Question about Frigidaire Affinity ATF7000E Front Load Washer
Atf7000eso door lock mechanism not engaging
  • Official Brand Answer
  • 4,342 Answers
Hi Linda, I understand that the washer door will not lock.
First check to ensure that the loading door is closed completely. If you have
already double-checked the door closure, check the door strike. More commonly,
the door strike can become bent or misaligned over time and may interfere with
the connection. If not clear to the naked eye, you can determine if the door
strike is good by listening for the lock to attempt to close. If it sounds like
that, then it could possibly be the door switch or door lock assembly
altogether. Worst case scenario could be that the problem lies with the main
control panel. If you have checked the door and the door strike, and both
appear to be in working order, you may want to connect with a qualified
servicer to diagnose the exact problem. Parts can be costly so having an
accurate diagnosis is always the best bet.
Posted on Jul 30, 2013
How do I get the external passenger door handle to engage the mechanism to open the door.
May be a control rod has dropped off. Remove the inner door handle and the inner cover , wind up the window . remove the plastic dust seal, you will now be able to inspect the door lock.
Apr 28, 2015 | Cars & Trucks
Hoover nextra washing machine door wont lock / cycle start
sounds like the door lock mechanism. if this cannot signal it has engaged, to the board, no other function will work (you don't want the washer going with the door open, trust me :) )
Nov 08, 2013 | Hoover Nextra 160 HNWF 3137 Front Load...
Power door lock does not engage lock works manually
Try wiggling the electrical harness between the door and body of the truck with the door open and switch engaged.
Aug 07, 2012 | 1995 Chevrolet Tahoe
Automatic door locks
is i lockingt after you start it... and does it relese when turn off
May 21, 2012 | 1999 Volkswagen Passat
My atf7000eso starts then stops over and over.
The door lock is bad, remove the spring on the boot to gain access it easy to fix.
Apr 11, 2011 | Frigidaire Washing Machines
2002 Lincoln LS Rear door latch does not open have tha panel off tried opening manually mechanism moves but unable to open a child was playing with door lock can you help me to get the door open, would it...
I think the child safety lock is engaged. Look in your owner manual how to disengage. It is near the latch on the edge of the door. Look for the yellow label.
rotate counterclockwise to disengage child lock.
Feb 23, 2010 | 2002 Lincoln LS
1992 Subaru Liberty wagon - cannot lock front passenger door.
Check the alignment with the door pin. Might be out of adjustment and will not let the door close all the way. That will cause the lock to not be operable. Good luck and have a great day.
Jan 14, 2010 | 1992 Subaru Legacy
Frigidaire Affinity ATF7000E Front Load Washer Logo
51 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
