Question about Android Apps
Had a leak from my thermostat fixed that but now i have a squeeling noise coming from the right side under the hood what could this be
    Problem Solver:
  • 17 Answers
Coolant got on your belts. clean with belt dressing or replace belts
Posted on Mar 10, 2014
2011 Kia Sorento 2.5 - whining when the car is first started.
Squeel = drive belt, whine check drive belt pullys. Still under waranty?
Jun 28, 2012 | 2011 Kia Sorento
STEAM COMING OFF ENGINE
check top radiator hose goes to thermostat housing sound like its leaking if your engine leaking from left driver side on top of engine it has to be top radiator thermostat hose leaking.wait until engine cool down replace top radiator hose see if coolant leaking still occur if so you could have radiator leak.
Dec 09, 2011 | 2002 Buick LeSabre
Power steering went out while I was driving (exiting freeway and braking) fluid seems to be leaking but the measurement stick for the power steering fluid is full). Where do I go with this an d what am I...
check the tension of the belt driving the power steering pump if not real tight it needs replaced turn wheel all way to left then to right listen for a squeeling noise if squeels then you need new power steering pump
Sep 12, 2010 | 2001 Dodge Ram 1500 Truck 2WD
2000 Mitsubishi Galant 4 cyl ES underhood squeal on right side
Be gentle with my rating. I am a long ways away. It sounds like a fan belt. You should pop the hood next time and see how it sounds when you have the squeeling going on. Fan belts will squeel until the get warmed up and then stop because the heat makes them grab the way they are ment too. Let me know, Raz
Apr 19, 2010 | 2000 Mitsubishi Galant
I may need to replace the front wheel bearing. There is a squeeling sound coming from the front right side of the car.
Normally a squeeling noise coming from the front wheel area would be the front brake disk pads getting too low. Normally when wheel bearings start to fail the noise they produce is more consistant which a growl noise.
Jul 08, 2009 | 1993 Mitsubishi Mighty Max
Squeeling coming from under right side of hood of car have had pulley,belt and tensioner replaced noise is still.
alternator bearings may be bad...who's the dummy doing all the other work and shoving it out the door unrepaired?
Good Luck
Jun 15, 2009 | 2000 Pontiac Grand Am GT
I have a periodic squeeling noise comming from under the hood and i've noticed that the fan /pully system jumps or bucks on occasion - is that a sign that my water pump is going?
No, a sign your water pump is going would be your water pump springing a leak through the weep hole, or your engine start to run hot, fast (but that can also be caused by a thermostat, a bad sensor, or blown head-gasket).
Likely-hood is your belt simply need to be replaced, take off the accessory belt and bend it backwards, if you see deep cracks or threads the belt is bad, if you don't then it could be your tensioner pulley going out.
Aug 05, 2008 | 2000 GMC Jimmy
Android Apps Logo
604 people viewed this question
Top Apps Experts
Are you an App Expert? Answer questions, earn points and help others
