Wolsey wps 100/1 have a problem with it cutting
Wolsey wps 100/1 have a problem with it cutting out - the green light disappears for no obvious reason and therefore the connection hence no digital tv. any suggestions please?
4 Suggested Answers
SOURCE: Tv cuts off and green light flashes
I went thru this a couple of days ago. The repairman change the bulb and my TV was fix in 15 Min. I too have a Sony 60 inch WEGA.
 Now that I know I can change the bulb myself, but there's a hazmat issue on the bulb.
goog luck.
Posted on Oct 23, 2007
shashank1990
  • 125 Answers
SOURCE: there is a green light
WPS means Wi-fi Protected Setup its a kind of wireless security for the router. There are two methods of activating it either by push button(Which you tried) and other is manual for that you can log into the Router setup page using "Http://192.168.2.1" in the Internet explorer and enter the pin code printed under the router. You should click on "Wi-fi protected setup" towards the left side of the page and leave the password field blank and click submit and enter the code and click on "Start" or Apply changes. The reason why it didnt work through the button is probably because your laptop might not be in range or switched off. It has a utility installed on your laptop which recognizes the connection and let it protect using WPS.
Hope it helps. Please feel free to contact us for further assistance or information.
Posted on Dec 16, 2010
  • 1623 Answers
SOURCE: What is the reason for
Its to allow you to connect wireless devices to your router without having to be able to know how to do it
  1. PIN Method, in which a PIN (Personal Identification Number) has to be read from either a sticker on the new wireless client device (STA) or a display, if there is one, and entered at the "representant" of the Network, either the wireless access point (AP) or a Registrar of the Network, cf below the Protocol Architecture.
    This is the mandatory baseline model; every Wi-Fi Protected Setup certified product must support it.
  2. PBC Method, in which the user simply has to push a button, either an actual or virtual one, on both the AP (or a Registrar of the Network) and the new wireless client device (STA).
    Support of this model is mandatory for APs and optional for STAs
Posted on Feb 15, 2011
What does WPS button stands for.
WPS=WiFi Protected Setup. This is typically used to connect a Wireless Router to a Wireless Repeater. Both must be WPS capable and using WPS is similar to pairing two Bluetooth devices. One device transmits WPS and another listens (after you initiate a WPS sync). You have to enter a WPS PIN and the devices should connect.
Jul 03, 2017 | The Computers & Internet
Why are both the Wireless and WPS lights on my modem\router always on solid green, when I only have a DSL connection?
The wireless and WPS lights solid green mean that the wifi and WPS are active. It also means that your home network is exposed to anyone with a laptop/pad/smart phone who knows how to hack into systems that have not been set up properly with the proper security.
I see the following security issues with your router:
1. The router's password is still the default or it does not have one.
(This means anyone who knows your router maker and model can easily break into your network and systems and steal your info, the router maker is broadcast by your wifi SSID, so they know it)
2. WPS is enabled and active (WifiProtectedSetup)(this service is a major security hole that is used by hackers to gain access to routers, it must be disabled for protection)
3. The wireless (wifi) connections are open (not encrypted), anyone can intercept the wireless traffic and read it. WPA2/AES encryption needs to be configured for the best protection.
4. The router's built in firewall may not be configured correctly exposing you to drive-by hacking.
To resolve these issues requires someone who understands router security and is best done onsite.
You need to engage someone you trust to check and configure your router and computer systems properly to protect yourself.
Mar 23, 2015 | Compaq Computers & Internet
I got a Netgear WNCE2001 today. My router is a Verizon router. (The one with the WPS button on the front.) The security password is in WEP. When I try to connect it with WPS, the light on the WNCE2001 just...
which light is blinking ?
may be this help you ?
2. Select a radio button.
• Push and Connect (recommended). Either click the button or press the WPS
button on the rear panel of the Internet adapter.
• PIN Number. Select the radio button and a PIN displays.
The Internet adapter tries to join the wireless network for 2 minutes if you are using Push
'N' Connect, or 4 minutes if you are using a PIN.
3. Go to the router.
• If you are using Push 'N' Connect, press the router's WPS button.
• If you are using a PIN, log in to the router and type the PIN from your Internet adapter
in its WPS screen.
4. Go back to the computer that is connected to the Internet adapter, and make sure that you
are connected to the wireless network.
• When WPS is running, the WLAN LED blinks, alternating between green and amber.
• If the computer does not to connect with WPS, the WLAN LED is solid red for 5
seconds.
• If the computer does connect using WPS, the WLAN LED is solid green for 5 seconds
Then the WLAN LED returns to indicating a wireless signal.
Feb 12, 2014 | NetGear Computers & Internet
Wps button tab pin
try changing your browser. Yours maybe not 100% compatibel with the modems pages.
best regards & merry Xmas
Dec 25, 2013 | D-Link DIR-600L Wireless N 150 Home Cloud...
Wolsey wps 100 1
Google the product then the connectors
Jun 12, 2013 | Computers & Internet
Where is the wps button
https://www.manualslib.com/manual/382487/D-Link-Dcs-932l.html?page=13
Apr 08, 2017 | Motorola Computers & Internet
Where is the wps button on my 2wire router?
Is your "router" a Gateway? Does the front of it look like this pic?
If YES, the WPS isnt obvious. Touch the WiFi logo. Thats the button
Apr 30, 2011 | 2wire.net
100 Ft. Cat 5e Cable damaged
I suggest soldering them, it is real easy and I could walk you through how but it would still work if you twist the together and elecrtical tape them off. Also were at on the cat 5 is it exsposed? If it is near the end you could just put a new plug on it.
Mar 18, 2009 | Cat5e 100 Ft. Cat 5e (100FTCAT53)
Computers & Internet Logo
194 people viewed this question
David Payne
David Payne
