Question about VinoTemp VT-52SN Stainless Steel Wine Cooler
VT-52SN stopped cooling. I opened the back and cleaned the coils. The compressor and fan run continuously, but the temperature reads 76.
3 Suggested Answers
57 varieties
  • 1653 Answers
SOURCE: Vinotemp (VT-60), cools, but doesn't turn off
It will either be the thermal resistor or the controller of which the electronic thermostat is a part and yes it can be repaired. It is a reasonably common and cheap fault to repair. If you go to the following link you can get the service manual FOC
http://www.vinotemp.com/Resources/Documents/VT60.pdf
and you can contact a repair company via Vinotemp at the following link
http://www.vinotemp.com/Service-Support/Repair-Companies.aspx
Posted on Nov 05, 2009
bobicehouse
  • 1524 Answers
SOURCE: My Vinotemp VT52SN stopped cooling.
How To Test the Compressor Relay The compressor relay's purpose is to start the compressor. A faulty relay can result in the compressor failing to cycle on. The relay is accessed from the lower rear of the refrigerator the relay is located in the terminal box which is located at the side of the compressor.
Before testing a compressor relay, unplug the refrigerator to avoid an electrical shock hazard. Also, if the compressor uses a capacitor, it must be discharged first to avoid the risk of electrical shock.
Beneath the terminal cover is found the compressor relay , overload protector and the electrical terminals of the compressor motor.
Remove the compressor relay by pulling it straight off from the compressor.
Pull the wire off of the side terminal of the relay. It is connected with a slip on connector. Firmly pull the connector, do not pull on the wire. You may need to use a pair of needle-nose pliers.
Inspect the connector and terminal for corrosion. If either is corroded they should be cleaned or replaced.
There are two types of relays you may encounter, wire coil and solid state. If the relay has an exposed wound wire coil it can be tested for continuity. Otherwise, the relay is of solid state design and requires specialized equipment for testing.
Posted on Jul 08, 2011
Fridge/Freezer not cooling, fans blowing, compressor running,double checked coils, and cleaned rear of box as well, no cooling in either freezer or fridge, thoughts?
FREEZER /FRIDGE NOT COOLING: Optimum refrigerator temperature at or below40° F(4° C). The freezer temperature should be0° F(-18° C). Check temperatures periodically. Appliance thermometers are the best way of knowing these
Check ur cold control thermostat, ur thermistors in both fridge and freezer ( they should be checked for both ohms and for amount of current being put out as per ur model ), ur air flow vent from freezer to fridge.( to make sure it opens and closes without any restrictions) On thermistors check for A close circuit and amount of ohms not just an Ohm reading. As per ur model. Most should atleast show 1200 ohms. Also Check door seals for leakage.
Evaporator coils
Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
FAN check to see if it is operating or restricted A fan that is not blowing or restricted will not circulate the cold air properly.
Often, the first thing that folks do when their refrigerator starts to feel warm is turn both controls on the coldest settings.This is exactly the WRONG thing to do.Turning the cold control to the coldest settingwillkeep the compressor running longer and make lots of cold air.
But turning the air door to the coldest settingclosesthe airway to the food section. Lots of cold air is made, but most of it stays in the freezer section, and the food section actually getswarmer.
Condenser
Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
May also need to check the defrost timer, u can get by and test manually by placing a small screw driver into the tiny slot or hole underneath the timer and turn slowly clockwise till u hear 1 click. this will engage ur defrost cycle in about 15 minutes u should be able to come back and feel the heat in freezer as it melts the ice providing ur terminator is not bad?
Another way to test it is with a multi meter. Remove timer it from fridge and you will see 4 prongs numbered 2,1,4,3 in that order. Place ur meter prong on prong 1 & 3 (if your fridge has a capacitor wired in series with the windings, then u check for micro fares rather than OHMS) If u cannot confirm this test, still try the next.
Take ur meter prong and connect to prong 1 & 4, it should read resistance or ohms ( closed) now remove prongs and place on prong 1 & 2, this should now read infinity or open (no ohms) now take a small screwdriver place it in the tiny hole or slot under the timer. Turn it clockwise slowly till u hear 1 click. Now ur 1& 2 should read closed ( showing ohms or resistance) now place meter prongs on 1 & 4 and you it should now show open ( or no resistance - no ohms) this is how u know ur timer is good, Remember when testing for ohms ADJUST meter to use a high ohms rating in the thousands as the resistance is very high in OHMS. And adjusting to low ohms rating may give a false reading or not show the proper resistance..
THE COMPRESSOR:
If you hear a clicking sound coming from the back of your refrigerator/freezer, then the problem is most likely the compressor, relay and or capacitor is overheating or not getting proper power and will not start.The compressor is the component on your refrigerator that allows your refrigerator to cool. If this component is not working properly your refrigerator will stop cooling. Most of the time the compressor is not the component that has failed.
To check ur compressor with multi meter:
Disconnect and remove the relay and capacitor from compressor, some located next to compressor in a casing.
You wills see 3 prongs coming out of compressor. 1 goes to ur srtart winding, 1 goes to ur run winding and the center goes to ur ground.
Place ur meter connector or prong on the start prong and the other on the ground (center prong) take note of the reading in OHMS for example 5 ohms.
Next place meter prong on run prong and the center ground prong agin. Take note of the reading in OHMS. Example 4 ohms
Next place meter prong on the start prong and the other on the run prong, now take note of the reading example 9 ohms. Now match the total of this ohms test with the total of ur two separate test. 9 ohms, if they match ur ok give or take 5 percent plus or minus. One more test to make to test of there is a short in compressor attach meter prong to ground prong and rub the other end of meter prong to metal ( scrape the metal clean of paint and test on metal surface not painted surface. If it shows continuity or ohms , u have a short in ur compressor. It should show infinity
Lastly you should also check ur THERMISTORS in the freezer and fridge section for continuity OHMS and for amount of OHMS current being put out. In most models around 13000 ( give or take 150 ohms) ohms is required.
Read more:http://removeandreplace.com/2013/10/31/fix-refrigerator-freezer-wont-cool-freeze/#ixzz3WDEo5NDJ
REMEMBER GOD IS THE REASON FOR GOOD ADVICE"
May 06, 2015 | Refrigerators
How can I fix the problem of the fan shutting off?
Check ur cold control thermostat, ur thermistors, ur air flow vent from freezer to fridge.( to make sure it opens and closes without any restrictions) On thermistors check for A close circuit and amount of ohms not just an Ohm reading. As per ur model. Most should atleast show 1200 ohms. Also Check door seals for leakage.
Evaporator coils
Condenser
THE COMPRESSOR:
Disconnect and remove the relay and capacitor from compressor, somes located next to compressor in a casing.
Mar 12, 2015 | Maytag Refrigerators
GE25JFR... Ice maker cycles and freezer IS cold enough, but once a week the defrost cycle melts all the ice and all the food becomes thawed to nearly room temperature. After I turn dial to 0 for a min
Evaporator coils
Condenser
THE COMPRESSOR:
FRIDGE COILS or door walls SEEM VERY HOT:
The condenser coils do get hot. They can even be to hot to comfortably touch and this is normal.
The refrigerator should not run constantly but shut off with each defrost cycle.
Running constantly and never cycling off can indicate a cooling problem.
One thing to try is to wait till it has been running a few minutes then open the door and turn your cycling thermostat towards the off position. It should cycle off before getting to the off position on the dial.
If it does not cycle off then it's not getting cold enough to satisfy the thermostat. This is likely the reason the refrigerator runs all the time.
A thermometer in a glass of water can be used to check the temperatures in the refrigerator section.
You can check that all fans are running.
Feb 11, 2015 | Refrigerators
Defrost timer location
Evaporator coils
Condenser
THE COMPRESSOR:
Jun 01, 2014 | Samsung RS2630SH Side by Side Refrigerator
I have a beverage air ucr48a. It stopped cooling so I cleaned the back really good and it worked for about three weeks and then quit cooling. Everything is running fine just won't cool now.Could it be the...
Evaporator coils
Condenser
THE COMPRESSOR:
Dec 10, 2013 | Beverage-Air Refrigerators
Bought 4 small Gold Star units in 2009. One quit cooling altogether, one blows slightly cool while the longer another stays on the less it cools. One did not cool well when it was new. All filters are in...
http://www.appliancepartspros.com/partsearch/frame_diagram.aspx?diagram_id=28700000&pkw_=basket&model_id=5520000&NewWindow=1
Download this illustration and then using a good multimeter start basic troubleshooting.
All residential window air conditioners have a cooling system made up of four primary components, a compressor, an evaporator fan, a control or switch, capacitor.When the thermostat is calling for a colder room temperature the compressor is energized. It is normally very quiet. The evaporator is always located on the front of the air conditioner. It also has silver fins. Be sure it is clean. Use a foaming type cleaner and rinse with plain water. Because the evaporator is absorbing heat, it is very cold to the touch. The temperature drop causes any humidity in the air to collect on the evaporator - sometimes called sweat. There is a fan inside the air conditioner that circulates the air for the evaporator and condenser coils. The circulating fan and compressor are running simultaneously. The fan motor has two fan blades attached to it on either end. The fan blade on the inside part of the unit continually draws room air over the evaporator coils, which are cold. The fan blade on the outside part of the unit continually draws fresh outside air over the condenser coils, which are warm. Because the evaporator coils are cold, they cause moisture in the room to collect on them, much like a cup of ice water on a warm, humid day. When the amount of moisture increases, it begins to drip down off of the coils into the bottom pan of the air conditioner.
If the compressor fails to start or the fan you may need to replace the capacitor.
You may need a hard start kit.
Thermostat control The thermostat on a window air conditioner works by sensing the air temperature entering the air conditioner. As the air entering the unit reaches the set temperature it will cause the compressor to turn off. The blower may continue to run depending on the selection chosen on the control panel. Digital thermostats work on a similar principle but display a more precise temperature.
Test for continuity with the multimeter between the two terminals . Warm you should read continuity (contacts closed). If not change it.
Selector switches The air conditioner selector switches allow the user to choose the fan speed. The compressor always runs at the same speed regardless of the settings. If low cool is chosen, for example, the fan runs at a slower speed but the compressor still offers the same cooling capacity. There are other switches to control louver operation and other features on some units.
Jul 23, 2011 | LG Goldstar GWHD5000 wall/window Air...
My Vinotemp VT52SN stopped cooling. I was away from home for a few days and when I came back the fan was running and the temp was stuck at 62 degrees. I had it set at 54 (and lower)... the fan runs and I...
Jul 08, 2011 | VinoTemp VT-52SN Stainless Steel Wine...
My refridge and freezer stop cooling fan is
check the overload relay, see the motor compressor , on side ot its body had a small box where the wiring goes in, open it and check the relay , see if still have continuity or better yet replae.
Oct 31, 2009 | Kenmore Refrigerators
Air condition. not cooling the house
Have you clean it at all?How about the filter?I would do those things first before I get someone to charge it.
Mar 26, 2009 | Coleman Mach III Air Conditioner
Runs but doesn't cool
Verify the compressor is running first and the fan close to it. Check for dust dirt in the condenser coils underneath. Clean as necessary. Feel of the compressor CAREFUL if its HOT to the touch and hasn't been cooling listen to it for the 10 to 20 minutes your talking about. If its precisely 15 minutes on then off and the fan motor under by the compressor starts and stops at the same time your controller (thermostat or sensor/board assy.) is not sending power on to the compressor - replace as necessary. If your fans keeps running under neath the compressor is not working correctly. here is what to do to check it.
The fan staying on underneath is the tattle tell. If its not running something else is turning off and on the compressor (they run together normally) and fan motor look to the controller.
If the fan stays on it means (usually) the compressor should be running also. So the controllers are at least telling it to run. If the fan isn't up to speed or the coil is blocked with dust and lint/dirt this can cause (in some setups) both fan and compressor to overload from heat.
Assuming you have voltage to the compressor and the coils are clean and the fan motor under is working up to par, The compressor or its start components are at fault. Here is what to look for:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Getting to this step: Either your compressor is broken inside or the start components are not working properly. Ohm the compressor terminals to ground and across to each other.
If any read anything to ground the compressor is bad.
Your readings between the compressor terminals should all be different and you should have 1 low 1 medium and 1 high resistance reading.
Add the low and mid reading together and the sum should be close to the highest reading. If it reads say 20% more or less then retest it a couple of times to confirm your not slipping on the terminals.
Assuming the above checks out: Get a new Start relay (start capacitor if so equipped) relay and overload (and capacitor if it has one) In other words everything that is external and attached to the wires or terminals on the compressor, and replace them on to the compressor. Then if it starts problem solved if it still does same thing the compressor is bad (broken mechanically inside the compressor) and you have to decide to replace compressor or replace the refrigerating compressor be it AC or Refrigeration.
A few times I have gotten a compressor to start after leaving it off for 6 to 12 hours then retrying it. See the compressor unless left off for 6 to 12 hours and sometimes as long as 24 hours Is tight due to linear expansion from heat. And about 1/2 the time it is ok after new start components are installed. The other 1/2 the compressor will be ok for a day or 2 then stop again. Most likely from a “hard spot” in the movement of the internal parts in the compressor.
30 years of doing refrigeration and this has not changed.
Please rate me as high as you can and ask me to clarify anything you don’t understand.
Jan 18, 2006 | Hoover HCA331FFK
VinoTemp VT-52SN Stainless Steel Wine Cooler Logo
156 people viewed this question
Top VinoTemp Refrigerators Experts
Vernon Taylor
Ilia Bichin
Are you a VinoTemp Refrigerator Expert? Answer questions, earn points and help others
