Question about Honeywell Dryers
I need to replace the power switch for my ht-800 table fan and I would like to know were to obtain a suitable replacement switch
    Top Expert:
  • Honeywell Master
  • 12,223 Answers
Go to www.americanfans.com and get it
God bless you
Posted on Jul 31, 2013
5 Suggested Answers
Crossedwires
  • 44 Answers
SOURCE: Fan switch replacement, Ellington fan
That would depend on the make and model of the fan. best to check the manufactorer web site for this information or call them if you do not have internet.
Posted on Feb 09, 2008
mrboo747
  • 24 Answers
SOURCE: Lasko E20739 Fan
I would love to tell you yes, but I ended up buying new fan.
The common wire was broken, buried in the windings and no way to repair without
damaging the windings.
Could not find anything on line.
Sorry,
mrboo747
aka Gary C
Posted on Nov 11, 2008
  • 334 Answers
SOURCE: wattage for the honeywell ht-800 fan
Can you see an amp draw rating on the fan motor itself?
Posted on Jun 20, 2009
  • 1196 Answers
SOURCE: need a replacement switch for soleus FCM-30
You can get your replacement switch at either ereplacementparts.com or ebay.com, you can also contact the manufacturer to find out if they have the switch or try check electronic stores/electronic parts sellers within your vicinity to see if they have it.
Posted on Jun 08, 2011
How do I clean the table fan? It is very dirty.
Remove the front grille with a phillips screwdriver, there are also two T10 Torx screws on the top and bottom. Wipe everything down with disinfectant wipes. Do NOT use water, with the exception of the front (dry it thoroughly). Don't remove the fan blades. Replace the front grille and screws.
Jun 25, 2015 | Honeywell HT-800 Table Fan
Can I replace the blade? Where do I get a replacement blade?
http://yourhome.honeywell.com/home/Applications/ReplacementPartsSearch.aspx
Nov 10, 2014 | Honeywell HT-800 Table Fan
BROKEN BLADE OF TABLE FAN
obtain new blade and replace same.
https://yourhome.honeywell.com/home/.../ContactUs.aspx
Jan 11, 2014 | Honeywell HT-800 Table Fan
How do I get a replacement remote control for an AIRWORKS ceiling fan/light
There are lots of fans with remotes available for under $40.00. I don't think you can find a remote for $40.00
Oct 16, 2013 | Honeywell HT-800 Table Fan
I have a honeywell upright fan, which was purchased about 18 months ago. The fan has just stopped working. The lights go on and it will oscillate but the fan has stopped functioning. Not sure how to fix it
The problem would be the burn out thermistor(FUSE), it is located in the winding of the motor itself. Before that check the wiring connection in the speed switch, the main line might have cut off.
Using the tester, check the continuity of the fuse. You can't see the fuse, it is mainly covered and connected in the capacitor line.
The cause of the burned fuse is overheating, the shaft bushing needs oil or have to be replace!
Hope that helps you out!
Jun 09, 2011 | Honeywell HT-800 Table Fan
How many watt it have?
    Features and Benefits:
  • Powerful 3 speed turbo fan for fast focused cooling power or enhanced air circulation
  • High performance blades rotate for maximum air velocity through the wind tunnel turbo grill
  • Pivoting head can be adjusted in a 90 degree arc for varied air distribution
  • Versatile design makes this fan great for use on desk and table tops
  • Wall mounts with separate purchase of hardware
  • Equipped with a carrying handle for transport
  • Dimensions and Weight:
  • Size: 6.33" x 11.375" x 11.125"
  • Weight: 3.5 lbs.
    Power 50W @ 110V
    Power 60W @ 220V
Feb 14, 2011 | Honeywell HT-800 Table Fan
HT - 800 Table Fan, I would like to know what the recommended maintenance is for it?
The owner's manual states "This fan does not disassemble". It appears this fan is maintenance-free.
I hope you find this to be very helpful in answering your question. :-)
Mar 23, 2010 | Heating & Cooling
Removing the hex screws from the table fan
you need a security bit it will have a small hole in it just for the screws you are trying to remove
Jul 26, 2009 | Honeywell HT-800 Table Fan
Wattage for the honeywell ht-800 fan
Jun 20, 2009 | Honeywell HT8002 Table Fan
I can not figure out how to take the cover off of the fan so I can clean it.
I have the same 1 , I take mine outside and hose it out , dont spray the switch so much and let it dry very well before plugging back in.
Phil
Jan 12, 2009 | Honeywell HT-800 Table Fan
Dryers Logo
59 people viewed this question
Top Honeywell Dryers Experts
Jay Finke
Jay Finke
richie46
Steve
Level 1 Expert
Are you a Honeywell Dryer Expert? Answer questions, earn points and help others
