Question about Microsoft Windows 7 Ultimate for PC
Mouse cursor won't stop dragging. It keeps dragging itself downward, I already checked if the problem was with the drivers, I disabled it, it kept dragging, I disconnected it, with no mouse attached the cursor kept dragging itself downward to the bottom of the screen. I tried with a different mouse, after it installed the drivers, it started dragging downward again. I booted into Safe Mode, it kept doing the same thing, I did a System Restore, the problem persists, dunno what else to try.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 46 Answers
Check virus in your computer
Posted on Nov 13, 2013
Unstable, jittery cursor
Lets give this a try: Click the Start button> click Control Panel> click Hardware> and then click Mouse. Click the Pointer Options tab, and then do the following: Uncheck the Hide pointer while typing box. Hope this helps you. Let us know either way. Make it a great day!
Apr 30, 2012 | Compaq Computers & Internet
Touch pad not working
Did it work for you before? what has happened since then?some laptops have a way to disable the touch pad so you won't accidentally move the cursor while typing. It may be a switch on the computer itself, or a LED in the corner of the touch pad, or it may be one of the Function keys (does any of them have a symbol of a mouse with a circle and one diagonal line indicating "no mouse") If so, push the fn key plus which ever function key has that symbol beside it.Some laptops automatically disable the touch pad if a USB mouse is plugged in.If none of these is the problem, you may not have a touch pad driver installed. Get a USB mouse to plus in until you get the driver installed. Go to the web page for the manufacturer for the laptop. Search for your model in the support section, and look for drivers. Download the appropriate driver for your touch pad and your version of Windows, and install it.Buying a USB mouse or a wireless mouse may be a valid solution no matter what the problem is if you like a real mouse.
Mar 02, 2012 | Computers & Internet
The arrow on the mouse kepts junping around ?
You are probably using a laptop with a touchpad. What is happening is that your thumbs are touching the touch-pad as you type and the cursor is jumping around. Solution: disable your touch pad. You can go to Start > Control Panel > Mouse > Touch Pad > Disable
Another solution is to go to the Dell website > Support and Drivers > download and install the Synaptics Pointing Device driver and disable your touch pad using the options in this new driver.
Oct 15, 2010 | Dell U0636 Mouse
Automatically cursor jumps . When we type in the cursor automatically moves fromm one place to another
I presume you have a touchpad under your keyboard.
Usually the hand position when you type is such, that it's very easy to involuntarily lighlty touch the touchpad with the base of your thumb, usually the right one, when you move the hand over the touchpad, mostly in the up-left direction.
This causes the cursor to move to some other place, usually up and to the left, resulting in the next characters you type being put in that place :)
Try to keep your hands a little bit more above the touchpad when you type. Also, many touchpad drivers have settings for ignoring light touches/drags, try looking into these settings in your pointing device properties.
As an aid, I would recommend a soft gel wrist support, which automatically elevates your palms above the keyboard.
Nov 13, 2009 | IBM Lenovo ThinkPad T400 7417 Notebook
Mouse keeps shifting the cursor to a different place in document
On touchpads if you touch the pad twice in quick succession it acts as a click and the cursor will move to the mouse pointer location. In mouse settings disable "tapping"
Aug 31, 2009 | Acer Aspire 5720 Notebook
Mouse moves, click and drag by itself
That sounds a lot like someone has remote access to your computer. Try changing your Firewall settings or try to get a different IP address. Careful messing around with the IP though, it's easy to create a problem when doing that.
Jul 08, 2009 | Microsoft 2000 Wireless RF Optical Mouse
Wireless Optic Logitech mouse performace
I had the exact same problem with my original Logitech wireless mouse that came with a wireless keyboard. I eventually figured that the button component inside the mouse wasn't making consistent contact causing unintended double clicking or dropping while dragging. I fixed it by doing some soldering to switch the left mouse button with the right mouse button, since I didn't have to use double clicking or dragging with the right mouse button. It worked pretty well for several months until the switched left button started showing the same problem again. Now my newer Logitech mouse (it's more expensive Nano wireless mouse) is having the same problem after about 1 year using it. I think there's a serious durability problem with the button component that Logitech is putting on their mice. I may do the same trick again on this mouse, but now I don't consider Logitech as a good mouse manufacturer anymore. They used to make good quality hardwares but I guess they aren't that good anymore with all those cheap Chinese suppliers for their parts. :(
Apr 28, 2009 | Computers & Internet
Problem with my Mouse cursor
If it's an external mouse you are using with the slow dragging problem then it could be a problem with the mouse itself ,internal ,try to clean the pad with a moist cloth while laptop is off.
Also look in the mouse setting and change the pointer speed.
Also try a plain coloured mouse pad and not one with mixed colours.
Download the vga driver from here and reinstall it :
http://support.acer-euro.com/drivers/notebook/as_5520.html
Oct 30, 2008 | Acer Aspire 5520-5908 Notebook
Mouse cursor moving by itself
In windows xp go into start menu, then into control panel then click on appearance and themes, then move your mouse over to mouse pointers click on it , uncheck "enhance pointer precision, and click apply, that will stop the mouse from acting crazy, this will work with dell mouse pointers and most.
Dec 28, 2007 | Compaq EVO N600C (Refurbished) 14.1" LCD...
i have latitude c610 and same problem happens with me too. i think that happens when i finish my brakfat and without cleaning my hands start using the touch pad. what happens according to me is that small particles of food(eg bread/dust particles) stuck in the corners or the body wall where the touch pad ends and keeps pressing the touchpad, thus causing the mouse to move to one direction. when i clean the corners and sides of the touchpad, it starts working ok !!
thanks
Johal
Dec 12, 2007 | Dell Latitude C610 Notebook
Microsoft Windows 7 Ultimate for PC Logo
60 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
