Question about Eliminator MotoMaster Mobile Power Inverter 700w
I just bought a 3000 watt eliminator inverter from canadian tire it is a motor master and am not sure of the instructions on how to wire it as it has two seraperate sets of negitive and positive poles do I run two negitive and positive wires to the battery or place a juntion block between
  • 1 more comment
  • wade holland Aug 01, 2013
    What I am looking for is the correct way to hook up my moto master eliminator 3000 inverter so I can use it to run some of my 120 volt appliances in my RV. when we are not connected to power the inverter as two positive and negative hook up ports and by the instructions I have show both connected so do I connect
    Add a Comments
    both positive and negative ports to the battery or just one set
I have a 1000w eliminator inverter and its only putting out 100w. what do you think?
Hi....if you should be needing a 3000W inverter. No way you should use a 3000 watt inverter. Using an oversized inverter will needlessly draw power from the battery. Be aware that 100 watts of power used is 1 amp of battery power used. You have not said what size battery you have but most likely I am going to guess either a group 24 or 27, which means you only have 40-45 amps of battery power that you can use before you start damaging your battery.
Jan 10, 2018 | Inverter Electronics - Others
What does opp stand for on a motor master 3000 watt inverter
Unit is shutdown with display showing "OPP"
Inverter is short circuit and has shut down.
Reset to normal operation by using manual switch
Nov 26, 2016 | Inverter Electronics - Others
3000 watt eliminator with OLP and LUP CODES any Ideas
Assuming you have a 12VDC In 120V AC out 3000W inverter.
LUP indicates battery voltage is low, so firstly make sure:
1. You 12V battery is good, it's large enough a minimum of 75AH and probably much larger is recommended and it's fully charged.
2. Verify you are using the correct size copper wires from battery to the Inverter DC INPUT(s). If you keep wire short the wire size can be smaller, but if the DC input wires are longer then you will need to use thicker copper wires.
At MAx load you would be taking 250 AMP from battery, so for a 5% Volatge drop of .6 V for a 10 ft length of cables from battery to Inverter you would need to use a 1AWG copper cable.
http://www.calculator.net/voltage-drop-calculator.html?material=copper&wiresize=0.4066&voltage=12&phase=dc&noofconductor=1&distance=10&distanceunit=feet&eres=125&x=37&y=8
OLP is a overload condition, which means you may have to many high powered AC powered things connected to the Inverters AC outlets or maybe something that has large start up surge, ie devices large electric motors.
Or it could be all due to a faulty Inverter.
Oct 22, 2016 | Eliminator Electronics - Others
My 3000 watt inverter says "lup" on the display
This question is solved in detail on a different page here on Fixya by user Pierre Curtis in detail. It's very well written. Rather than repeat, just click this link:
http://www.fixya.com/support/t26322938-3000_watt_eliminator_olp_lup_codes_any 3000 watt eliminator with OLP and LUP CODES any Ideas
Nov 09, 2013 | Eliminator MotoMaster Mobile Power...
My 3000 watt Duracell inverter will not start a 1 1/2 hp electric motor. The voltage drops to 45v and the electric motor struggles to reach full rpm. This is a table saw with no load. The generator revs...
have the saw motor checked for internal and wiring problems
check the start/run capacitor of the electric motor
running a 1 1/2 hp motor (1075 watts) on a generator that has a running wattage of around 2250 watts means that it should start and come to speed immediately if the motor is good
the problem indicates that there is a circuit problem in the saw motor that is exceeding the available wattage (3000 watts ) on start up
Oct 22, 2017 | Duracell DS30R1i 3000 Watt Continuous...
Looking to talk to someone that makes eliminator batteries i bought one for my envoy not even twon years ago from canadian tire and now can't find the reciept and i really don't want to pay another...
YOUR ALTERNATOR NOT WORKING.HAVE BATTERY CHARGED UP.YOU SHOULD HAVE 12.6 VOLTS IF BATTERY FULLY CHARGED OR NEW.START THE ENGINE.WITH ENGINE IDLING YOU SHOULD HAVE 13.5 - 14.5 VOLTS AT THE BATTERY.IF NOT.ALTERNATOR NOT CHARGING BATTERY.BEFORE REPLACING ALTERNATOR, MAKE SURE DRIVE BELT NOT SLIPPING,CHECK ALTERNATOR FUSE,CHECK ALTERNATOR POWER FEED WIRE AND VOLTAGE REGULATOR WIRES FOR DAMAGE AND LOOSE CONNECTIONS. BEFORE DISCONNECTING NEGATIVE BATTERY CABLE TO MAKE REPAIR, TURN OFF RADIO FIRST TO KEEP FROM LOCKING IT OUT.
Jul 12, 2011 | GMC Envoy Cars & Trucks
My microwave will not work with this new inverter, it is a 650 watt microwave. It will not work in any plug but all other things work in each plug including 1500 watt elec skillet and 900 watt coffee...
There are a couple of possible explanations for this. I have no way of knowing how well your inverter is wired. If you have followed standard inverter wiring guidelines for an inverter of this size you will have eliminated that as a possible problem. Your microwave is more than likely at least 1100 watt input power consumption. I am not familiar with this brand. Some off brands make claims that are substantiated by questionable testing. Your initial surge should be no more than 2200 watts, well within the capabilities of this inverter. My guess would be that your problem is probably with your wiring. If you feel that the wiring is without defect, you may have a faulty unit. I know that dollars are always an important consideration, but I suggest purchasing as large a unit as you can afford and one that exceeds your requirements. Best wishes...
Aug 24, 2010 | RTO ATD-5954 1500 WATT INVERTER
Canadian tire says tests fine. bought new battery,
open hood and check pcm wiring harness its located in the left back end of the engine compartment looking at it from the front of the vehicle. the wiring tends to become very loose
Feb 12, 2010 | 1994 Jeep Grand Cherokee
Lost AC charger and lighter adapter - need replacements
Although the MotoMasters are quite popular and are excellent products in most folk's opinions, parts are quite difficult to find. Complete units are in abundance.
Your charger doesn't have to be branded MotoMaster. And charger of approximately 500 to 750 mA and approximately 14 volts will work nicely.
From time to time Canadian Tire have some parts or open box sales. You might check with them. Hope this helps!
Sirwriter
Nov 06, 2009 | Eliminator MotoMaster Mobile Power...
Eliminator MotoMaster Mobile Power Inverter 700w Logo
123 people viewed this question
Top Eliminator Electronics - Others Experts
ottworld5982
Mark Magill
Mark Magill
Tom Chichester
Are you an Eliminator Electronics - Other Expert? Answer questions, earn points and help others
