Question about Danby Refrigerators
When I plug in my Danby premiere dpac9009 it starts beeping and shows an error code AA and under that HA . It wont start and i have to unplug it to stop the beeping.
4 Suggested Answers
SOURCE: Danby Kegerator is beeping and flashing EE and won't cool
I am having the same problem seeing if you found a fix??
Posted on Feb 15, 2010
jetimanski
  • 13 Answers
SOURCE: I've owned it for about a year and have not had any trouble. But my Danby Kegerator just started beeping and flashing EE on the display one day and it won't cool. I had to unplug it. Any ideas
An EE error code means that you have loose connections (loose temperature sensor connections) check all the wires for a loose connection
temperature touch pad
the units main control board
the control board is in the back of the unit there is a panel covering in the middle lower back near the compressorInside your unit on the left side in the lower rear theres a vented piece of plastic pry that off thats the temperature sensor make sure all the connections are tight
If the error does not clear then your temperature sensor is faulty
you can get a new sensor at
www.repaiclinic.com.or
or at
www.appliancepartspros.com
hope this helped
Good Luck!
Posted on May 02, 2012
Sea Breeze
  • 4655 Answers
SOURCE: Frigidaire fridge will not stop beeping and will not turn on
The only thing that I know could be causing the problems is the=> 5303918476 Defrost Control Board
This part is behind the control panel inside the fresh food section where you adjust the temperatures. Let me know if you have questions, Thanks Sea Breeze
You obviously have the wrong model number listed on your post. ?? What is the correct model number listed on your model? The model mentioned in your post has mechanical thermostat and yours has didital.
Posted on Mar 25, 2013
Showing error codes. E2. F6
If you wish to get some details; check the site linked here. Pull up older posts....
http://electro-medical.blogspot.com/
Apr 25, 2016 | Office Equipment & Supplies
Danby premiere shows stop message and wont turn on.
Your internal tank might be full of the condensed water. You may need to drain it
May 17, 2015 | Danby Heating & Cooling
Danby premiere dpac 12010h does not fully start, shuts off, repeats
Unlikely to be a capacitor but they aren't expensive to replace. More likely to be compressor failing to start, or controller faulty. Try powering up the compressor and fans to see if they run independently of the controller
Aug 07, 2012 | Danby Premiere Series DPAC12010H 12,000...
I have a Danby Premiere mobile ac unit and it has been working just fine, as of yesterday it all of a sudden just quit working. I can plug it in and it will run for a few seconds and then quit. once i
Hi There,
I would like to help you with this but I need some more information.
Is the display showing any error codes?
Is there a red light blinking?
From what I have learned from a technician, with the weather being so hot and humid in most areas it is likely that the water bucket is full.
If this is not the case, please either respond to the questions above and I will look into this further or you can contact our Customer Service department at 1-800-26 Danby for assistance.
Thanks!
Jul 18, 2012 | Danby Premiere Series DPAC12010H 12,000...
Error code 40, found problem, still wont start
you can disconnect the battery to clear the codes. If I remember correctly the code 40 is indicating an open injector circuit. You might want to check that area as well as the service manual for more detail
Nov 15, 2011 | Yamaha YZF-R6 Motorcycles
Aug 26, 2009 | Danby DKC645BLS Compact Beverage Cooler
My microwave buttons dont work on my danby microwave, after a few hours it started beeping and asking for a code. what is the code
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for maybe an hour.
If it still isn't working I would contact Danby Customer Service US / Canada.
Jan 08, 2009 | Danby DMW1146SS Microwave Oven
Buttons dont work on danby microwave
If it still isn;t working I would contact Danby Customer Service US / Canada.
Viking Electric oven beeping saying EOCGT v36 premiere poweringup
Sounds like leaving the door open has possibly cooked the controller. I would try a power cycle - power off at fuse for 5 minutes, then reapply power. If this doesn't clear it, you may need a new controller for it.
Nov 27, 2008 | Ovens
Danby microwave m # 1153
danby dmw11536 my microwave oven start beeping all the time. i can start it if ipush the cancel button, ordinarely once but sometimes it won't start unless you unplug it. also disylay shows 1:00 but keep time of cooking anyway. after it returns to beeping all the time, sometime you have to leave it unplugged for a couple of hours. danby dmw11536
Aug 27, 2007 | Microwave Ovens
Open Questions:
Danby Refrig DFFC1WDB, two years old, in my vacation home that I visit one weekend a month. Lights flashing, power cycled (after req'd 5 mins). Discovered coils were packed with ice. See below: 1.) Danby Refrigerator DFFC1WDB, about two years old, in my vacation home that I visit one weekend a month 2.) Never defrosted it manually before (i.e. turned off and left to defrost) 3.) For some time I noticed the light inside the fridge was flashing, but the refrigerator seemed to be cooling okay and the manual says nothing about what the flashing light means. I attributed it to a power failure and the flashing stops once the unit is unplugged and plugged back in (power cycled) after 5 minutes or so. 4.) This visit I noticed the flashing lights again and that the freezer was cold (it was heavily loaded) but fridge was barely cool. I power cycled the fridge (allowing 5 minutes) and the flashing stopped but I was concerned about the issue and threw out some food. 5.) I unplugged the unit again and removed everything from the freezer. I noticed a thick coating of ice on the freezer back wall. I used a hair dryer to melt this coating of ice and then realized that the coils behind this wall must be covered in ice. I removed the back wall exposing the coils and discovered that I was correct: The coils were completely covered/packed with ice, so I greatly sped up the melting process with the hair dryer. After all, I had food sitting in coolers with ice and wanted to return it to the freezer and fridge asap. 6.) Once all the ice was gone I left the freezer open for a while for the coils and assembly to cool (since I had used a hair dryer to melt away the ice pack) 7.) I set the freezer and fridge to their coldest settings and plugged it back in. The lights do not flash when I plugged it back in. The compressor (I assume) ran for a while (the fan in the freezer ran also), and during this time I heard the unit lightly buzzing (with life), and then it stopped. But it seemed to have quite a way to go when it stopped and the freezer and fridge were not nearly cold enough at that point. I surmised that it might be entering one of its periodic defrosting periods, but after quite a while of waiting it still hadn't started running again so I power cycled the unit again and again the compressor/fan ran for a while and then stopped. It just doesn't seem to be starting on its own unless I power cycle it (waiting the required 5 minutes before plugging it back in.) At this point I don't have confidence that it is cooling well enough to keep my food fresh (and frozen). 8.) What do you think could be wrong? It certainly seems reasonable that the part/system responsible for periodically defrosting the coils may have failed. But since the unit is completely defrosted now, why does the unit only run for a short time after unplugging/replugging and never run again?
Jun 10, 2018 | Danby Refrigerators
Refrigerators Logo
85 people viewed this question
Top Danby Refrigerators Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
jason
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
