Question about Vacuums
Crofton steamer - Vacuums
I only need a new Crofton cordless sweeper battery charger
FIXYA does not sell any product . SORRY
Sep 13, 2017 | Vacuums
My compact steamer does not let the steam out when I press the black release button help?
I examined mine. There is literally NO hole in the steam wand for the steam to exit. It's a wonder the thing didn't blow up. Take it back and be glad you still have your face.
Jan 01, 2015 | Top Vacuums
Crofton VC9385S manual
This vacuum was built by Wachsmuth & Krogman for the Crofton label. The model number, VC9385S, is used for the Easy Home Carpet Cleaner from several different years. Please check the date code on your vacuum to check which manual is the one you need. The date code is on the rating label (usually on the line below the manufacturing location). Start at http://www.wk-usa.com/#!manuals/cni5 and choose the correct year for your product. Then scroll down to the Easy Home section. The direct link to the manual for the 2013 version is currently http://media.wix.com/ugd/b833f4_5253cb0da5524200b89975f17b0453ea.pdf.
I hope this helps.
Jul 19, 2013 | Vacuums
Just purchased crofton sm 102 steam mop. instructions say will steam when light turns green. ok, it steams for about 10 seconds and thats it!!!!!! tried several times with same results
I had the same problem. Seems the little gizmo in the base that pushes up the water release valve is set a bit too low. With the water tank removed, you'll see a plastic circle with a plastic "x" in the middle. A tiny drop of glue on the "x" to raise the level a bit did the trick for me.
Apr 11, 2011 | Vacuums
I ned at instruction book for electrolux enviro multi steamer
You didn't specify which model you had, but I assume it's the newer Eureka Enviro Steamer Model 313A.
Here's a link to the owners manual for your Steamer. If you have an older Enviro steamer, please feel free to reply using the comment field below. Also, if you found this solution helpful, please be sure to leave feedback for me. Leaving feedback is greatly appreciated by the FixYa community, and ensures that repair experts continue to leave great FREE advice, as opposed to just answering the premium, or paid questions.
Hope this helped you, thanks again.
Eureka by Electrolux Enviro Steamer Owners Manual for 313A
Jan 07, 2011 | Vacuums
Would like to remove urine stains on carpet with steamer. Do not have any instructions. Please help
You should not try to remove the stains with the steamer. Removing stains with a steamer can cause a chemical reaction that will bond the urine to the carpet.
Mar 15, 2010 | Electrolux Envirosteamer 370A Canister...
Vacuums Logo
14 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
