Question about Sewing Machines
I'm looking for a babylock overlocker BL4-736 convert looper to buy. It's a small little wire which you insert in the looper so that you can make a rolled hem. If you can please help me with a suplier. My email address is lismonav@yahoo.com Thank you!!
bargainbox
  • 1388 Answers
SOURCE: Ezy_Lock 304D
This may be too small to read, if so, email via
www.bargainbox.com.au and I shall send it on........remember to only ever use the R needle, so you only have 3 threads.
To move the Rolled hem arm, you will need to release the upper knife (knob on left inside cover....push to the right and blade moves approx 6mm) so you can slide the small metal tongue to correct position for:
N = Normal
R = Rolled
Posted on Feb 17, 2008
  • 4 Answers
SOURCE: Babylock 5380E Service manual
http://www.sew4less.com/manuals.php?OVRAW=sewing%20machine%20manual&OVKEY=sewing%20machine%20manual&OVMTC=standard&OVADID=936063522&OVKWID=4667402522
This might help you,
Also, you might find a dealer through this
page:http://www.babylock.com/where-to-buy
Posted on Aug 12, 2008
SOURCE: thread continually breaking in lower looper needle
I was having this very same problem with my lower looper . I had been using the one needle stitching all afternoon and I was doing quite nice stitching. then I decided to put the right needle back in and do some overlock stitching and guess what I spent the next two hours fighting the looper problem. I had completely re-thread this machine at least 20 times now. I decided to take the needle out and re-insert it and re-thread it one more time (right lower looper- then upper looper- right needle- then left needle) was careful to pull all threads to the back and under the presser foot for about 6 inches.
Held on to the thread, lowered presser foot and did the chaining stitch. BINGO it didn't break, tried it with a piece of cloth and Perfect stitches. I have a Babylock BL402 and used tension settings left to right
4-3-3-3 and default settings for the rest.
Hope this helps someone someday.
Jo Griffith
Posted on Mar 29, 2009
  • 3 Answers
SOURCE: Owners Manual needed for Overlocker Toyota SL 3404D
"World of Sewing" have these manuals.....you need to ask for "Toyota SL series". I got my replacement manual from them and the service is excellent. Their phone number is online if you want to ring them (UK ) Hope this is helpful to you
Posted on Dec 01, 2009
  • 1116 Answers
SOURCE: I can't find my Bernina Serger 800 dl manual - how
From what I have read this manual is less than desirable. Neither is the one for the brand that I have.
You may have better guidance if you purchase and use Nancy Zieman's "Serge with Confidence". I have found it very helpful.
For the two thread rolled hem, the looper cover is used to "trick" the looper into "thinking" it is threaded.
On my serger (not a Bernina), this is referred to as a "subsidiary looper". It is a spring type mechanism that fits in a small hole at the top of the upper looper.
You use a rolled edge presser foot; right or left needle; stitch length @ normal or wider; stitch length @ 1mm for the left needle/0.5 for the right needle; differential feed @ normal; needle tension - tighten; lower looper tension - normal or looser; two thread looper cover - engaged.
Test and adjust the tension as needed before making the rolled hem on your garment.
I hope this helps.
Posted on Apr 18, 2010
I have been given a Babylock Evolve overlocker and am having difficulty in adjusting the stitch so it doesn't extend over the edge of the fabric
Sounds like your looper tensions are too loose. If the threads are "slopping" over the edge of the fabric, tighten the looper tensions.
Jul 19, 2017 | Sewing Machines
How do I set up my babylock serger for a rolled hem? What is the tension to be set at?
I don't know your babylock well, some of these have automatic tensions and electronic stitch selection. But a rolled hem is achieved on any overlocker in the following way; the actual dials and knobs might vary a bit.
Firstly there is a stitch finger that you need to change or retract so that the thread can roll the fabric rather than staying flat. For a normal seam this finger sticks out in the area where the loopers and needle form the stitch holding the cut edge flat until the seam is made over it. But for rolled hems you want to retract this finger so it does roll.
On the Bernettes this is a little lever in front of the stitching area that you pull back to retract the finger. Have a look around where the stitch forms and you should see the finger. Some machines, its a part you change on the needle plate with a screw driver, or just move a switch or lever.
You want the right hand needle in place, remove the left hand needle.
Thread upper looper with wooly overlock thread, this is a fluffy nylon that pulls flat under tension but relaxes and "fills" out once its stitched into place. Gives that lovely covered look you see on shop bought tablecloth edges. Your regular thread in needle and lower looper. Usually cutting blade to the right side as you want it to cut more fabric than in the seam so it rolls under. Now loosen off the tension on the top looper, (I use 2 on mine but this is something you need to finesse with each machine), and tighten up the tension on lower looper, (about 7). Leave needle tension alone.
Now test stitch on your fabric, and finess the upper and lower looper tensions until you get the lower looper thread almost not showing, it should be right up against the needle on the underside with the upper looper thread completely wrapping around top and bottom, pulling the fabric under.a seam like this.
Test stitch and adjust upper and lower looper until this is happening.
Now, turn stitch length down to close up the stitching, probably 1 or 0.8 if you want a real satin stitch look to the hem.
Because of the stitch density this uses thread so do the finessing first, then turn the length down.
That's it! Now right down the tension settings you used and keep handy for next time.
Sep 24, 2011 | Baby Lock Eclipse Serger
How do I oil my Janome 664d overlocker
Does your overlocker have a threading diagram on the inside of the front cover? Often this will also show a couple of red dots where you need to oil.
Obviously always best to consult the manual if you have it; I haven't been able to find an image of the threading or oiling diagram for your machine.
If it doesnt have this diagram and you don't have a manual then I would hazard a guess and say that you need to oil the loopers where they move through another metal part. So open up the front and have a look at the lower looper mechanisim, manually turn the flywheel to move the looper and you should be able to see what I mean. The lower looper will move back and forwards through a metal socket piece and the looper bar may look lubricated on each side. So give the metal holding bit a drop and the oil should work into it. There may be a similar looking bit for the top looper, have a look and give it a drop of oil.
Some overlockers will have an oiling point at the back of the sewing table, it may be a little hole marked with red paint.
Sep 06, 2011 | Janome MyLock 644D
My serger, Babylock Imagine's looper threads are too tight. I have tried rethreading, adjusting the fine tuning screw and varying stitch lengths and widths. At the recommended setting for the 3 thread...
I am having this same problem today. The needle threads when pressed look almost like a flatlock stitch. There seems to be no tension. With BabyLock's auto tension system, I have no idea what to do. I've been on the phone with my dealer about this today and he is clueless as to what may be causing it. I guess it's time for a checkup.
Sep 07, 2010 | Baby Lock Imagine
Serger stitch not forming right
It sounds like the timing needs to be reset by a sewing machine repair tech.
May 09, 2010 | Baby Lock Evolve
I require operating instructions as to what is requiered for flat bed stitching?
I can share the information for my BabyLock Imagine in hopes that it will help you.
There are options of 2 or three threads.
For the 2 thread the serger must have a 2-thread converter- aka, auxiliary looper or subsidiary looper.
This is a spring type mechanism that fits in a small hole at the top of the upper looper. It 'tricks' the upper looper into thinking it is threaded. It must be engaged by connecting to a small hole in the upper looper
Set up the serger for a 2 or 3 thread right or left needle.
Stitch width - wide if you are using the left needle and normal if for the right needle; length 1 - 3mm.
Needle tension loosened and looper tension normal.
Disengage the cutting blade..
Set the differential feed at normal.
Hope this will help.
Mar 19, 2010 | Janome Memory Craft Compulock
Thread continually breaking in lower looper needle
Jo Griffith
Oct 20, 2008 | Toyota TL-432DE Mechanical Sewing Machine
Unable to thread lower looper on Babylock Eclipse BLE1SX
On rare occasions lint can clog the yubes on these sergers. One of the first things I do is thread the wire through in the opposite direction. It will sometimes push the blockage out. The other option is to use an air compressor and again blow the lint out from the opposite side. If this does not work take it to a service man.
Dec 18, 2007 | Baby Lock Eclipse Serger
Sewing Machines Logo
23 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
