Question about Echo Rapid Loader, Trimmer Head
Echo trimmer stalls when i stop pulling the trigger
    New Friend:
  • 19 Answers
Retune the jets on the carb or reset the idle
Posted on Nov 06, 2013
4 Suggested Answers
  • 81 Answers
SOURCE: idles but will not stay running
This is nearly always caused by the muffler and muffler port being blocked by carbon not allowing the air to flow properly. Take the muffler off and see if this makes a difference. If so, then burn the carbon out of the muffler with a torch or throw it in an outside fire for awhile. Let it cool on it's own, do not use water as you will warp it and not get a good fit. Also take a knife and scrape the carbon out of the muffler port on the engine. Should solve your problem.
Posted on Jun 24, 2009
Dolfoff
  • 148 Answers
SOURCE: need to install new lever trigger lockout but
Navigate to your exact model using Echo's public website.
Click the "WEB-PLUS PARTSEARCH" link at the bottom right of their homepage.
Posted on Sep 26, 2009
2strokeJim
  • 577 Answers
SOURCE: The starter string does not retract after being
spring probably broke for recoil,will have to pull the 4 screws holding it on and and pull recoil off
you might get lucky as you loosen the bolts it might retract, if it does it is dirty inside and possible nylon guides wore causing it to bind. otherwise spring prob broke inside
Posted on Apr 06, 2011
Why does my Echo trimmer stalls when in run position
Carb adjustment. Start with one full turn on both low and high side, then set the idle.
Sep 03, 2014 | Echo Garden
Engine stall when trigger is pulled
Could be a number of things is it a 2 stroke if so sometimes the muffler gets plugged with unburnt oil and gunk. Remove muffler and use a propane torch to burn the gunk out and reinstall. Also if problem is not fixed might not be getting enough fuel take carb apart and clean with carb clean and use a piece of tag wire to clean tiny passages. hope this helps
Nov 07, 2013 | Poulan 12" Electric Twist N Edge Plus...
How to tune a walbro diaphagm carburetor
ok first set you low side to idle once you have that set . set you high side while pulling in on the trigger once you reach your desired setting your done .. note you will have to try this several times
Mar 01, 2013 | Echo Garden
My srm 230 starts but bogs down when you pull trigger. I put a new carb on and it ran for a few days then it started bogging. Any tips?
Same issue with mine... I've put in new plug, fuel filter, made sure exhaust was clear. Changed gas.
Apr 01, 2010 | Echo Garden
Need to install new lever trigger lockout but can't figure out how to install spring on echo trimmer srm 210
Sep 17, 2009 | Echo Garden
Echo gt 200r trimmer not spinning
there is a cable inside the tubing shaft you must separate engine from tube to access
Jul 17, 2009 | ECHO, Inc. PB-251C Handheld Blower
Idles but will not stay running
Jun 24, 2009 | Echo Rapid Loader, Trimmer Head
Echo Rapid Loader, Trimmer Head Logo
122 people viewed this question
Top Echo Garden Experts
Jim Parker
Jim Parker
colesmowers
Phil Walker
Phil Walker
Are you an Echo Garden Expert? Answer questions, earn points and help others
