Question about Pride Celebrity X 4-Wheel Electric Scooter
I have aflat tire on my scooter that i would like to fix but i cannot get the rim apart the nut just will not move
    Habit-Forming:
    New Friend:
  • 88 Answers
Be careful! Only remove the wheel's central nut, NOT the outer ring of nuts yet. Remove the tyre valve slowly and with care to empty the inner tube. Remove the wheel by tapping the rear of the wheel as necessary - be careful to remove the axle key and keep it safely to one side. Remove the remaining wheel nuts split the wheel and remove the tube from the tyre and wheel. Check the wheel inner surfaces for rough spots and clean. Insert the new tube and making sure that nothing is pinched reassemble the wheel inflate the tyre to the recommended pressure in stages gently bounce the wheel once or twice to help the tyre to seat properly. Inflate to just above the recommended pressure and release surplus air. Offer the wheel up to the axle with the wheel and axle key slots exactly opposite each other. Insert the "key" in the slot and gently hammer it home.
Voila, you have done it!
Posted on Aug 02, 2016
I need to remove tire?
You will need Socket wrenches, a big ***** Driver and air valve tool if there is a pneumatic tire involved, two 3"-5/16" bolts w/nuts and washers. I like to tip the chair on its side. and loosen the main shaft nut and remove it. Then wiggle the tire back and forth, then lift. If you are lucky it will slide right off. then you can let the air out of your inner tube or go straight to removing the split rim bolts. the ***** driver is used between the rim and tire and pry apart the tire from the rim, work around the the rim until the tire is off on both sides, If this is a foam filled tire then you will need 2 5/16" Bolts w/ nuts and washers replace the tire and line up the hole for the bolts and push the rims together so the long bolts can make it long enough to put the nut on. the nut down a little then put another one on opposite side to pull the wheel in tighten the bolts a little on each side evenly until the original bolts are able to be used to tighten then take out long bolts and install all the rest of the shorter bolts. tighten them up and grease the shaft and put the shaft key in the slot and gently put the wheel on and tighten the shaft nut. Check to see the wheel turns with the shaft. the key can slide out some times Then tip the chair up and see how it drives. Sorry no pictures yet.
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
Mar 28, 2016 | Hoveround MPV5 Electric Wheelchair - Used...
Sunny MC-300TKA has a severe front end wobble
Hi, Clemente and the usual suspects are:
1. Improperly loaded motorcycle. Non-standard equipment on the front end such as heavy radio receivers extra lighting equipment or luggage tends to cause unstable handling.
2. Incorrect air suspension pressure.
3. Damaged tires or improper front-rear tire combination.
4. Irregular or peaked front tire tread wear.
5. Incorrect tire pressure.
6. The shock absorber is not functioning normally.
7. Loose wheel axle nuts. Torque to recommended specifications.
8. Excessive wheel hub bearing end play.
9. Improperly vehicle alignment.
10. Steering head bearings improperly adjusted.
11. Tire and wheel unbalanced.
12. Rims and tires are out-of-round or eccentric with the hub.
13. Rims and tires are out-of-true sideways.
14. Loose spokes.
15. Shock absorber improperly adjusted.
16. Worn engine stabilizer links.
17. Damaged rear engine isolation mounts.
18. Swing arm pivot shaft improperly tightened or assembled.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
***** Wobble How To Fix ***** Wobble KevinsOffroad com
http://www.spyderlovers.com/forums/archive/index.php/t-51337.html
Sunny Trike Scooter MC D150TKA Assembly instruction part 3 the end
Sunny TRIKE 300cc
MC D300 TKB Sunny 300cc Roadrunner 3 wheels Trike Motorcycle at...
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Sep 24, 2014 | Sunny Motorsports Sunny Powersports...
Puncture in one of my front tyre how do l remove it
To remove wheel there is one center bolt in the middle of the wheel(13mm). The wheel is a split rim so on the inside of the wheel there is more 13mm nuts undo them and the wheel comes apart.(no need for tire levers)
Feb 10, 2014 | Electric Mobility Shoprider Electric Power...
I have a flat tire on my scooter which i would like to fix but unable to get the rim apart can you help me
Yes. Be careful! Only remove the wheel's central nut, NOT the outer ring of nuts yet. Remove the tyre valve slowly and with care to empty the inner tube. Remove the wheel by tapping the rear of the wheel as necessary - be careful to remove the axle key and keep it safely to one side. Remove the remaining wheel nuts split the wheel and remove the tube from the tyre and wheel. Check the wheel inner surfaces for rough spots and clean. Insert the new tube and making sure that nothing is pinched reassemble the wheel inflate the tyre to the recommended pressure in stages gently bounce the wheel once or twice to help the tyre to seat properly. Inflate to just above the recommended pressure and release surplus air. Offer the wheel up to the axle with the wheel and axle key slots exactly opposite each other. Insert the "key" in the slot and gently hammer it home.
Jul 30, 2013 | Pride Health & Beauty
Pursuit XL scooter, rubbing sound during right turns...
My first guess is that you have either loose lug nuts(5)on one or more of the wheels, or you have loose screws(6)that hold the wheel rims together as these have split rims. This is more common on scooters with flat-free tires as the tire and the foam insert will chafe against each other and produce a rhythmic sound as the wheel rotates. Try tightening all of the lug nuts first and see if that helps. If it persists, try removing the tire by removing the 5 lug nuts and pulling it off the axle. You'll see six bolts that hold the rim halves together. Re-tighten all of these and install the wheel to see if that cleared the noise. Note: The real wheels have a key-slot in the axle and a key which slides into this slot to hold the tire to the axle. Be careful not to lose the key when you slide the wheel off, and be sure to get the key back in the slot when you install it back on the hub. Here is the page for your scooter. Click on the owners manual and scroll down to page 37 for info on tire removal.
Jan 10, 2013 | Pride Mobility Pride Pursuit XL 4 Wheel...
How do you get the rubber tire off the rim?
Get the rim / tire of the frame. Let all the air out of the tube, Using two flat blade screw drivers, put them between the rim and tire about 3 inches apart, (be careful not to puncture the tube) Pry the tire over the rim, leave one in place and move the other about 3 more inches and pry the tire over the rim again, keep moving around the rim until the side is off. Reach in and pull the tube out, fish the stem through the hole. Finish pulling the tire off the rim, you can use liquid soap to help make things easy. Put the rim back together the same way. Hope this helps Fix Ya up.
Jun 18, 2011 | Mongoose Cycling
Have a flat tire on a Chauffeur Scooter rear wheel.
I just removed the right rear wheel from my Chaffeur scooter. I first removed seat, plastic cover and batteries. Then removed wheel center bolt, set scooter on it\'s side and used a short 2x4 and rubber mallet to drive the wheel off. A shot of penetration oil helped. It is an extremely tight fit.Can\'t figure the two piece rim out though. Anyone have suggestions on why it is a two piece and how to remove tire from rim?
Apr 28, 2010 | Health & Beauty
How to change the flat tire? Can not remove tire off the rim. How i get the nuts off?
While there is road side assistance that can help in times of need. It's imperative that every driver should know about how to replace a flat tyre. After ascertaining that the tyre is flat, you should check the link which will guide you to change the flat tyre with the spare one, have a look
=> DIY 10 easy steps to change flat tyre
=> How to Change Flat Tire
Dec 16, 2009 | 1998 Volvo S70
Clicking, first noticed on carpeted surfaces. Sounds like it is coming from rear end. Scooter has been used outdoors mostly over some rough terrain. No leaks visable. Was recently purchased used from a...
Clicking from the tires is usally due to one of two things. First, check to see that the nuts holding the wheel onto the axle are tight by removing the plastic cover and tightening them as hard as you can. Drive and see if it quit clicking. If not, check the air in the tires; they should be kept at the stated range on the tire. If they are foam-filled, flat-free tires, these can often click when the tire chages against the wheel. It doesn't affect the safety of the scooter but can be annoying. Spraying some WD-40 around the rims inside and out will often clear it up. If not, you'll need to pull the tire and tighten the 4 bolts that hold the split-rims together.
Oct 07, 2009 | Invacare Supply Group Health & Beauty
Click and clunk when moving from right rear wheel Pride Elite +
This can be caused by two things usually. One cause is the bolt holding wheel to the axle is a little loose so check to make sure it is very tight on the axle. The second click comes from flat-free tires. The tires have an adhesive applied at the factory and if you hit a bump, or if there's not enough to hold the tire tight to the rim, the tire will make a grinding click noise when it rolls and passes over this area. Pneumatic tires properly inflated don't make this noise since the air pressure keeps the tire fixed to the rim at the bead; flat free tires lack this pressure. Simply lubricate the area around the tire where it meets the rim on inside and outside, and drive it...noise should dissipate.
Aug 28, 2009 | Pride Go-Go Ultra X 3-Wheel Travel Scooter
Pride Celebrity X 4-Wheel Electric Scooter  Logo
80 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
