Question about HEWLETT-PACKARD HP G61-429WM Notebook
I Need to know how to reset the bios jumpers on a HP g61 notebook can anyone help ?
  • 3 Answers
This information is intended for experienced users. It is not intended for basic users, hackers, or computer thieves. Please do not try any of following procedures if you are not familiar with computer hardware. I'll not be responsible for the use or misuse of this information, including personal injury, loss of data or hardware damage. So use it at your own risk.
A. By Using the Motherboard Jumper:
In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
B. By Using Software:
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds
BIOS/CMOS Password Recovery Tool Service: http://www.biospasswordrecovery.com/
Posted on Jul 30, 2013
HP G61 no power
open *********** board battery some time or " mother board battery
inside 3pin jumper switch. open this jumper middle pin to other pin connect some time 1 minute & jumper set previous position.
or" see mother board battery
inside reset switch
May 28, 2012 | HEWLETT-PACKARD G61-306NR Notebook
How do i locate the hp probook 4520s BIOS password jumper on the motherboard
4520s.
you failed because of one reason, you asked on fixya not HP'
why ask here, there are no HP(few) folks here, they are all over at HP, real forum.?
bios resets are tricky,
the new rules changed with UEFI BIOS and or TPM chips added.
back in 2007 the mobo had reset jumper, (mine desktop does)
but not my 2008 elitebook laptop, due to the TPM rules.
first the link to your books
https://support.hp.com/us-en/product/HP-ProBook-4520s-Notebook-PC/4145198
those cover most issues, you will have. all by HP direct,
page 126 here is not too clear;.
the answer is here
your PC is fully locked now, there is no way to reset it .
without HP direct intervention (fixya can never ever do that)
the send you a special binary flash file that only works on YOUR PC (a fact and is by DESIGN)
https://h30434.www3.hp.com/t5/Business-Notebooks/Probook-4545s-Bios-Password-reset/m-p/6350164#M147169
never use a BIOS password, unless you write it down and hide the paper in a book you know, where it is. (got books?) i know books are now (dead technology but)>?
if you guess and start flashing BIOS, you will BRICK THIS PC.
Oct 20, 2017 | HEWLETT-PACKARD ProBook 4520s
Sir i have problem in hp g61 i;m getting that message upon installing new bios. my touch pad is going crazy, so i was advised by hp to update the bios from F 0.6 to F06 f. however when i turn the computer...
never flash BIOS or risk this., only flash if
1: THERE IS A PROBLEM WITH PC.
2: HP TOLD YOU the bios fixes this exact problem.
3; getting the correct bios for this pC can be difficult.
4: flashing with a dead battery can fail,
5: If the flash fails, try again. repeat the flash,
6: if the BIOS is now dead, take out coin cell for 15min.
put it back see if BIOS key works now. and reflash it using only the correct new BIOS FLASH binary files only from HP and matching
your exact unstated, service TAG data. (i bet you did not even look or get it right here, as many do , and then brick the PC)
the touch page worked when new.
so how can BIOS suddenly go bad?. (it cant)
no windows OS stated
if you are still running the correct OS on this G61.
to make the pad work takes:
1: pad not damaged or cables inside not loose.
2: correct OS, that HP supports, (windows 10 may not be)
3: only HP version and disks loaded for OS and all drivers, not microsofts.
4: remove and load the correct mouse pad from HP.
5: bingo it works and no flash needed, nor desired ever or 99.9% of all cases. leave BIOS alone and win. is my motto.
what G61, since you never said, my guess you dont know
and if true, then how'd you get the correct bios.
you didnt. (my guess and is right most times when bios mangles)
here ill click 100 for your, my wild guess.
it runs vista and w7 only, are you >? hp disks not MS?
year 2009 made.(as old as....)
see results in last photo. (guessing your unstated service tag)
btw, next time ask for mouse pad help
and leave BIOS ALONE.
Apr 30, 2017 | HP Compaq Presario C502US Notebook
I need to reset the password for the bios, thanks
You need to reset the BIOS. You need to open the laptop and move the jumper over one pin, then boot up your computer. Then let it boot completely, then shut it off and move the jumper back to where it was before. That will completely reset your BIOS, in turn removing the password.
May 08, 2011 | HP 6515b PC Notebook
I have a HP DV7-1175NR and I can't get access due to a problem with the password in the bios. For some reason It doesn't recognize my password. I need to know if you have any idea how to reset the bios.
HP/Compaq/Acer InsydeH20 Bios Password Service
with 8 digit HashCode
Support model: Compaq CQ40, Compaq CQ45, HP DV3, HP DV4,DV5....
We can help you remove this password.
You just entering 03 times wrong password, then your screen will show 8 digit code number (view below image):
Let's me know your 8 digit code and Model Name ( mr.tran7000@gmail.com)
GO TO >> Master password - Bios Password
Apr 11, 2011 | HEWLETT-PACKARD Pavilion dv7-1175nr PC...
RESET BIOS PASSWORD ON COMPAQ 6400 LAPTOP
YOu can reset bios password with 2 method.
(1) open back cover of laptop then find motherbord .Pull cmos cell from motherbord for 15 minutes then again put it in it's position .then it not ask for password.
(2)You can clear password with jumper settings find jumper on motherbord named clear cmos it has 3 pin .1-2-3
Put jumper in 2-3 position then again put it in 1-2 position then check .
Let me know if you need more assistance.
Thanks.
Nov 16, 2009 | HP Compaq NC6400 Business Notebook
I just hauled my very old Acer notebook (Travelmate 220) out of storage to give to a worthy cause, but I can't open it. It's password protected which is something I never usually bother with, but back then...
For that you have to reset bios settings.
Open back cover of laptop then find motherbord .
Pull CMOS cell from motherbord for 10 minutes from motherbord so all settings reset.
You can also reset password with jumper on motherbord.
Find jumper on motherbord named "clear cmos " or "reset bios " it has 3 pin.
Set jumper in 2-3 position then again put jumper in 1-2 position .
Then all settings goes to factory defaults.
Thanks.
Oct 24, 2009 | Office Equipment & Supplies
Can anyone help me on how to reset the Bios password to default on an HP Compaq 6710b Laptop? I have an HP Compaq 6710b Laptop. It is booting but it cant go beyond bios boot and i cant enter setup as it is...
Oct 16, 2009 | HP Smart Buy Notebook
Reset bios password
Most laptops do not have one and clearing the cmos will not help.
Contact HP, they have a master password that can get you in. You may have to fax them proof of ownership to get them to help. I had to do this on a laptop.
Hope this helps
Apr 28, 2009 | HP Compaq nc6120 Notebook
How to resets bios for compaq 2514 at
Why? What happend? Is it asking for a BIOS password?
If it is asking you have to short two jumpers on the systemboard to have it reset.
If not, just go in to BIOS by pressing F2 then restore or optimize default settings on BIOS.
Hope this helps...
Jul 24, 2008 | HP Compaq Presario V2000 Notebook
HEWLETT-PACKARD HP G61-429WM Notebook Logo
114 people viewed this question
Top HEWLETT-PACKARD Computers & Internet Experts
Michael Vincent Cruz
Are you a HEWLETT-PACKARD Computer and Internet Expert? Answer questions, earn points and help others
