Question about Sharp Aquos LC-42D62U 42 in. LCD HDTV
Telefunken Vegas TV says no sync since it was switched off at abou 1.30am this morn when switched on at about 8am NO SYNC displays checked everything linked to PVR decoder via HDMI cable worked ok watched from 10pm last night to 1.30am
SOURCE: I have a Sharp Aquos 46" LCD television
Problem is likely at broadcast source, if you've tried rerouting the audio over an alternate path. Complain to Dish!
Posted on Jan 25, 2008
  • 53 Answers
SOURCE: Sharp 46D62U incompatability
Most likely a defective Main Board. I suggest calling Sharp 1-800-237-4277 to locate your local Sharp Authorized Service Center.
Posted on Mar 14, 2008
zlittell
  • 30 Answers
SOURCE: Television is not recognizing HDMI inputs
there is a possibility that there might have been a power surge sent over hdmi into the hdmi board on the tv. if on your model the hdmi board is seperate from the sine board then youll have a cheap replacement if not its gonna cost you roughly 300-400 is my guess.
call your repair guy
Posted on Aug 03, 2009
dave1645
  • 834 Answers
SOURCE: I have a Sharp Aquos TV that only displays a colorful grid.
your t-con board is failing call a tech to install a new one
Posted on Sep 20, 2009
vernonallen5
  • 134 Answers
SOURCE: I have a Sharp LC-46E77UN
THe problem is in the set top box. Or common called the tuner box. IT looses the 5 volts to the main display and thus the monitor will go into a shut down state. THESE boxes are factory repair only and must be sent off to repair.
Posted on Feb 20, 2011
Why does my Telefunken Vegas HD Plasma tv keep switching on and off by it self?
take it in for a proper diagnosis but it appears that you have a component that is malfunctioning or over heating , probably in the power supply
Jul 08, 2016 | Televison & Video
Why my telefunken picture keep on going down not stable?
Vertical rolling. Instability in vertical sync: circuit. Contact any service technician. Sounds like an IC fault. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Mar 17, 2015 | Televison & Video
Telefunken vegas please assist and email me maria.vandenberg59@gmail.com some help my TV sound goes up and down one moment it is soft then it goes load. How can I ajust the volume
If the audio level goes up and down automatically, the cuse should be with its main system control memory IC. Contact any service technician.
Gopakumar Gopalan Google
May 17, 2014 | Televison & Video
Telefunken Vegas 50 plasma
do you see an option to run in a compatability mode?
Nov 06, 2013 | Televison & Video
Telefunken Vegas 42'; model: D294U - 88 power
Sounds like the screen could have gone or the motherboard has something to do with it, try opening it up but be careful just to make sure everything is intact
thanks
Aug 06, 2013 | Telefunken Tablets & eReaders
Ford Sync not functioning
I've had the SYNC stop working twice for no reason. The first time, after checking fuses and such and not finding a problem, I just disconnected the battery cable for 10 minutes, then reconnected and everything worked again. Went straight to that the second time it happened and was back in action straight away.
Mar 16, 2013 | 2009 Ford F-150
Telefunken Vegas Tv + All For One Universal Remote = :(
Codes to check are 058,038,049,026. If you wish to get more details to different brands of universal remote controls, check this link.
Feb 09, 2013 | Televison & Video
The codes for telefunken vegas 50" plasma tv
Hello
There is only one setup code with Telefunken V with URC 3021 and it is:
0702
OK.
Jul 15, 2011 | One For All URC-3021 Remote Control
What do I need to connect my laptop/wii/dvd player to my Sharp Quattron Aquos Led TV? Please need an urgent answer please?
Hello
1 Press MENU to display the MENU screen, and then
press [=> or <=] to select "System Options".
2 Press [Up or Down] to select "Input Terminal Setting", and
then press ENTER.
3 Press [Up or Down] to select "PC input", and then press
ENTER.
4 Press [Up or Down] to select a specifi c adjustment item,
and then press ENTER to set each item.
5 Press [Up or Down] or [=> or <=] to select or adjust the desired
setting, and then press ENTER.
Adjusting the PC Image
Auto Sync. (for Analog PC Input Mode Only)
For automatically adjusting the PC image.
Yes: Auto Sync. starts and "Now adjusting the image."
displays.
No: This function does not work.
When "Auto Sync." is successful, "Completed" displays. If
not, "Auto Sync." failed.
"Auto Sync." may fail even if "Completed" displays.
"Auto Sync." may fail if the computer image has low
resolution, has unclear (black) edges, or is moved while
executing "Auto Sync.".
Be sure to connect the PC to the TV and switch it on before
starting "Auto Sync.".
OK.
Mar 14, 2011 | Sharp Televison & Video
Sharp Aquos LC-42D62U 42 in. LCD HDTV Logo
80 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
