Question about Sennheiser Hdr 40 Hdr40 Wireless Headphones
Hi can I use a hard wire only to connect my HDR-40 headphones?
Sennheiser HDR 130 with TR 130 transmitter not working.
If you twist the earpiece,one of them has two NIMH AAA batteries ,worth checking out if these are gone ,which is what happened to me.I was about to bin my rs130's and just stuck two new rechargeables and the earphones are working again!!!!!
As for $20 dollars from sennheiser for replacements!?!?!?
You should pick up two NIMH batteries for a couple of bucks on ebay or amazon.DO NOT USE ORDINARY BATTERIES!!!!!
Feb 09, 2012 | Sennheiser HDR 130 Consumer Headphones
HDR 120 PHONES. Sound on right phone has dissapeared but right phone is ok. Batteries have been checked and are fully charged. Any suggestions. I have checked all the connections and all look solid on both...
Hi, What test did you preform to know the right phone is OK? Connections can look solid to the naked eye but not be the case. What are you using to test these phones? Make sure the the plug you are plugging your jack into is functioning properly so you know you will get a proper test of the phones themselves. With the phones on your ears and plugged in and music playing can you wiggle any of the wires or connections and hear any crackling? This will give you a good starting point to address. Good luck.
Mar 06, 2011 | Sennheiser HDR 120 Consumer Headphones
Headphones not working
Check the plug - see if any wires have been severed. Also, measure the contacts for 8 to 16 ohms impedance. If you don't get a reading then the headphone speakers are shot.
Oct 28, 2010 | Sennheiser HDR 130 Consumer Headphones
Sounf come thru the right side but is silent in the left headphone
Hi,why sounds comes out from one side and the other side silentis because,the wire inside the speaker has cut and it needs to be soldered back with a soldering iron and a lead.
Sometimes it might also be from the speaker itself if it is damaged.
When you solder back the place that has cut,problem solved.
Thanks for using fixya....
Oct 20, 2010 | Sennheiser HDR 120 Consumer Headphones
My sennheiser hdr 130 has no sound even though it has lights on its based and it is connected to my t.v. what is the cause of this problem and the solution?
This worked for me (this solution was posted on another thread). Unplug the base and take out the headset batteries. Wait 30 seconds. Reconnect. Turn on head set. I could hear immediately!
Jun 13, 2010 | Sennheiser HDR 130 Consumer Headphones
Sennheiser hdr 120 headphones no longer hold a charge. where are the batteries in the headset?
Twist the pad counterclockwise on the left earpice. You'll find the batteries underneath.
Dec 27, 2009 | Sennheiser HDR 120 Consumer Headphones
Bad battery for my Sennheiser HDR 45 headphone
A replacement battery can be purchased from Sennheiser for $20.00.
Battery is: BA 151
Sennheiser Link:
http://www.sennheiserusa.com/newsite/productdetail.asp?transid=004146
Dec 24, 2008 | Sennheiser HDR-45 Consumer Headphones
Sennheiser Hdr 40 Hdr40 Wireless Headphones Logo
32 people viewed this question
Top Sennheiser Audio Players & Recorders Experts
Vito Vacirca Jr.
Gerhardus Stroebel
Are you a Sennheiser Audio Player and Recorder Expert? Answer questions, earn points and help others
