Question about Microwave Ovens
Oven aftron sparking inoven
    Top Expert:
  • Microwave Ovens Master
  • 12,223 Answers
Follow this steps and fix it. God bless you
  1. Waveguide coverSparking and arcing in a microwave can be caused by a damaged waveguide cover. Try removing the waveguide cover to see if the problem persists. Once removed, the waveguide cover can be inspected for burns, which will indicate if this is the issue. If the waveguide cover is burnt or will not stay in the proper spot it will need to be replaced.
  2. Cavity/Rack supportIf sparking or arcing in your microwave is near a rack support, any exposed metallic area can be covered with a microwave cavity support. It is also recommended to replace the rack supports in this situation to ensure the issue is resolved.
  3. Cavity paintIf sparking or arcing in the microwave is visible on the side walls, the paint covering the metallic areas could have worn off or chipped. This can possibly cause pitting in the side walls or ceiling. If this is the case, it can be repaired with microwave cavity paint.
Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#10#ixzz2aaus0Uj3
Posted on Jul 31, 2013
Aftron tv manual control is not working and coming some lines on the screen
che the display board or control unit ther wise replace control unit
Jan 28, 2014 | Microwave Ovens
Manual control button is not working of aftron tv
replace manual control button or control unit
My aftron lcd have problem with screen it opens for seconds and become black screen even i choose source like AV,TV,VGA it doesn't work what can i do pls
Do you have a device inputting into the port you are selecting ?
Try connecting the VGA port on TV to your PC's out put where the monitor connects, Boot the PC after selecting VGA as the input on the TV. Your PC's desktop should be displayed on the TV's screen
Oct 16, 2013 | Sharp R-510HW Microwave Oven
Sparking in microwave (aftron make)
test this steps and fix it. God bless you
Jul 30, 2013 | Microwave Ovens
MY AFTRON TV AFLCD3255PTFHD TO BE REPAIRED IN COCHIN OR NEAR BY
Hello - Are you having an issue with an over the range microwave? What exactly is the problem you are experiencing? With this information I can assist you further with the issue the unit is having.
Oct 27, 2012 | Frigidaire FMV145K Microwave Oven
My Goldstar MV-1310W microwave has sparks flying from the metal plate that's inside on the top.
Microwave ovens do not work well with exposed metal. IF you place uncoated metal in the oven, sparks will occur.
IF the interior of the oven has the metal exposed, it will cause sparking to occur.
There must be NO exposed metal inside a Microwave oven!
Aug 15, 2011 | Goldstar MV-1310W/B Microwave Oven
Need aftron lcd tv manual
my aftron tv has been locked by mistack.it is showing the locked symbol only.please help me
Dec 19, 2009 | Sharp R-510HW Microwave Oven
MICROWAVE NOT HEATING ANYTHING?
If it is working but not heating, then test the high voltage capacitor,the rectifier diode.or the magnetron. If all this are fine, test the control board.
The diodeand capacitors can be tested. The capacitor must be allowed discharge before testing, or you risk to get electrocuted, evenif power is off.Capacitors can get discharged by shorting their two contacts.
Before replacing the magnetron test also the control board.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts.
You can also order from MicrowaveSvc , they also provide parts.
Dec 29, 2008 | Frigidaire FMV145K Microwave Oven
Light and turntable will not work
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa.
Feel free to contact me directly (and please remind me of your full model number KOT172S) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Nov 29, 2008 | Dacor DMT2420 1200 Watts Microwave Oven
Microwave Ovens Logo
99 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
