD_BIG_ENDIAN - A 32-bit number in big-endian format.
* REG_LINK - A Unicode symbolic link. Used internally; applications should not use this type.
* REG_NONE - No defined value type.
* REG_QWORD - A 64-bit number.
* REG_QWORD_LITTLE_ENDIAN - A 64-bit number in little-endian format.
* REG_RESOURCE_LIST - A device-driver resource list.
on Dec 02, 2009 | Computers & Internet
My wife is having horrible menstrual cramps. what medication can she take to ease them?
from http://www.mayoclinic.com :
  • NSAIDs. Nonsteroidal anti-inflammatory drugs (NSAIDs) may be helpful in relieving the pain of menstrual cramps. Your doctor may initially suggest taking over-the-counter NSAIDs, such as ibuprofen (Advil, Motrin, others) or naproxen (Aleve), at regular doses starting the day before you expect your period to begin. Prescription NSAIDs, such as mefenamic acid (Ponstel), are also available.
  • Hormonal birth control. Oral birth control pills contain hormones that prevent ovulation and reduce the severity of menstrual cramps. These hormones can also be delivered in several other forms: an injection, a patch you wear on your skin, an implant placed under the skin of your arm or a flexible ring that you insert
Apr 18, 2013 | Health & Beauty
Polaroid 4011-TLXB Power supply blew up IC3 I need the generic IC nr. It is an 8-pin dip. It is switch mode driver IC. Please help. Larry @ central tv
Replace power supply board from PTS. No parts available for PCB.
Generic part nr for IC3 is A6252M can't find one easily.
Feb 08, 2010 | Polaroid 4011-TLXB LCD TV
HELLO I want TV Polaroid power supply part,the part number is 860-AZO-MLT666AMH.My Tv blown up some months back and I found out the fuse T5AH/250 its gone. Please can you be of help. Thanks, Akins
sorry dont have a parts book handy.. but blown fuses usally means a big part with a heatsink behind it has shorted.
call a wholesale electronics parts house close to you and they might have it or can cross it to a stronger generic.
Oct 08, 2008 | Televison & Video
Schema classes and attributes
Every directory object you create is an instance of an object class contained in the schema. Each object class contains a list of associated attributes that determine the information the object can contain. Classes and attributes are defined independently, so that a single attribute can be associated with multiple classes. All schema classes and attributes are defined by the classSchema and attributeSchema objects, respectively.
Classes
ClassSchema objects are used to define classes in the schema. A classSchema object provides the template for building directory objects of that class. Examples of classSchema include User and Server. A classSchema object contains, among other things, the following information:
Class type (structural, abstract, or auxiliary)
Common name and Lightweight Directory Access Protocol (LDAP) display name
Lists of the "must contain" and "may contain" attributes for instances of the object
Relative distinguished name attribute
A list of possible parent classes
Class types
Three different types of classes exist in the schema:Class type Purpose
Structural
Used to instantiate objects (users, servers and so on) in the directory.
Abstract
Provides templates for deriving structural classes
Auxiliary
Contains predefined lists of attributes that can be included in structural and abstract classes
Attributes
AttributeSchema objects are used to define attributes in the schema. An attributeSchema object determines the allowable contents and syntax for instances of that attribute in the directory. Examples of attributeSchema include User-Principal-Name and Telex-Number. An attributeSchema object contains, among other things, the following information:•
Common name and LDAP display name
Syntax rules
Data constraints (single versus multivalued, minimum, and maximum values)
Whether and how the attribute is indexed
Jul 17, 2008 | Microsoft Windows Server Standard 2003 for...
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
