Colors are good picture is fairly dark, I have tried to brighten it up and it didn't help. Now 3 1/2 hrs later the picture looks fine. Confused is it the tv or the satellite service!!
    Sergeant:
  • 171 Answers
Provide with the TV model number.
It could be a lamp burning out.
Posted on Jul 30, 2013
BMW Rider
  • 232 Answers
SOURCE: HITACHI ultrascan hd tv....
toni, you`ll need a tv tech for this problem, spark gaps need to be cleaned, crt sockets need to be cleaned and crt pins on all 3 crt`s need to be sanded, this is a common issue with this model set, good luck, BMW Rider
Posted on Dec 28, 2007
  • 579 Answers
SOURCE: problems with brightness on the hitachi 50v810
Yes, they dim as they age, and you've done well to get 3 years out of one.
Projection TV makers charge an arm and a leg for their replacement lamps. They make it easy to do but as a result the custom lamp assy is expensive. The trick is to just buy the bulb for your model TV from any number of us aftermarket sources at a fraction of the lamp price and install it in the old lamp yourself. really easy.
Posted on Jan 02, 2008
SOURCE: Fading picture that looks dark and dull on a 42" Samsung DLP tv.
You need a new lamp...
Posted on Feb 27, 2009
SOURCE: TV picture is red.
Normal color picture is composed with 3 colors R-G-B (Red-Green-Blue). Picture turns Red means: Missing Green and Blue colors (many reasons: bad contacts, projector tubes dead, and other...). Try to give some "tabs" to diagnose ... I don't know what is the type of your Projection TV, how long you owned it, to have more idea.
Posted on May 15, 2009
  • 668 Answers
SOURCE: sony xbr 60 grand wega color problem.
It sounds like to me you have a bad Optical Block. It is a expensive repair and you may want to call Sony at 1800-222-SONY and see if the would assist you in repairs. Due to the age of it, they would probably only cover a partial amount of the repair.
Hope this helps,
Skyassoc
Posted on Jul 25, 2009
Sony 32" works fine as a tv but very dark when on vga input
check if cable is good and if so try enhancing brightness from pc to max.
when its dark, menu colour is dark as well? if so that is a problem on the motherboard and not pc or cable, if not it means its a wrong setting somewhere
Mar 09, 2014 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Dark picture,can't get it to brighten up with menu color settings.
Assuming brightness and contrast (picture on some sets) does not help it could be a number of things, how old is this set?
Dec 15, 2012 | Sanyo DS25390 TV
The Picture on my HD-52G886 Model is really kind of dark I can still see the picture and sound is fine but a little to Dark when I try to brighten it then its really dull white.
Changing the contrast will also help brighten your screen. For best results, try changing the contrast and the brightness, to find the perfect combination for your needs.
Jul 19, 2011 | JVC HD-52G886 52" Rear Projection HDTV
Picture on all channels is dark
seems like its the inverter thats either not working or the tubes are faulty
Mar 26, 2010 | LG 42LG50 42 in. LCD HDTV
The brightness is very dark. Any nightime scene
Your CRT's getting old. Plus dust on lenses don't help much. You have to open front frill (below screen) and back of the TV. Clean up lenses using dry paper towels, do not wet.
In front of the TV after grill remove center cover and locate "black box" that have 6 potentiometers on it that looks like plastic adjustment screws for philips #2 screwdriver slots. 3 of them should read "Focus" These you don't touch. Another 3 reads "Screen". Put some still image on your screen (like paused DVD movie frame). Carefully add brightness in all 3 colors trying to avoid horizontal lines appearance. If lines show up, just turn it back a little. Try to keep color balance looking at the picture.
This procedure will brighten up image but further reduce CRT's life.
In case that you posted wrong model here and you have DLP Projection TV - just replace the lamp.
Mar 09, 2010 | Pioneer SD-643HD5 64" Rear Projection...
Dark and red picture
First you can up the screen voltage, by finding the HV transformer. It has Screen and Focus control on it this it the Transformer that is in back of set and has an anode lead going to Picture tube. Come up on the screen control slowly and if the picture brightens with vertical lines then it's too high, The red problem is a small transistor that maybe located on the CRT board. It's probably shorted. There are about 3, each going to the different colors Red, Blue, Green.
Sep 13, 2007 | RCA F35317 35" TV
Dark picture
use the advanced options page and reset the factor blue and red convergence defaults then do re apply the auto color defaults color at first it seemed very red (which is good because red was the missing factor in the green picture) but after reseting all the color and tints to the normal ranges I then reset the color auto correct again and all seems fine.
Sep 21, 2006 | Hitachi 53SDX01B 53" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
