Question about Ricoh Aficio 2015 Copier
My ricoh aficio sp 100su only installs in a foreign language that looks like chinese
  • 86 Answers
SOURCE: driver for Ricoh Aficio SP-C210SF
Please browse the link below;
http://www.ricoh-support.com/enduser/downloads/downloads.asp?fileid=11342&ricohmodelid=6317&url=http%3A%2F%2Fsupport%2Ericoh%2Ecom%2Fbb%2Fhtml%2Fdr%5Fut%5Fe%2Fre%2Fmodel%2Fspc210%2Fspc210en%2Ehtm
Good luck and please rate me, thanks.
Posted on Jan 29, 2009
SOURCE: page counter on RICOH aficio SP C811DN
Enter the menu of the printer pressing once the relevant button and with the up or down buttons find the list test print. Then press once # or OK (whatever the machine has) and you see Configuration page. By pressing once again the # or OK it prints the Config.Page, which somewhere on the top of thw sheet shows the pages printed (first the black and then the colour. Good luck!
Posted on Sep 09, 2009
Ickoajnc
  • 183 Answers
SOURCE: i have a ricoh aficio sp c420dn, when and turn on
You may try first to reset the SC 542 before calling a technician!
That you can do by following method:
1.Turn the machine off and then after 5 second turn it on while pressing the “On Line” key and “Escape” key together until “SYSTEMver x.xx/1. Service” shows on the display.
2.Use the “Up/Down arrow” keys to scroll through the menu listing.
3. Press the (OK) key while
on the display writes " 2. Engine " .
4.go to "[5810 001] - Fusing SC Reset" by scrolling the “Up/Down arrow” keys and press the [OK] key (on the display should write execute or done) press [OK] again if is needed to press it.
5. After this turn off and than after 5 second turn it on the machine.
Please do not change nothing else in this menu only reset the fusing unit SC code, because if you change some other values and settings you might to regret that and pay high price for that.
So only reset the Fuser SC code SC542 by the upper mentioned method and do nothing else, if the SC code appear again then do not try this again because you might burn some parts.
If this do not help than call the technician.
Please answer do this is helpful for i to know do the problem was solved.
Regards
Posted on Jan 13, 2010
FixinFax
  • 3085 Answers
SOURCE: Ricoh Aficio SP 232 DN
Call a Ricoh Technician to Reset the codes
Posted on May 30, 2010
bosegautam11
SOURCE: Ricoh Aficio SP C411dn error SC542
Ricoh Aficio error SC542
Posted on Sep 26, 2011
What does the error message C8 mean?
press the helpful button
found this on fixya by J Mcallister
Heating roller warm-up error 2
?? The heating roller temperature does not reach the ready
temperature for 90 seconds after the heating lamp on.
?? The heating roller temperature does not reach 80°C for 13 seconds
after the IH inverter on.
?? Defective thermistor
?? Defective IH inverter
Related SC code: SC 542
1. Check if the heating roller thermistor.
Ricoh Aficio SP 100SU User Manual Error And Status Indicate On The Control...
Jan 27, 2016 | Ricoh SP 112SU 3in1 Laser Printer
Ricoh aficio sp 100su has error code c6
SC101 c6 C CIS Lamp/Scanner Motor Error A problem occurred with the CIS or scanner motor in the flatbed scanner: -Carl
Nov 13, 2014 | Ricoh Aficio SP 100SU e Laser...
My new ricoh aficio sp 100su ddst printer has hardly printed 100 pages and now it show E7 and doesn't print. what must I do?
Go to page setting option and set page range and page auto print. If printer ok then may be E7 browser not full support so that up to date then you try.
Read More Help... Ricoh SP 100 Printer Need to press Form Feed button every time to print... and Ricoh Printer Support
Thanks,
Sep 10, 2014 | Office Equipment & Supplies
Show my printer on display C8 on Ricoh SP 100Su
Fusing Reload Temperature Error (Fatal Error)
Fusing thermistor deformed or out of position ? Fusing lamp harness loose, broken, defective ? Fusing unit defective ? After servicing the machine to solve the problem, the service technician must execute a "Fuser SC Reset". Otherwise, the machine will continue to issue this SC code and cannot be operated.- Carl
Aug 02, 2013 | Ricoh Aficio SP 100SU e Laser...
Error code c8
error c8 on lcd screen
Jul 15, 2013 | Ricoh Aficio SP 100SU e Laser...
How to solution of FUSER TEMP.
my rocoh printer SP 100su show on lcd panal C8 error code . power on .
May 17, 2012 | Ricoh Aficio Sp 1000sf All-In-One Laser...
Ricoh Aficio 2015 Copier Logo
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
