Question about Bosch Washing Machines
Hi, No manual came with my machine and I've had it now for two years. Just recently when a wash is put on a light appears that looks like a basket overflowing with suds, and at the end of the cycle the machine will not empty the water out. I do not know what this light means as we have no manual. Any information would be great??? :)
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Bosch Master
  • 102,366 Answers
What model Bosch washing machine?
Posted on Jul 30, 2013
Washer_tech
  • 164 Answers
SOURCE: Maytag Washing Machine - water will not shut off and overflows tub
this could be either a bad pressure switch, located behind the control panel. it has a small usually black hose running down to the tub. more than likely since this is an older machine the hose has become worn in one spot and is leaking air. replace the hose and that shold do it. if not its the presasure switch.
Posted on Nov 29, 2007
SOURCE: GE Front Loading Washing Machine seems to be holding water....
manual
Posted on Mar 21, 2008
jsrock516
  • 5911 Answers
SOURCE: Spin Cycle on Wash Machine does not work
The problem is your lid switch. This is a common problem with this model washer, and a very simple & inexpensive problem to fix. Click on the following link for advice on how to replace:
http://www.fixya.com/support/r385198-replacing_lid_switch
You can find a replacment switch at searspartsdirect.com. Just type in your model number and look under the "Cabinet Parts" heading on the next page. I believe thats the heading the part is listed under. Sears has excellent part locator drawings to assist you in identifying the part. Once you have the part number identified, you can do some comparative shopping at other online websites too. Use the part number that Sears provides, however. A new switch usually runs about $25 to $35. In addition, make sure you check the lid strike. This is a small plastic piece on the lid that is used to activate the lid switch through a small slot. If the lid strike is broken off, it will give the same symptoms of a defective lid switch. I hope this information helps you. Please post back if you have any questions.
Posted on Aug 04, 2008
jsrock516
  • 5911 Answers
SOURCE: Whirlpool Ultimate Care II Quiet Wash - Wash Cycle not holding water
Since your washer worked fine while in Germany and now is exhibiting this problem at your new home, you may want to double check how it was installed. I suspect you may have a problem known as "siphoning". The following link explains:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
This could be a simple situation where the drain line on the washer is not installed correctly. There are minimum height and length requirments on the drain line. In addition, make sure the stand pipe you have the drain hose inserted in has a proper air gap to allow draining. All of this is explained in the link provided.
I hope this information is helpful to you. The majority of the situations arise from improper installation and is not an operaitonal problem with the washer. If, however, you double check everything and still have problems, please post back and let me know.
Posted on Sep 11, 2008
  • 135 Answers
SOURCE: Hi, I have a Candy
Check filter behind kick plate on bottom front of machine. Drain water out first by lowering drain hose into bowl or bucket.
Plz come back if further help required.
Posted on Dec 02, 2008
Not cleaning upper rack
check that the upper basket is the correct one for the unit. some one may have just put in a basket to sell it
Jun 01, 2013 | Asko Dishwashers
Samsung WF7700N6W1 washing machine not draining
Could be a sock or something between the 2 drums that moves over the outlet hole from the drum when upright and trying to drain but moves away when machine is on its side. Get a flashlight and look through the holes in the inner drum and you may find the culprit.
A coin may also be stuck in by the pump blade, not always easy to see but worth a look.
Dec 22, 2012 | Samsung Washing Machines
Zanussi FLE1216w Repair Manual
Hi, my zanussi fle1216w is skipping the fabric softener stage of the cycle. I've cleaned the dispensing drawer and the surrounding areas, even put on a boil wash in case somethihg was gunge up or visits the Zanussi Owners Manual.
Mar 22, 2012 | Washing Machines
I have a Maytag Bravos washing machine that has just recently become really noisy when it goes into high speed spin. I have lifted the cover and found no items or debris. When I spin the tub by hand it...
Hi.
F51 is motor position sensor error. From manual:
F51: Motor RPS Failure
F then 51 flashes when there is a motor rotor position sensor (RPS) failure or lower harness problem.
The motor position sensor failure may be the result of a problem between basket and motor.The parts below the basket must be inspected. There is need to remove the basket to check parts in there. I can give you the procedure to remove the basket if you want.
Aug 20, 2011 | Maytag Bravos MTW6600T Top Load Washer
Hi , my washing machine recently started not spinnig as good as it use to. The clothes are still soaked. I heard it could be the coupler, but turned it upsidedown and looke at it myself and it looked fine....
Probably your transmission starting to go out.  Check to see is there is a ring of oil around your casing, or oil leaking out under the machine.  If there is replace the transmission.  Check to see how easy it is to rotate the basket.  Sometimes things get stuck between the tub and the basket.
Nov 13, 2009 | Kenmore 24032\24036 Top Load Washer
Dirt around the rubber insert!!
Your washing machine probably just has a build up of dirt in the basket. When you look inside the basket you see all those holes that are all over it. Dirt will stick inside there and after time will start coming out during washes. A simple thing that you can do to fix this is run some vinegar through the wash. Pour it in the basket, the soap, fabric softener, and bleach dispensers. Wash on hot and extra large load. Make sure no clothes are in it of course. This is something you can do every few months or so. Not only will it clean out the machine but it will clean out all the hoses and any hard water deposits. Your clothes will start smelling better and looking cleaner. Give that a try though. If your machine is 8 years old chances are this is the problem. Let me know if you have any other questions and let me know if this is helpful to you. Good luck and I am always happy to help out.
Jan 22, 2009 | Frigidaire ATF6000ES Front Load Washer
Leaks under pressure
Hi
Your brew head gasket is leaking and needs to be replaced. remove everything and turn the machine on its top. Look ate the brew head inside there is a black gasket and it should be clean and flat. If its cut or curled it needs to be replaced. Not cleaning the brew head will cause this gasket to be cut and after a while it will curl and not seal.
Mar 02, 2008 | Solis Crema SL-90 Espresso Machine
Frigidaire FTF530FS Front Load washer
Take off the lower panel. Inspect the shocks too see if they are damaged. If they are OK turn the wash basket by hand if the knock is heard then most likely you have a broken wash basket.
Jan 13, 2008 | Frigidaire FTF530FS Front Load Washer
Wasing machine leaves rust spots on clothes.
check the basket of the machine for rust spots on the basket if thats the case the basket should have a 10 year warranty depending on the age marks are either caused from that or the dryer. if its frigidaire the dryer then the front seals probably need to be changed make sure to find out exactly which machine its coming from
Mar 18, 2007 | Kenmore 22422 Top Load Washer
Washing Machines Logo
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
