Question about Hisense LHD3204US 32 in. LCD HDTV
Hisense 32 lcd. Red light staying on but tv wont turn on useing remote control or side panels
SOURCE: My Hisense lcd is lock.
This is how I got mine to work after weeks of struggling just trying to find a new remote (hisense is really hard to contact....).
1) Turn the TV ON. unplug the tv while still ON 2) hold down the "menu" button on the side of the TV and plug it back in. keep holding it down. the TV should turn on with the menu popping up. use the Vol <> keys and Channel <> keys to navigate the menu. go to the Vchip menu, and play around. I'm not sure what ultimately worked, but i changed the Vchip password to 1111, turned the reset menu to "on" and played around with the ratings settings (turning most of them to "u"s etc).
I went through this process several times and finally, the black background behind the menu turned to static. I played around with the channels, and the TV was unlocked. I turned the TV off, and then on again, and the channels showed up normally (no static). and it was no longer locked. I had to do the unplug thing several times, and was getting really frustrated looking for an "unlock code" in the manual (it just says press the button on the remote. so it was not really helpful).
But really, once you can just get to that menu you've made some progress, and just keep playing around with it until something works.
Best of luck!!
Posted on Jul 11, 2008
SOURCE: Hisense LCD Tl2020
I, also, have the Hisense LCD 1504 and cannot turn it on with the original remote. I have to use the ON button on the side every morning. You have to hold this button in for a while then wait a while and presto, the blue button shows on the front and the picture comes on. If it fails to work the first try, just try try again. It does work for me this way. We had this same experience with the TV in our room at a Hotel where we were on vacation and the TV worked fine when we turned it on using the side ON button. It just takes a while for the picture to appear. Hope this clue will help someone.
Posted on Oct 12, 2008
  • 13433 Answers
SOURCE: hisense tv
so whats the remote you have there?
Posted on Oct 23, 2008
  • 4090 Answers
SOURCE: Hisense tv turns on and off
STOP!
The unit has a fault on its power board and sustain board.
It turns off because the sensor is preventing some component from bacoming overheated and catching fire or damaging further components. Seel professional repair.
Please rate my help++++Thanks for using FIXYA
Posted on May 13, 2010
gopakumarg43
  • 74459 Answers
SOURCE: code remote control universal hisense LHDN32V66AUS
Hello
Four digit universal remote code for Hisnse TV are:-
0073 0182 0216
Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
OK.
Posted on Mar 09, 2011
How do you turn up the volume on hisense ledn32d33 without a remote
See if the set has volume controls on it. Some sets have a power switch and volume/channel controls on them.
May 29, 2016 | Hisense Televison & Video
HL32V86 Hisense 32&#39; stuck on standby wont turn on it seems screen stay black
Call the HiSense tech dept. You can find the number on line and they will tell you how to fix it or you can try using the remote and go to settings and see if you can fix it that way. Also the manual for this tv should be available online as well.
Jan 03, 2015 | Hisense Televison & Video
Why wont the flashing red light go away and switch on my 32 inch led hisense tv
It could be your remote control batteries are dead? Try to manually depress on/off switch on TV.
Dec 03, 2014 | Hisense Televison & Video
I need a remote control code for a hisense tv
Hello
Four digit universal remote codes for Hisense TV are:
0073 0182 0216
Five digit universal remote code for Hisense tV with RCA RCR312W remote control is:
10748
Sep 14, 2012 | Hisense LHDN32V66AUS 32 in. LCD TV
Need a universal remote control code for Hisense tv
Hello
0073 0182 0216
10748
Dec 12, 2011 | Hisense LHDN32V66AUS 32 in. LCD TV
Need IR code for Hisense 32" LCD tv to program
Are you referring to the iPhone/iPad app? if yes then this is not a remote app, it's a management app made for Comcast boxes and nothing else it doesn't controls tv's.
If you are referring to the actual remote for one of the Comcast boxes then it all depends on what model of remote you have and the exact model of your tv - some will support it thru the use of a Daewoo or Samsung code, others don't.
So you have 2 options:
1 - you try every Daewoo and Samsung code you have in the manual and if that fails you do a code scan on the remote as explained in the manual:
Turn on your TV
Press the TV button on the top of the remote, then press and hold Setup until the TV light blinks twice
Enter 9-9-1 and the TV button will blink twice
Press and release 1 and the TV button will blink twice
Point the remote at the TV, press and release the Power button, then press the CH+ button multiple times until the TV turns off
Press Setup once to lock in the code and the TV button will blink twice
If even that fails - the tv doesn't shuts down - then the remote is incompatible to the tv so
2 - you get a remote that is compatible with both. The only one i could find is
http://www.logitech.com/en-us/remotes/universal-remotes/devices/6812
Jun 04, 2011 | Hisense LHDN32V66AUS 32 in. LCD TV
Code remote control universal hisense LHDN32V66AUS 32 "
Hello
0073 0182 0216
Code Entry
OK.
Mar 09, 2011 | Hisense LHDN32V66AUS 32 in. LCD TV
I need the code to program a rca systemlink3 remote for a hisense tv
0748...but if its like mine it wont work. these HiSense remotes are JUNK!!!
Aug 17, 2009 | Televison & Video
Hisense LCD Tl2020
Sep 16, 2008 | Hisense LCD1504 15 in. Television
Hisense LHD3204US 32 in. LCD HDTV Logo
Top Hisense Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Electro Med Services...
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
