Question about Stihl 16" Chainsaw Bar Chain Saw 018 025 Ms 180 250
MS180 CHAINSAW RUNS BUT HAS NO POWER TO CUT - Stihl 16" Chainsaw Bar Chain Saw 018 025 Ms 180 250
Need sparkplug wire for ms180c chainsaw
Robert, spark plug wire for Stihl MS 180C. Check the attached links, Good luck.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Amazon com Ignition Coil Spark Plug Wire Fits Stihl 017 018 Ms170 Ms180...
New Ignition Coil Spark plug wires for Stihl 017 018 MS170 MS180 Chainsaw...
Amazon com IGNITION COIL MODULE FITS STIHL MS170 MS180 017 018 ENGINE...
Jul 30, 2016 | Stihl 16" Chain Saw Repl. Chain Model...
How do i find a repair manuel for stihl ms170 chainsaw
Best Advice I can give you is to contact Stihl directly on their website or 800 number.
Oct 03, 2014 | Stihl 017 018 Ms170 Ms180 Chainsaw Starter...
The rope broke when I tried to start the chainsaw. How do I replace it?
Your rewind spring is now sprung. Remove recoil assy ( the part your rope slides into). Remove all old rope remnants and rewind the spring. Install new rope, tie it off and slowly release spring rewinding the rope.
Mar 14, 2014 | Stihl 017 018 Ms170 Ms180 Chainsaw Starter...
Chainsaw blade rotating when idling
Could be dirt in the carb or a dirty air filter. A good clean is in order I think!
Feb 04, 2014 | Stihl 017 018 Ms170 Ms180 Chainsaw Starter...
Will a complete engine from a stihl 017 fit into a stihl ms180 chainsaw.
you should be able to get the engine to fit. The 017, ms170 and ms180 are all part of the same family.
Jan 15, 2013 | Stihl Garden
Will a stihl chainsaw engine assembly from 017 fit in a ms180
those saws are part of the same family so there should be no problem putting the two together
Jan 10, 2013 | Stihl 017 Crankshaft Assembly W/ Piston...
Stihl 16" Chainsaw Bar Chain Saw 018 025 Ms 180 250 Logo
29 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
