Question about Canon MultiPASS MP730 All-In-One InkJet Printer
Printer I am trying to copy or print and error is coming up stating wrong cartridge and I have had the same cartridge no changes I even printed 1 week ago
  • deeo Jan 31, 2008
    I also have this Printer & I love it. Mine also has the same Error message.
    Nothing I have done works. How do I reset the Printer? Dee
YDOC is correct above. You will need to replace the print head. You can "reset" the printer and clean the printhead but it is only a temporary solution.
Posted on Dec 04, 2007
Posted on Nov 03, 2007
  • 390 Answers
The printer is not reading the cartridge properly. You may have clogged nozzles/printhead. Do a claen (deep or other) that is in your printers maintenace area. Then try to print. No luck, then remove cartridges, do a thorough manual clean by using proper cleaning solution and cotton buds(q-tips). If the cartridge has its own printhead (gold areas) wipe the gold area that goes against the printer carriage, ie the one the ink comes out of, be careful, do not wipe any other gold areas, only the one the ink comes out of. Press the cartridges firmly one by one on a folded wipe and hold a moment, when you lift off, you should be left with a clear vertical line of three colours, and the black one should be same but black. The marks should be dark and bright (ink) not patchy or missing colour etc. (i use unscented baby wipes-huggies!!! don't laugh they work great, i have never had printer problems apart from usual things like a toddler jamming it with toy!!!) Put cartridges back. Try reprinting. Good luck!!!
Posted on Aug 31, 2007
Print job disappearing and not printing
1. Check for a paper jam. Paper jams occur when one or more sheets of paper become stuck in the feeding or printing mechanism. Gently remove any jammed paper and reset the printer.
2. Check ink levels. Those ink cartridges run out fast. If your printer looks like it is printing but nothing comes out on the page, you might be out of ink. Try replacing the cartridge and printing again.
3. Check for a clogged print head. If you know you have ink, the print head might be clogged. Navigate to "Control Panel > Printer > Right Click > Properties > Maintenance > Clean Cartridges" to attempt to clean the print head.
4. Reinstall printer drivers and software. If none of the above helps, try uninstalling and reinstalling the printer and software to correct possible software bugs, errors or conflicts.
Canon-Specific Issues
5. Check printer drivers. Navigate to "Control Panel > Printers > Right Click > Properties > Update Driver" to check for a new driver for your printer. You can also find drivers and software on the Canon Support site (see Resources).
6. Resolve the Waste Ink Error. Press menu on the printer and press scan/copy to enter service more. Press the right arrow to access "NVRAM." Set ABS-M level to 0. Set ABS-P level to 0. Press "Stop" to exit.
7. Resolve Wrong Cartridge Message. Turn off the printer and unplug the power cord. Remove the cartridges and the print head. Clean the print head in lukewarm water. Set it aside to dry. Clean the contacts gently with an eraser and wipe with a tissue. Reinstall the print head and reinsert the cartridges. Run a cartridge alignment.
8. Resolve E0D02 error. Clean the cartridges and the sender strip. The sender strip is behind the rubber drive belt behind the main hatch. It runs horizontally across the machine. Wipe it gently with a lint free cloth.
Aug 19, 2012 | Canon Pixma Mp250 Printer
The printer states that their is an automatic alignment problem does not print the black even if a new cartridge is inserted. What could the problem be?
Open the printer cover and remove both cartridges. Check the cartridge area for any obstructions or foreign objects blocking the cartridge carrier path. Also, try to check for the encoder strip (transparent strip behind the cartridge carrier) and make sure it is not unseated from its position. The encoder strip helps with the mechanism of the cartridge carrier in the assembly.
When cartridge is clear and looks normal, close the printer cover. Unplug/re-plug the printer into the power source to reset it. When the printer turns on, firmly re-insert the cartridges. If no error appears on the printer screen, try to print again.
If problem continues, please contact Lexmark Technical Support Center for additional assistance.
Sep 02, 2011 | Lexmark X8350 Print, Scan, Copy and Fax...
My HP Photosmart 8250 Inkjet printer is not printing black ink. If I let it sit for a while and only print 1 copy it will print a pretty good copy. Additional copies are almost blank but will have color...
try to reinstall the printer driver software. you can download the latest printer driver software from yout printer manufacturer's web site then restart the computer and printer.
Jun 11, 2010 | HP Photosmart 8250 InkJet Printer
Error 1203
error 1203 means either or both cartridges have short circuited and needs replacement..
You will need to perform the following steps to find out which cartridge is defective:
1. With the printer turned ON, open the front cover and remove both cartridges from the printer.
2. Power the printer OFF and unplug the power cable for 30 seconds. Plug the power cable back in and turn ON the printer.
3. If the error message is now cleared from the printer, please perform the "Self-Test" by following the steps below:
1. Make sure the printer is in “Copy Mode.”
2. Press the “Menu” button once.
3. The screen will display “Copy Menu: Copies”.
4. Press the left arrow button once. The screen will display “Copy Menu: Tools”.
5. Press the check button once. The screen with read “Tools: Maintenance”.
6. Press the check button once. The screen with read “Maintenance: Ink Levels”.
7. Press the right arrow button until the screen reads “Maintenance: Print Test Page”.
8. Press the check button once. This will start the Self-Test. Once the page has printed, the printer will stop. The test is not continuous.
If the printer has detected a "Cartridge Missing" error, then please follow the steps given below:
1. Turn the power OFF.
2. Open the front cover.
3. Turn the power back ON. The print cartridge carrier should move to the install position located in the middle of the printer. If it does not, close and reopen the cover:
4. Reseat both cartridges in the printer and check for the error.
5. If the error still displays, then remove the color print cartridge.
6. Close the cover.
7. If there is no error indicated by flashing lights, the color cartridge has short-circuited.
8. However, if you continue to get an error, repeat steps 1-3, and then go to step 9.
9. Remove the black print cartridge and reinsert the color cartridge.
10. If there is no error indicated by flashing lights, the black cartridge has short-circuited.
11. If you continue to receive an error in both cartridge scenarios, both print cartridges have short-circuited.
Apr 23, 2009 | Lexmark X5470 All-In-One InkJet Printer
Wrong cartridge?
Doubled check the cartridge numbers and that they match what is on the printer. If no match get correct ones.
Oct 24, 2008 | HP PSC 1410v All-in-One Printer
Error: Wrong Cartridge
Yup I had the same problem and there is only 1 valid solution. Change the print HEAD. its a removeable item that is easily replaced. all you need to do is remove the ink cartridges (All) and flip up the lever where the cartridges are . This will allow for the removal/replacement of the head assembly. You can alays try cleaning this head assy with (Ammonia D) just in case you are one of the lucky one just to have a defective connection. Note: Worked for me and everyone else I ever saw with this error. (I bought my head on ebay)
Aug 09, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Cartridge problems
Clean the heads, printer is not reading new cartridge or refilled cartridge. You may also have a paper jam if alignment is affected. Check for little jams, post back if no go lilacgerry xxx
Dec 28, 2007 | Lexmark X4270 All-In-One InkJet Printer
Printing Error
try changing the ink cartridges.
This may have happened due to low ink levels. Also try reinstalling the printer driver.
If the print cartridges are damaged this problem will pop up. Even static electricity in human hand could damage the print cartridges.
Oct 07, 2007 | HP PSC 2355 All-In-One InkJet Printer
Not copying or printing
Your printer is telling you it cannot allign the cartridge due to tape, did you remove all the tape off a new cartridge? I use the cleaning solution that comes with the ink refil kits to clean the printer heads and bottom of contact, and have you checked for roller jams, paper jams etc inside unit itself. Also, could be a commincation error. Try turning off unit, unplugging it and reverse, try agian, this resets it. Good luck, post back if no go cheers lilacgerry xxx
Sep 29, 2007 | Lexmark X6170 All-In-One InkJet Printer
Canon MultiPASS MP730 All-In-One InkJet Printer Logo
297 people viewed this question
old marine
old marine
