B&k st140 schematic - Audio Players & Recorders
How to adjust bias and DC offset
Ok you need some tools for it: Oscilliscope, Multimeter.
And here is the link:
http://www.audiokarma.org/forums/showthread.php?t=5634
Aug 09, 2014 | B&K Audio Players & Recorders
Appear to have broken belt guide to drive cutters
i would check the manufacturers parts website
Mar 04, 2014 | Garden
Schematic for orion HCCA-D2400
The schematic or service manual doesn't appear to be available online. You may have to contact Orion. Verify the REM input to the amp. It should be 12V when the car is on and 0V when the car is off.
Jan 15, 2014 | Orion HCCA-D2400 Car Audio Amplifier
Bolens st140
If you have a manual check for all their safety features such as seat. If the seat has an electrical plug connected to it, bypass it and see if it starts. Do the same thing with any other safety features to eliminate that problem. There are times when safety switches stick, make sure if button operated, that button moves freely in and out. Check to see if you have current going to starter to determine if the problem exists between ignition and starter.
Jun 08, 2013 | Garden
Blowing fuses in my bolens ST140
when is the fuse blowing while cranking or when just turning on the key when the blades are turned on
Jun 09, 2012 | Garden
There are some burnt carbon resistors beyond recognition on a peavey tnt bass combo.so I need the schematic diagram
Try these schematics:
http://elektrotanya.com/peavey_tnt115s_sch.pdf/download.html
http://elektrotanya.com/peavey_tnt_100_1974.pdf/download.html
Scroll down to "Get Manual" at the web page and click on it to download.
Please note that on the first schematic above, the power amp schematic is way down beyond the parts list and layout of the preamp section... keep scrolling. ALSO the powoer amp shows a real WIERD connection where the output transistors drive against ground and the center tap of the power supply transformer for the power amp portion then bounces around with the audio output... that is a wierd connection but it is possible.
May 23, 2011 | Peavey Max 126 10 Watt Combo Bass...
I need to know how many wires go to a 1989 ford econoline fuel pump with a 460 efi engine
I suggest check this wiring diagrams for code color wires...
1989 5.0L & 5.8L & 7.5L ENGINE SCHEMATICS
1989-91 CHASSIS (GASOLINE)SCHEMATICS
1989-91 CHASSIS (DIESEL) SCHEMATICS
Hope this help.
Mar 23, 2010 | 1989 Ford Econoline
I have a Cobra 21- 23 channel CB and the wires pulled out of the plug. The mike wire has red,yellow black,blue,whiteand a ground. My plug has only four prongs to solder to. What four colors do I use?
Hello there
Here is the diagram for you
Cobra 29LTD, 29LTD ST, 29WX ST
Documentation Project
CBTricks.com
TIPS:
You need to have Acrobat Reader version 5 or newer installed to view the files with pdf_1.gif icon.
If the files with jpg.gif or gif.gif icon will not display see the Site FAQ for help on printing, viewing and using this information.
Click Picture to See Close-up
DIAGRAMS
Page 1 to 11
Page 12 to 34
29LTD
29 LTD Classic Schematic Diagram pdf_1.gif(Courtesy of Rick Jackson)
Mic Wiring
Stock
1- Shield
2- Audio
3- Transmit
4- Receive
Astatic (4 wire)
1- Shield
2- White
3- Red
4- Black
Astatic (6 wire)
1- Shield & Blue
2- White
3- Red
4- Black
Yellow NC
Daiwa EM-500
Cobra CA Series
1- Shield & Black
2- Red
3- White
4- Blue
Galaxy DC-521S (4 wire)
1- Shield
2- Yellow
3- Red
4- Black
Galaxy CB-660EI
1- Shield & Black
2- White
3- Red
4- Blue
Sadelta
1- Shield
2- White
3- Brown
4- Green
Turner
1- Shield & Red
2- White
3- Blue
4- Black
Yellow NC
Nov 17, 2009 | Cobra 29 LTD CB Radio
102 people viewed this question
 Grubhead
Grubhead
