Question about A.O. Smith SQ1102 Pool Pump Motor
A.O. Smith SQ1252 Where is the overload protector located
2 Suggested Answers
c17hydro
  • 2984 Answers
SOURCE: Where can I find a replace thermal overload protector?
http://www.mypool.com/Products/Catalog/mo.asp for the capacitor.
See if there is another part number for that breaker (CET51 ABM).
Posted on Mar 10, 2009
Overload protector
Try checking on sears . Consult your manual as well.
May 07, 2013 | Craftsman Sears Radial Arm Saw 10" Blade...
I am trying to find the thermal overlaod switch with no luck . Where is it exactly?
The motor has a manual reset thermal overload protector switch. If the motor overheats for any reason, the overload protector will shut off the motor. The motor must be allowed to cool down before resetting the overload switch and restarting. It is located on the motor housing on the side opposite where the pump and hose connections are. The reason this switch shuts off is because of low voltage problems caused by either a too low amp rating on the circuit it's plugged into or by using an extension cord. It is always safer and better for the motor to run longer air hoses than to use extension cords.
Jan 09, 2011 | Makita MAC700 2 HP Air Compressor (Hot...
My makita makair mac500 was running fine. then it just quit. i have emptied the tank to 0. It will not start. is it dead for good? thanks
Nov 18, 2010 | Makita MAC700 2 HP Air Compressor (Hot...
AO smith compressor motor missing toggle for duel voltage
Most motors will have a wiring diagram on them with numbers not colors, and show the wiring configurations for both voltages. If you do not have this then you may want to contact a motor shop and see if they can get it wired for you.
Nov 25, 2009 | AO Smith Air Tools & Compressors
Feb 28, 2009 | A.O. Smith SQ1102 Pool Pump Motor
Motor will not start
I had the same problem and the solution was to manually press the thermal overload button. The button is located under the tool box next the motor head. I do not believe I tripped the thermal overload during use, but I suppose anything is possible. I’ve been using the compressor in sub 40 deg F. temperatures. I found the following in the Owner’s Manual, but had to look at the part manual to locate the switch.
MOTOR THERMAL OVERLOAD
PROTECTOR: The electric motor
has a manual thermal overload
protector. If the motor overheats
for any reason, the thermal
the motor. Turn pressure switch
to the “off” position and wait for
unit to cool before pushing the
reset button and restarting the
compressor.
Good Luck!
Dec 14, 2008 | Makita MAC5200 Electric Powered Air...
Overload Protector
i guess you can ohm it out witha meter( exact specs idont know) can you hear it clicking on/off??, generally i remove it from compressor and if its faulty it shake and sound busted. might be bad compreesot that coaused that (which should be covered under 5 yr manu. warr) adnthat comes with new overload protector
Mar 01, 2008 | Kenmore 52642 / 52644 / 52649 Side by Side...
Hotpoint wma58
Could be a bad overload protector in the motor. Some machines have a circuit where the machine rapid advances to the end when the motor overload protector kicks in. This would also make sense that it started happening in the Spin cycle when the motor draws the highest voltage.
Feb 29, 2008 | Hotpoint WMA64 Front Load Washer
A.O. Smith SQ1102 Pool Pump Motor Logo
267 people viewed this question
Top A.O. Smith Plumbing Experts
Donni Steen
Tom Chichester
Are you an A.O. Smith Plumbing Expert? Answer questions, earn points and help others
