Question about Muratec Office Equipment & Supplies
Scanning error not able to transmit confirm setting
I am getting error 244 when receiving a fax.
errors 243 and 244. Taken from HP.
The user of the remote machine has pressed that machine's Stop key causing the session to be prematurely terminated. Alternatively: the remote fax machine determined there was a feature incompatibility between the two machines and has terminated the session. An example would be when the local machine wanted to initiate polling, but the remote machine did not support this mode of operation.
Solution:
1. Confirm the remote user is not inadvertently attempting to poll transmit from the local machine, instead of transmitting to the local machine. This mode of operation must be specially configured on the local machine. If poll transmission from the local machine is the desired mode of operation, confirm the local machine has been configured for this operation.
2. Reconfigure the local fax machine to use different configuration settings, toggle the ECM state and/or select a slower reception speed
Sep 20, 2010 | HP 910 Plain Paper Inkjet Fax
Will not transmit to Shop and Scan website when transmit button is pressed . drivers installed from cd provided, new usb lead connected and green light shows on scanner, test scan done from barcode on...
Did you ever get it to transmit the barcodes?
I'm having very much the same problem. Got the error 3 message first, then was told to delete the add on in manage add ons. Now i get an error 2.
Jun 13, 2010 | Opticon OPN 2001 Mobile Data Collector...
How to get a confirmation print out after a fax done
Open 1 Touch Speed Dial Panel. Press <Data Registration>. Press <Set>. Arrow down to (2.Report Settings). Press <Set>. 1.TX Report . Change from "Print Error Only" to "Output Yes". This will cause a confirmation report to be printed after every transmitted fax.
Oct 06, 2009 | Canon LaserClass 2050 Plain Paper Fax
Hi there i have a strange icon in one of my radios
The icon you are describing is the "roger beep" icon. It would not be the reason your radio is not transmitting. Most likely your programming has been changed. Here is a link to the manual where you can read how to program the radio's frequency and interference eliminator code. http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T5320_T5410_T5420_User_Manual_E.pdf
Roger Beep/Talk Confirmation Tone
When you turn on this feature, your two-way radio transmits a unique tone when you
finish transmitting. It’s like saying “Roger” or “Over” and lets others know you’re
finished talking.
• To enable Roger Beep/Talk Confirmation Tone, press and hold + (plus button) as you turn
your radio On. Now, when you release the PTT button, your set tone lets your
friends know you’re finished talking and will appear on the display.
• To disable the Talk Confirmation Tone feature, turn your radio Off and then back
On while pressing and holding the + (plus) button.
Jul 01, 2009 | Motorola Talkabout T5420 (14 Channels)...
Fax confirmation
Some printers don't do that, some printers do.
Go to the preferences of your printer and set the confirmation there. Usually after sent a fax if no error message appears the fax has been transmitted.
Oct 06, 2008 | Dell 924 All-in-One InkJet Printer
Motorola T5420 Transmit Problem
Here are some troubleshooting thoughts:
1. Is your battery indicator showing at least 2-3 bars? (Battery Note: Your rechargeable batteries may fail due to setting without use for a long period of time. They need replaced every 12-14 months usually. A good tip is to charge them once a month to keep the chemical in the battery active.)
2. Check to see your Qt noise filter is shut off. Refer to page 22 of the owners manual. It is possible you have some radios set to Y and others to N. To assure good communications you should set all of them to N.
3. With your radios set to interference code zero, place your radios one at a time in scan mode, while you transmit/talk on one individual radio. See if any of the radios receive. Do this with each radio individually to see if you are transmitting at all. NOTE: This test will determine if you have any ability to transmit. If you do not receive any sound on the 3 radios setting in scan mode, the individual radio you are testing will not transmit.
Aug 25, 2008 | Motorola Talkabout T5420 (14 Channels)...
Scanner will not scan to printer.
try to check ur scanner settings on the control panel of your coouter it might not be added to your hardware that's why....
Feb 26, 2008 | Samsung SCX 4200 All-In-One Laser Printer
Muting the sound
The sound produced by a Motorola radio when the mike is keyed refers to the "Transmitting Call Tone" which is another feature other than the "Interference Eliminator" or the "Roger Beep" feature.
On most Motorola GMRS/FRS TalkAbout radios, setting the "Call Tone" to 0 disables the feature. This is done with the radio ON by pressing on the "Menu" button 3 times which will result in the display showing the current Call Tone setting (flashing) and the letters CA; pressing on the <- or +> buttons will change selection (you will also hear the different Tones), select 0 (it may be up to 5 or 10 depending on the version). Press on the "Menu" or "PTT" button to set, save and exit.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Nov 25, 2007 | Motorola TalkAbout T5530 2-Way Radio
Jounal Entry Dates
Most machines will only keep a certain amount of transactions in memory. Your fax that you are looking for is probably over the amount of transmissions kept in memory. One suggestion, if the fax was a long distance number, you could check your phone for that number. You also might want to set your machine to print a confirmation report for every fax sent and staple it to your fax for further reference.
Jun 25, 2007 | Muratec F320 Plain Paper LED Fax
19 people viewed this question
Top Muratec Office Equipment & Supplies Experts
Kyocera HP Expert
CheckitRight
CheckitRight
Ben
Ben
Are you a Muratec Office Equipment and Supply Expert? Answer questions, earn points and help others
