Question about True Technogym Excite Run 700 Treadmill
Monitor shows equipment block what can i do? - True Technogym Excite Run 700 Treadmill
    Top Expert:
  • True Master
  • 12,223 Answers
Please Pressing SCREEN LOCK a second time will unlock it as well.
God bless you
Posted on Jul 31, 2013
Technogym cross trainer - equipment is blocked 16
Equipment is blocked is unfortunately a common 'error' that shows up with Technogym, but it refers to a number of errors.
-Does your emergency stop swivel a lot, or is it fixed? If a cable has come off inside, that can be the cause.
-A loose cable running up the arm of the frame is the next thing to look at.
-Lastly, and most common is the motor controller has fried. It's a common thing with Technogym, and is an expensive repair. Technogym will tell you that you have to replace it, but since it's electronics it can be repaired, as long as someone knows what they are doing.
Where are you located?
Apr 20, 2014 | True Technogym Excite Run 700 Treadmill
Why does my monitor produces static noise when I scroll?
it might be because of rays emitted by the monitor...show it to your local electrical equipment repairer or take it to the service centre if still in warranty
Apr 06, 2014 | Computers & Internet
L750 block of colour on bottom half
Your lcd screen is going bad. It's either the lcd screen or the video card inside the computer. To isolate the problem try connecting another monitor to the computer. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed monitor displays ok then your video card is ok, but your original monitor is bad. If the Borrowed monitor displays the same as your original monitor then your video card is bad.
Plug in an external monitor and see if the display shows up on it. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If the video shows on the external monitor that proves your video card is ok, ,but your lcd screen is bad. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
Jun 08, 2012 | Toshiba Satellite L750 Notebook
Kenwood kvt-719dvd plays dvd but wont show picture
It is probably that the parking safety wire wasn't hooked up properly, or at all. Most in dash dvd players are equipped with a motion safety device to prohibit the driver from viewing movies and such on the monitor while the vehicle is in motion. The wire for this needs to be hooked to the parking brake light wiring. This will ensure that when the parking brake is on, the dvd can sense that the vehicle is stopped, and should therefore show the image.
Mar 15, 2010 | Kenwood KVT-719DVD 7 in. Car Monitor
When I connect the lcd to my laptop, the lad shows
hi atuire,
try hooking up the lcd screen toanother computer and if it shows the same double screen again then there is aomething wrong with your lcd monitor,
you may want to use another monitor with your laptop to ensure the problem is not on the laptop's side.
if issue stays same with another monitor, then just right-click onto desktop background, goto properties and have a look whether you have enabled the shared monitor feature
(meaning that u can use two screens with just one graphics card parallel, to work on a 'wider' range of sight.
Therefore your machine's graphics card sually must be equipped with both: a standard vga out and a HDMI-out as well.)
if your machine ddoes not have these capabilities but still the monitor sharing is turned on from the software side, this might cause the problem. To disable simply change the graphics card's
propertiers as descried above.
Good luck
Sep 06, 2009 | Gateway Computers & Internet
Can balance cm2017 play High Definition video?
it isnt so much the monitor that plays it as the equipment that you have to play it , in other words if you have a high definition reciever or dvd player hooked up to it it will show these in hd
Aug 28, 2009 | Balance CM2017 17" Monitor
SCREEN DOES NOT SHOW HELP HP G60
TRY HOOKING AN EXTERNAL MONITOR TO THE LABTOP IF YOU SYSTEM IS EQUIPED FOR THAT TYPE OF USE., IF YOU DONT HAVE ONE, SEE IF ANYONE YOU KNOW WILL LET YOU BORROW UNTIL YOU CAN SOLVE THE PROBLEM WITH YOUR MONITOR.
ROD
May 12, 2009 | HP G60-120US Laptop
Gateway vx930 monitor has a black screen and clicks one time when booting up computer, but does not show anything. Switched to another monitor and it works fine. Can I fix this monitor or is the repairman...
Can you fix it is more a question of your electronics expertise and equipment. Unless this was a very expensive monitor it's probably worth disposing of. Most cities have some sort of disposal system. Here in AZ there are many private companies that offer free disposal.
Mar 26, 2009 | Gateway VX930 19" CRT Monitor
SCRAMBLING SCREEN
befor replacing,make sure settings in video output from video card are set for that monitor.If color quality is set too high or resolution settings not supported by the monitor are used picture may not show up at all.(try safe mode,Settings are usually at bare min.in safe made)
Jan 09, 2009 | Acer AL1715 17" LCD Monitor
Vista shows monitor as Analog
Are you actually interfacing via the DVI-D connection or the 15 pin analog 'D' connector? Your monitor is equipped with both according to its specs.
Sep 14, 2008 | Gateway FPD1975W 19" LCD Monitor
True Technogym Excite Run 700 Treadmill Logo
297 people viewed this question
Top True Exercise & Fitness Experts
Tom Chichester
Electro Med Services...
Are you a True Exercise and Fitnes Expert? Answer questions, earn points and help others
