Question about Braun 8585 Electric Shaver
Braun activator 8585 change the foil - Braun 8585 Electric Shaver
  • 4 Answers
Braun series 5 combi 51S outer foil and cutter replacement pack (Formerly 8000 360 Complete Or Activator) for men electric shaver braun 8585 replacement parts.
braun activator 8585 change the foil - 46d2e745-0475-43b6-91fd-5ed9b5560420.jpg
Posted on Aug 23, 2013
2 Suggested Answers
brector3
  • 1610 Answers
SOURCE: My Braun shaver 8585 has died. Foil, cable, box,
If I understand correctly, the shaver is dead but all other components are in good condition. If this is the case, you should consider ordering a replacement lower unit. See shaveroutlet.com link below
http://shaveroutlet.com/braun-8585-activator-lower-unit-p-364.html
Newer models made by Braun do not use all the same parts as your shaver so this would be a good way to go
Posted on Aug 23, 2010
I have had a Braun 8985 electric shaver for 4 years now. I have recently replaced the cutter block and foil but I am still having a problem with the shaver. It is not unusual for me to have to make 3 or...
The symptoms you describe indicate that the 'drive unit' is the problem. This part includes the swivel frame that the foils and cutters fit onto as well as the motor. Sometimes a piece of the plastic oscillator inside will break. The vibration causes the loud noise and it can not oscillate properly because of the break.
You will find the part needed at shaveroutlet.com. See link below for this part and scroll down the screen for helpful installation video
http://shaveroutlet.com/shaver-replacement-parts/braun-8000-series-activator-motor-drive-unit-p-36.html
Jul 27, 2011 | Braun 8585 Electric Shaver
Shaver is getting very loud
Most likely, the swivel frame that the foil snaps onto has a broken piece(s) of plastic inside making a buzzing sound. If this is the case, you will need to replace the drive unit. You will find this part for model 8585 at shaveroutlet.com. See link below
Disassembly video can also be found at shaveroutlet.com. See link below
http://www.shaveroutlet.com/braun_syncro_shaver_disassembly
Jan 07, 2011 | Braun 8585 Electric Shaver
I dropped my 8985 braun and it will no longer shave with the foil head on. It does work if you remove the foil. Did I loose a part?
You probably dented the foil head enough to stop the vibratory action of the blades, thus the working when the foil is removed. Braun has a replacement foil and blade kit sold at Walmart.
Dec 04, 2010 | Braun 8585 Electric Shaver
My Braun shaver 8585 has died. Foil, cable, box, Clean and charge unit as new. Which Braun shaver replaces Braun 8585 and can utilise good pieces?
Aug 23, 2010 | Braun 360° Complete 8985 Electric Shaver
Making a funny noise and not shaving well
8585 shaver gave higher tone and stopped cutting especially after a few days growth, even with new cutter and foil. Cutter wasn't pressing against the foil properly due to a bit of wear on the spring clip holding the cutter pin. Fixed with about 1cm of cigarette paper moistened and rolled into a 1-2mm ball. Stuffed that into cutter pin hole and rammed home with the cutter pin. Take the foil off and wiggle the cutter - if its feels loose, this might help, though the battery might just be getting old.
Jul 10, 2010 | Braun 8585 Electric Shaver
Hello, I have a Braun 8585 model and drop it is there any shop to send to fix it. please respond
Please call this number they can help you.please vote Contact information Procter & Gamble
Phone: 1-800-BRAUN-11 (1-800-272-8611)
Nov 02, 2009 | Braun Activator 8585 Electric Shaver
BRAUN 8595 screen indicates i should change my foil and block
there is a reset button directly underneath the LCD screen
Dec 02, 2008 | Braun Activator 8595 Electric Shaver
Braun 8585 series
I found that the hole that the blade slots into had become worn and the blade was wobbling about too much under the foil. To solve it I wrap a small piece of masking tape around the metal shaft that slots into the hole and then push the blade back firmly into the slot. This seems to result in the blade pushing more firmly against the underside of the foil and giving a shave like new again.
Oct 10, 2008 | Braun 8585 Electric Shaver
Braun 8585 Electric Shaver Logo
93 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
