Question about Sewing Machines
Where can I find a user manual for the Brother Pacesetter Free arm 6945 sewing machine
    Champion:
  • 208 Answers
Contact Brother in your region, unlikely you will get one from a shop because not many spares were made
Posted on Oct 10, 2013
bargainbox
  • 1388 Answers
SOURCE: stitching looping
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....the question you pose could have 2 meanings....this reply is for looping thread.
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
cc3f045.jpg...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all back properly.
FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes. ie a different colour top and bottom just for the test.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is, and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine case....no case ? then make some sort of cover ! Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistant diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
If you need any more help with this, just post back here, or, drop a line through the "Contact Us" page at www.bargainbox.com.au
Posted on Feb 23, 2008
informatica
  • 1114 Answers
SOURCE: Looking for the free manual that you advertised
Hi - You can download the manual by clicking the link underlined in blue below:
LS-1217
Other info here.
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Posted on Sep 14, 2008
  • 253 Answers
SOURCE: user manual needed
The manuals will sometimes come on CD now, hard to read I Know.
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_PS_1250_MULTI_1343.PDF
This is the direct link to the manual, you will need the free adobe acrobat reader(You probably already have it) when you click on the link if you cant see it you will know.
Please give a fixya rating if this is what you needed, Thanks.
Posted on Apr 12, 2009
SOURCE: brother vx810 sewing machine user manual
This is an old forum, but thought that I would add a link - http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_VX_807_810_EN_1068.PDF
Posted on Aug 21, 2009
award462
  • 395 Answers
SOURCE: user manual
http://www.fixya.com/support/r4964670-get_manual_most_any_electronic_device
Posted on Jun 03, 2010
User manual
here is a link for the manual, it's not free, you can try contacting brother customer service and see if they have a free one, but I couldn't find one for free
Dec 03, 2013 | Brother PS-1250 Pacesetter
I need a User Manual for the Brother Free Arm 6945 sewing machine
check with a1sewingmachines.com and go to the contact us section,, they have a email address and a phone number, ask them about the manual.
Jul 26, 2013 | Sewing Machines
Lemair Pacesetter 703 user manual
email these sites about the manual, they should be able to tell
you something about the manual
sewvacdoctor.com
sewusa.com
mastersewusa.com
Jun 03, 2012 | Brother Sewing Machines
How to thread a pacesetter sewing machine?
There are different models of the Brother Pacesetter.
If you try the Brother website you should be able to download a manual.
Apr 01, 2010 | Brother Lay-In Thread Serger Mechanical...
Oiling a pacesetter
No oiling by the user.
Computerized machines are lubricated and sealed in the factory.
If you are the original owner, you could invalidate your warranty if you go beyond the maintenance routine described in the manual.
To keep the warranty, your machine is to be serviced by an authorized Brother tech on a regular basis - once a year if it gets heavy use.
General maintenance, per the manual, will keep the machine in good working condition.
Mar 31, 2010 | Brother PC-6000 Pacesetter
What type of bobbins does the PC 6000 use. I cannot find my owners manual. can you help?
There is no free download available for model 6000 but you ca get a free download for model 6500 from the below link.Atleast you ca get some idea if you view the manual for 6500 as it is the same 6000 series.
http://homeappliance.manualsonline.com/manuals/mfg/brother/pc_6500.html
If you need the exact manual for model 6000 then you will have to buy it for $9 from the below link:
http://www.download-manual.com/shop/Brother-PC-6000-Sewing-Machine-User-Manual-pr-10597.html
Jul 08, 2009 | Brother PC-6000 Pacesetter
User manual needed
Apr 12, 2009 | Brother PS-1250 Pacesetter
We can not operate our brother Pacesetter sewing machine
A lot of time you can find a manual on ebay or sold through sewing supply stores. A quick search online showed that sew4less has the model manual for sale. Also if you contact brother or check their website you should be able to get a manual.
Oct 09, 2008 | Brother PC-6000 Pacesetter
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
