Continous message on the screen "New external device is connected. Do you want to enjoy this? AV2 NO
How do I get sky tv through my philips mx5100vr home theatre
External Input Mode (for VCR features) To receive the signal from an external input (decoder, satellite receiver, video camera, another VCR etc.), connect to the AV2 (DECODER) socket, and enter "002" with numerical key pads to appear "AV2" on the TV screen.If you use the AV1 (TV) socket, enter "001" with numerical key pads to appear "AV1" on the TV screen. If you use the front AUDIO/VIDEO input jacks, enter "003" with numerical key pads to appear "AV3" on the TV screen.
Apr 25, 2015 | Philips MX5100VR System
Input composite
I would take a Close look at the Connection itself on the back of the Tv and verify its not broke and theres no dirt or dust in it..... somtimes dirt and dust can cause such an error... of course connecting something to it is a possible solution ... like an ps3 or xbox
Oct 13, 2013 | LG 42 42PT350 42 Plasma TV
I have connected the audio optical cable from my TV, but I couldn't get the koss system to work. Are there any other settings need to be set? Which channel should i use to get the sound AV1 or AV2?
AV1 & AV2 are the Video Inputs from your external devices such as DVD Player, Freeview etc.
I presume you have something connected to your TV and want to get this sound from your TV to output through your Koss.
Their should be a menu to activate the Optical Input but I can't find the manual to advise the correct menu.
I'll keep looking for a manual so if you can't find the menu let me know and I'll see what I can do to guide you in the right direction.
Jul 25, 2011 | Koss KS5190 System
All the lights come on when I switch on my HP Pavillion dv9600 but the screen is blank.
DO THIS FIRST - Perform a hard reset If a PC suddenly fails to boot properly, you should perform a hard reset as the first procedure.
  1. Disconnect all peripheral devices and remove all USB devices and media cards. You want to test the computer not the accessories!
  2. Disconnect the AC power adapter, remove the battery, and then press and hold the power button for at least 15 seconds .
  3. Reconnect the AC power adapter (but do not connect the battery), Press the Power button, Look for glowing LEDs near caps lock and num lock keys, and Listen for sounds of a disk drive and fan turning.
Actions to take after performing hard reset If no error message is displayed:
If a text error message is displayed, see Troubleshooting Error Messages on a Black Screen During Startup or Boot c02076104.jpg
Black Screen with No Error Messages Connect an external monitor c02076105.gif If there is a problem with the LCD display's back light or a corrupted graphics driver, the display may appear blank but the notebook may be displaying information. Attach an external monitor to test the display. If the image displays on the external monitor, there may be a graphics driver conflict. To resolve this, turn on the computer and press f8 key, then select Enable low-resolution video . If the image displays on the LCD display in low resolution, you can download and install the latest drivers for your specific graphics driver. If there is an image on the external monitor but the notebook display remains black, contact HP for technical assistance. Disconnect all peripherals and repeat the hard reset Even though users are instructed to disconnect all peripheral devices from the notebook when doing a hard reset , some devices are often overlooked. c02069237.gif Double-check that all devices are disconnected including: external keyboard and mouse (wired or wireless), USB connected external drives and devices, thumb drives and flash drives, network storage devices, PC card, SD memory cards, express card, eSata connections, firewire or similar devices, printer, scanner, camera, port replicator, or docking station, any CD/DVD from the optical disc drive, and any media from the multi-card reader.B
b52compters@gmail.com
B52computers
Chris Thrash
Jan 10, 2011 | HP Pavilion dv9500 dv9600 and dv9700 FF...
How do I switch to AV3 , AV2 And AV1 functionon the sony Bravia 40 inch HDTV
All you need to do is press the TV/VIDEO button in the top left corner of your remote. Each time you press, it will cycle through the connected external inputs, e.g. AV1, AV2, etc.
Hope this helps.
BElectric
Nov 23, 2010 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Unable to record to VCR from Alba LCD TV(LCDW16HDF0
Tried all combinations of scart connections and channel settings ,without result.Finally connected an external freeview box to VCR AV2,with through aerial feed to TV.Setting TV toEXT-1 and VCR to AV2 and with scart to phono adaptors connected box audio and video "out "with phono leads to audio video "in" using an adaptor into the TV scart socket.
Jun 17, 2009 | Hitachi Televison & Video
Have a Sanyo DP42828(42"). My Satellite is working after the card resetting itself. But which 3 holes do I hook the (RED, YELLOW, and WHITE) for the dvd player?
dems,
Are you reffering to your DVD player to be conected to with your TV screen?
For DVD player connection the 3 colored RCA jack socket are:
YELLOW = video out
RED and WHITE = Audio out (left and right channels)
to hook up to your screen, at the back of the screen or side of it you'll see RCA socket indicating "AV1" "AV2" AV3" this are all Audio/video inputs where you can hook up all you A/V device or game consoles. These inputs also have the same 3 colored socket (yello = video red/white = audio)
connect your DVD player to any of this input following the same color code.After connecting the cable, select the input where you hook up your dvd player. Do this by pressing "A/V" buttons in remote commander of your TV. continously press this button until it reaches the exact location where you plug your player ex. AV1, AV2,AV3
note: in some cases the remote commander doesn't indicate this A/V button but a picture of a box having a arrow pointing inside the box.
cheers,
mark
Jan 05, 2009 | Sanyo DS31590 31" TV
Laptop boots then shuts and continously does it
you really need a recovery CD, or windows operating system.
try removing any external devices ( Printers/scanners/ USB devices et,c ) And start the computer up with bare minimum devices attached/connected. it may be one of the external devices causing your problem.
Mike @ Compurepair.
Jun 08, 2008 | HP Pavilion zd8000 Notebook
Panasonic TV - want to remove on screen message
its an input message i dont have your remote in front of me but im going to say when you hit the input av1 av2 there should be a button on remote for display or info one of these buttons should deactivate that message
May 13, 2008 | Televison & Video
Televison & Video Logo
458 people viewed this question
Top Televison & Video Experts
Electro Med Services...
