Question about Fujitsu ESPRIMO E5905 PC Desktop
Usb boot from stick - Fujitsu ESPRIMO E5905 PC Desktop
How do i install a operating system on a sony old sony viao 600hep with no dos and no operating system and a broken cd rom drive. only have usb.
Check out this:
http://www.ubuntu.com/download/desktop/create-a-usb-stick-on-windows
This gives instructions on how to download, and create a ubuntu bootable USB stick.
http://www.ubuntu.com/download/desktop/try-ubuntu-before-you-install
This will give instructiosn on how to load and install from said USB.
You will need:
A working computer with Windows
A 2GB or larger USB stick
Internet connection
After you've made your USB stick, when booting up the computer you wish to install ubuntu on be sure you have the USB stick inserted when powering it on. When the start screen comes up press ESC to enter the BIOS or boot order. Select the USB stick from within the BIOS boot order menu, or the USB stick from the boot options menu.
Load ubuntu, install, enjoy.
Mar 13, 2015 | Sony Computers & Internet
How can i boot from usb in hp elitebook 8460p
You must first get a USB stick set up with the OS you are using and the USB stick must be formatted as to be bootable. Then you need to restart your notebook and go into the BIOS setup and change the boot order to make the USB port(s) first, otherwise you will continue to boot to the hard drive.
Dec 18, 2014 | HP EliteBook 8460p Notebook
I want to turn a memory stick into hard drive. How can i do that?
you will need usb data drive at least 4 - 8 gb
Download the GParted Live utility and the HP USB Format Tool via the links in Resources.
http://www.majorgeeks.com/downloadget.php?id=5757&file=15&evp=fb0a8fee133295405b5af3205e8d2424
Insert your USB stick into the computer. Run HP USB Format Tool. Select your USB stick and then choose the FAT or FAT32 format options. Click "Start."
Extract the files from the GParted Live zip file. Select the USB stick as the destination.
Open a file browser and navigate to the USB stick. Select "utils" > "win32" > "makeboot.bat." Double click on "makeboot.bat." Enter "Y" when prompted.
Power off your computer leaving the USB stick inserted.
Connect your portable hard drive to another USB port.
Power on the computer and quickly press "F8" through "F12" to access your boot menu.
Check your computer or motherboard manual for the exact keystroke.
Select the USB stick as your boot source and press "Enter." Allow the Gparted GUI to start.
Select the external portable hard disk drive. Click "Partition" on the menu bar.
Hover over "Format to" and select "NTSF."
If you are unable to create or format the partition, select delete partition.
This will erase all data on the external hard drive. Confirm partition deletion. Select the external drive again. Click "Partition" and hover over "Format to" then select "NTSF."
Select the external hard disk drive again. Click "Partition" on the menu bar and then "Manage Flags." Check the box next to "Boot." Save and apply changes to the drive.
Power off your computer and remove the USB stick.
Install the OS
Insert or plug your OS installer, usually a DVD, CD or USB thumb drive, into the computer. Power on the computer and access the boot manager again.
Select the source containing your OS installer and press "Enter."
Enter your personalization and registration information if required.
When prompted, specify the portable hard drive as the install directory.
Begin the installation normally.
Restart the computer when prompted and access the boot menu again. Select the external hard drive as your boot source and press "Enter" to ensure the installation succeeded.
Use this process to boot from your portable drive on any computer.
hope this helps
Oct 02, 2012 | Sony Vaio VGNBX196SP
Hirens
Go to the BIOS settings and then Boot (start up) order and make the USB device the first boot device and the hard disk the second boot device.
If the USB is not listed then your laptop cannot boot up from an USB memory stick.
To make a Hirens USB boot memory stick copy the Hirens files onto the USB memory stick. Then you can boot up Hirens with the USB memory stick.
Jul 01, 2012 | Computers & Internet
Can Gateway MX3215 boot to usb stick?
If you go into the BIOS configuration then the Device boot order and you do not see the USB port in the list, then an USB boot up option is not available.
If it is available the move the USB as the first boot device so you can boot up with an USB memory stick.
Nov 13, 2011 | Gateway MX3215 Notebook
Cannot boot from usb key
Try hitting F12 while booting up. Later model PC's use that key sequence to allow you to choose which device to boot from. Permanent changes to the boot order can be made in the BIOS. If that does not give results, maybe try another usb slot.
Nov 08, 2009 | ASUS Eee PC 1000HA Notebook
Any other advice?
hi....
this trick will allow u to use ur usb stick as a key to boot into windows . if someone tries to start the
computer without the usb stick , it will display boot errors. before we begin , let me tell u that playing
with the bios and boot files of ur computer may result in u not being able to boot into ur windows partition ; so continue at ur own risk!
step1: unhide hidden and protected files: go to tools > options > view , check show hidden files and uncheck hide protected system files
step2: from the drive where windows is installed copy the files boot.ini,ntdlr and ntdetect.com to ur usb stick
step3: now we need to go into ur bios , so restart and keep jabbing (F8 or DEL) as soon as the pc starts
step4: once the bios , enable usb drive as the first boot device u might have to enable usb legacy support on older bioses
step5: restart ur pc if all goes well , u should be able to log into windows if not, then unplug the usb stick , return to the bios and change the first boot device to ur hard disk drive and repeat the steps above
step6: once u r logged into windows , go to ur windows drive and rename boot.ini to boot.bak
step7: to check if u have setup everything correctly , eject usb and reboot the pc u should get error message on the screen such as "invalid boot.ini" or " windows could not start "
step8:incase windows does not load , use ur windows recovery disk by followin the steps at http://tinyurl.com/s9sd2
Apr 14, 2008 | Intel D850MV Motherboard
Fujitsu ESPRIMO E5905 PC Desktop Logo
91 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
