Question about Dell Computers & Internet
I have a dell inspirion 5150 that doesn't power up it has a new charger, it shows a solid green power indicator and a solid orange battery indicator. It does nothing when connected, does anyone know what those codes are? Thank you.
  • Official Brand Answer
  • 560 Answers
Thinkloko,
With the power off and the system unplugged, connect the AC adapter to the system to see if the system powers up. If so, then the battery will need to be replaced. You can call the Dell Spare Parts Department at 1-877-717-3355 to check the price for a battery.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Posted on Jul 31, 2013
3 Suggested Answers
  • 130 Answers
SOURCE: Dell inspiron 2200 green LED battery Indicator flashing
sounds like your charging circuit isn't working or the adapter isn't putting out enough power or amprage to fully charge the battery, or you battery went bad. if the charging circuit is bad then so is *********** board, time to burry the system and buy a new one
Posted on Jun 21, 2009
shakeelm
  • 224 Answers
SOURCE: Dell Inspirion 1526 will not turn on. The battery
Sounds like a motherboard problem that needs replacement most likely. You'll need to get a techie to diagnose it pysically
Posted on Mar 03, 2009
What does a orange power light mean
please see the commentary. God bless you
  • The majority of laptops will display a solid green, blue or purple battery light to indicate that the battery is fully charged. Most manufacturers indicate that a laptop is in the process of charging by displaying a solid or blinking green, orange, blue or purple light. If your battery indicator light is green, blue or purple, the battery is probably functional, regardless of whether the light is blinking. If the light is solid orange, the laptop is probably in the process of charging.
Battery Error Coneventions
  • Many battery manufacturers use rapidly blinking lights to indicate that a battery's charge level is low. In general, a laptop will rapidly blink orange or red when its charge drops below a certain level until the computer is plugged into a power outlet and charged. If your laptop's battery indicator continues to blink rapidly in orange or red or if it remains red even when it is plugged into the charger, it indicates a problem with your battery or the charger.
Read more: http://www.ehow.com/info_12183593_blinking-battery-light-laptop-mean-charger-not-charging.html#ixzz2fu5qhEWg
Sep 25, 2013 | Computers & Internet
Zoostorm laptops
please read and execute the commentaries. God bless you
Charging Conventions
Sep 25, 2013 | Gateway Computers & Internet
Mydell 5160 has a yellow blinking light on the front 1st from right. any suggestion on cause or solutions.
It is the battery Status indicator and flasing orange light indicates that battery is low. After connecting the charger it should turn solid green, which indicates that the battery is charging and it turns off when battery is charged completely.
If it continously blinks, check out the charger and battery.
Dell 5610 owner's manual can be downloaded from:
http://support.dell.com/support/edocs/systems/ins5160/en/OM/G74822LRs.pdf
Check out Page-15
Let me know if any clarification is required
CreativeTECH
Nov 12, 2010 | Dell Inspiron 5160 Notebook
I have a Dell Inspirion 1525. I have a fairly new after market replacement battery which I have only had now for 4 months. I am using Vista. As soon as I unplug, computer shuts down. I go to power settings...
The adapter is working correctly. The battery is either slow to charge or in need of replacement.
It's possible your battery isn't charging at all so to test this boot into bios -> battery status and watch it run overnight.
Sep 09, 2010 | Dell Inspiron 1525 Notebook
I have a Dell Inspirion 1525. The Battery would not charge and the light would flash orange. I bought a new one and upgraded from a 6 cell to a 9. Now it says plugged in but not charging and the batt light...
Firstly, i suggest you try to use the charger with a similar laptop to see if it will charge it.
If it does, it means the charger is still very much good.
And as for the battery you change, it will be better for you you to check the voltage rate on your charger and the voltage rate on the battery because it is very possible, the voltage rate of your charger might not be able to power your new battery.
The voltage of the new battery might be higher than what the battery could power, so you might need to get the same voltage rating of charger for the new battery.
**** you can still test the charger with a similar laptop to be sure the charger is still good.
Take care.
Apr 19, 2010 | Dell Inspiron 1525 Laptop
Dell 9400 wont show AC power icon
If the computer is connected to an electrical outlet, the about10.jpg light operates as follows:
  • Solid green: The battery is charging.
  • Flashing green: The battery is almost fully charged.
If the computer is running on a battery, the about41.jpg light operates as follows:
  • Off: The battery is adequately charged (or the computer is turned off).
  • Flashing orange: The battery charge is low.
  • Solid orange: The battery charge is critically low.
Looks like the AC adaptor is faulty.
Aug 25, 2009 | Dell Inspiron 9400 Notebook
Its doing something new i htink
That usually indicates battery is beginning to go bad. Eventually it will not hold a charge and will need to be replaced.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 09, 2008 | Dell Inspiron 5150 Notebook
Can't charge battery or run off AC
You may have a problem in the DC charge circuitry. These parts are located on the moatherboard directly and can't be bought separately and repaired. You must send your Dell to a specialised service to have it fixed by them. Sorry, I can't see no other way for this problem to be solved.
Jan 20, 2007 | Dell Inspiron 5150 Notebook
Computers & Internet Logo
Alun Cox
