My Walkman doesn't connect properly with my computer (or with any other computer, if that matter). I normally connect it with the UDB cable given with the product, and initially it worked, I even loaded some songs, deleted them, it worked fine. Then one day it didn't connect anymore. I can't find it in File Manager, I tried anything I know, but can't get a hold of this problem. what should I do?
How to connect400w ate power supply to cpu
Simple change. Just turn the computer off, remove the power cord, open the case. There are 4 screws that hold the power supply in place that you will have to remove then you can remove it. What where the cables are connected to the motherboard from the old power supply because you want to connect the cables from the new power supply in the same place.
Normally there will be two cables that plug into the motherboard and they will only fit in the correct place on the board. There will be a number of cables for the hard drive and dvd drive and it doesn't matter which one you use.
Jun 06, 2012 | Dell Computers & Internet
Sony walkman nwz-b135 when i connect it to my laptop it will add music etc, but will not charge thanx
I'm sorry to know that the Walkman player is not getting charged. I'll be glad to assist you with this. Please perform the following steps:
If the New Hardware Wizard appears and is prompting for a location of the driver, point to the following directory: C:/WINDOWS/INF .
To function properly, your Walkman player must be recognized by your computer as a Media Transfer Protocol (MTP) device. If the portable player was connected to the computer before the Windows Media Player version 10 or later was installed, it will be recognized as a Mass Storage Class (MSC) device and not function properly. In that case, a different procedure is available to correct this issue.
For some models, when you use the portable player for the first time, if you have not used it for a long time, or the battery is depleted, it may take up to 5 minutes for it to be recognized or start charging. On models with a display, the display will remain blank. If it the portable player is not recognized or does not begin to charge after waiting 5 minutes, reset the player by pressing the reset button.
If this is not the first time using your player and it was working properly at one time with no major changes performed (such as restoring the operating system or replacing a hard drive), follow the procedure below:
Connect the portable player to the computer using the supplied USB cable.
Disconnect the USB cable from the portable player and then reconnect.
Check the connection status again.
Disconnect the USB cable from the computer and then reconnect.
Check for available space on the player using Windows Media Player or My Computer .
Restart the computer.
Check that the USB cable is firmly connected to both the computer and the player.
If the player is connected to a USB hub, disconnect it and connect it directly to the computer with a dedicated USB cable.
If the player is still not recognized by the computer, disconnect all devices connected to the computer with a USB connection and restart the computer.
After the computer restarts, connect only the Walkman player and test the connection again.
If the player is still not recognized by the computer, try a different USB port.
Under the Common settings menu of the player, format the player using the built-in Format utility.
Verify the current Operating System. If it is an upgraded operating system, contact the computer manufacturer for updated drivers for their upgraded operating system.
If you are running the Windows XP operating system, be sure you are running Service Pack 2 (SP2) or later.
If you did not have the latest service pack, test the connection status again after it has been installed.
If you are still unable to transfer music to your player and have not yet uninstalled and reinstalled the driver follow the procedure to confirm that the player is recognized by the computer as an MTP device.
Thanks for contacting FixYa.
Aug 08, 2011 | Sony Walkman NWZ-B135 MP3 Player
How To Reset Canon MP276 Error p08 Experts.
Turn the printer is the printer on. And remove the USB printer cable from your computer ..
While the printer is off, press and hold the Start / Stop in the canon of some other models of printers, press the Resume / Cancel.
While holding Start / Stop or Resume / Cancel button, press and hold the POWER button.
When the Power LED (green) lit, release the Start / Stop / resume / cancel button (without releasing the button).
Without releasing the power button, press Start or resume the Stop button or cancel button twice, then release the POWER button. Wait until the printer LCD display 0 (zero) the number of
After the screen is 0, connect the printer cable UDB to your computer, will detect the new device installed (normal), will now restore steps
solution taken from:blogspot
May 26, 2011 | Computers & Internet
When i'm going to connect it does't show the music files and also i can't charge my walkman.and also can't copy the songs from walkman.
The Computer will not recognize the Walkman when connected, if it is not having enough charge. You can try connecting the Walkman Player to the working USB port on the Computer for 2 hours and check if the player is getting charged. I suggest that you also perform the steps mention on the article given here. Click here to view the steps to troubleshoot the issue. This should resolve the issue.
Thanks for using FixYa.
May 07, 2011 | Sony Walkman NWZ-W202 MP3 Player
When i conneted my player with computer then i
1.Try resetting the Walkman by pressing the RESET button located on it. It looks like a small hole. You can use any pin or any sharp pointed object to reset it.
Then connect back the Walkman to check whether it works.
2. Use the supplied USB cable to connect the Walkman to the Computer.
3. Disconnect all other USB devices if you have connected to avoid conflict.
4.Connect the Walkman to the other USB ports on the Computer.
5.Check whether the USB Driver is installed in the Computer or if it is corrupted.
You can check whether the USB Driver is corrupted or not by following steps below(only for Windows Operating System).
Right-click on MyComputer icon and select "Manage".
Then, select Device Manager at the left plane.
Then check whether any "Unknown device" or "?" or "!" is listed under Universal Serial Bus Controllers at the bottom of the right pane.
If there is so, then right-click on it and select uninstall.
This will un-install the USB Driver.
Then, un-plugg the USB cable and plug-it in.
Now, the Walkman should be recognized as a removable device in My Computer.
If the issue persists, then connect the Walkman to a different Computer to check whether the issue is with the Computer or the Walkman.
If the issue persists even with different Computer,
If the issue persists you may try using a different compatible USB cable.
Jul 27, 2010 | Sony Walkman NWZ-B142 MP3 Player
My Walkman.. is Loading forever and cannot open
Jul 22, 2010 | Sony NWZB133F MP3 Player
Frozen and won't connect to computer
1. Use the supplied USB cable to connect the Walkman to the Computer.
2. Disconnect all other USB devices if you have connected to avoid conflict.
3.Connect the Walkman to the other USB ports on the Computer.
4.Check whether the USB Driver is installed in the Computer or if it is corrupted.
If the issue persists even with different Computer, then try resetting the Walkman by pressing the RESET button located at its bottom. You can use any pin or any sharp pointed object to reset it.
Jul 21, 2010 | Sony Walkman NWZ-S616F MP3 Player
My mp3 player will not conect to my computer i have done it once and it now want let me conect
Sony NWZB135F not reconized by computer
Hi!
No drivers are required to connect the Walkman to a Computer. Please make sure that the USB ports to which the Walkman is being connected is properly functioning. Next, press and hold the Reset button on the Walkman for 30 seconds.
Then, connect the Walkman to the Computer and check if it's being recognized. If not then open Device Manager window then check if there is any exclamation mark visible under any category specifially under "portable devices" or "Disk drives" category. If there is any exclamation mark visible beside any devices under any category, please right click on it and click Uninstall. After uninstalling all the devices with exclamation mark, please restart the Computer. After restarting the Computer with the Walkman should be recognized by the Computer.
Please follow the steps given below to open device manager:
Please press the Windows logo on the Keyboard and then press the "R" key while holding down the Windows logo key to open the Run dialog box. Then, please type "devmgmt.msc" in the Run dialog box and click OK to open the Device Manager window.
Performing all the above steps should make the Walkman work with the Computer.
Aug 23, 2009 | Sony NWZB135F MP3 Player
Can't connect to computer with NWZ-A816 Sony walkman.
I figured it out!
It used to be that when I plugged my walkman into my PC, the screen would read "connecting" but would never actually connect, so I couldn't add/remove songs from the walkman or even recharge it. The solution is easy. Plug your walkman into your PC, and then go to
Control Panel --> Device Manager --> Portable Devices --> Walkman
If you have the same problem as me, the Walkman icon will appear with a yellow exclaimation mark, signifying a problem. Just right click the icon, and selecte "Uninstall". After that, the driver will be removed from the PC. Now, unplug your walkman from the PC, and then re-plug it in, and the driver on the Walkman will automatically upload to the PC, and everything should be back to normal and the Walkman should work perfectly.
The problem is that the Walkman driver in the registry was partially damaged somehow (I think during a registry clean up I did earlier). Just uninstall it, reinstall it by plugging in your walkman to the PC, and voila. Let me know how it works for y'all!
Mike
Mar 25, 2009 | Sony NW-E002BC Walkman MP3 Player
73 people viewed this question
 Grubhead
Grubhead
