Question about Maytag MFD2560HES Bottom Freezer French Door Refrigerator
Maytag fridge freezer GC2225GEKB freezer not working. Lights up, husband says compressor working. Fan is off. Turn power off then back on, fan goes on, but switches straight off., What do i need to replace
Krazytech
  • 725 Answers
SOURCE: Maytag MZD2766GES side-by-side Refrigerator warm
is it frozen up? do you have any air flow thru the air tunnel from the freeze to the fridge? Check your air flow with the door switch pushed in. also check to see if the damper door opens... 1) if it is iced up you have a defrost problem. most likely a defrost timer. Turn off or unplug untill all the ice has melted off the evaporator back of the freezer..plug back in and it will work fine untill the ice builds up again. if this work you do have a defrost problem.. if not let me know and we can go deeper...
Posted on Aug 18, 2007
mikedurland
  • 481 Answers
SOURCE: Maytag MSD2651HES fridge not cooling freezer works find
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Posted on Jul 06, 2008
tborn6
  • 700 Answers
SOURCE: Fan running,both cold settings at 4 , freezer 14 degrees C
you need to replace the start components on the compressor, theres a relay that mounts on to the compressor that takes out the start winding after it starts the compressor up. You can also try whats called a three in one to try to start up the unit. Good Luck.
Posted on Mar 28, 2009
  • 363 Answers
SOURCE: maytag mff2557hew fridge not cooling. Freezer ok.
Sounds like the Freezer Fan is wearing out or is worn out. This fan problem is very hard to detect. The reason is that when the motor is starting to wear out the fan will spin, but at a much lower rpm. This is enough to keep the freezer cold. but will not ciculate enough air thru the freezer and the refrigerator to prevent freezer from and refrigerator from cooler. The cost to repair/replace this fan is a minimum of $300.00
Posted on Jul 28, 2009
Testimonial: "Your solution was right on the mark! The fan was spinning but not fast enough (according to my repair guy). Thanks again!"
  • 257 Answers
i am not a expert just trying to help,,, try pulling fride out and checking the line from freezer down to the pan and made sure it is clear,cause this will keep the air from flowing,, hope this help
Posted on Oct 20, 2009
RF267aewp french door refrigerator is acting crazy. Sometimes compressor fan runs, sometimes it doesn't same with freezer fans. Front control panel will not respond so I cannot get into diagno
Had same problem on my fridge a long time ago. Here is what was wrong on mine. Debris had clogged up around the fan blades to the point where the very small motor that runs the fan was not powerful enough to make the fan turn. When this happens the compressor has to work harder and harder until it finally shut down on safety cutout. I had to open the back of the fridge and clean up the fan blades, [ took the opportunity to put a small amount of oil on the fan shaft too, my Norge fridge is now over 50 years old.]
Nov 05, 2014 | Samsung RF267AEWP - 26 cu. ft. French Door...
Why would my Maytag MFX2570AE 4 door french door fridge motor/fan run constantly?
if the compressor goes off and only the fan keeps working thats broken fridg but fan is not a big energy drainer on bill if the compressor works allways it might be to hot in the room or door is not seald or totaly closed give it a strog push when closing or maybe you have under floor heating so you have to insulate bottom from heat or maybe its not insulatdd well from heat of compressor
May 20, 2014 | Maytag Ice2O MFX2570AE 25.0 cu. ft. French...
2005 Maytag Refrigerator Fan Stopped WOrking
What is the model number and is the compressor kicking on?
Oct 28, 2012 | Maytag Refrigerators
The refrigerator has quit working. Lights come on and fan appears to be running. Not cooling
Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay. Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
If it's iced up really heavy you have an auto defrost problem. Melt the ice with a hairdryer and check the defrost system.
Oct 12, 2010 | Maytag MSD2756G Side by Side Refrigerator
My fridge clicking, buzzing and then clicking back off. Inside it was starting to warm up and was starting to leak water onto the floor. Today someone came out and replaced the relay. After 4 hours the...
Hello, no if the compressor is still running and you are not hearing the click you should be ok. It will take approx 8-10 hours for it to get to normal temp. The frost you mention on the freezer panel could be a problem with the defrost system. I would leave it over night and check it tomorrow. If there is a major ice build up comment back and i will assist you further. Mike
Oct 19, 2009 | Maytag Refrigerators
MAYTAG MODEL# MQU1556AEW, HAS POWER, LIGHT COMES ON, QUIT COOLING, WE LIVE IN THE HILLS, NO APPLIACE REPAIR PEOPLE, HAVE ELECT TESTER AND BASIC KNOWLEDGE, I COULD USE DIAGNOSTIC MANUAL OR HELP,, THANKS
If the fan in the freezer is working , but the compressor is not , then the overload/relay is bad ( pt # 4356738 ) . If you hear nothing , then the defrost timer is bad ( pt # 4357124 ) . This part looks like its located close to the compressor or in one of the corners of fridge on back with about 1/2 " hole to access manual turning slot . Turn the slot and see if fridge starts .
Aug 24, 2009 | Maytag Freezers
Freezer works fridge doesn't both worked yesterday today fridge wont
Hi, Check and see if the condenser fan motor down by the compressor is running. Sometimes when they get moved, something will get into the blade and stop fan.
That will overheat the compressor and cause it to shut off on safety. If that fan is running, check the fan inside freezer and look to see if frost is building up on inside rear freezer wall.
Please let me know if this helps you or if I can assist you further.
Vic
May 30, 2009 | Refrigerators
Maytag model (MTB1950GR) tripped off the power switch and smell
Hi, It sounds like the relay onyour compressor. They will smell when it goes bad. Remove the rear panel on the back of the refrigerator and see if the smell is around the compressor.
Please let me know If I can assist you further.
Vic
May 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Compressor very hot + water leaking
This is not normal. The coolant charge is low which means it leaked out some where. Return it.
Dec 22, 2008 | Sub-Zero 650 / O Bottom Freezer...
Refrigerator stopped working, freezer works fine
Sounds like the evap fan is not running. The fan takes cold air from the freezer to cool the refer compartment. If the freezer is cold the compressor is running. Generally the freezer will stay cold since the cooling coils are there but it must have the fan working to get the air up to the refer area. Pull everything out the freezer and take the back panel off to view the coils and fan, etc. It's a simple easy job to change the fan. If you find the coils are a total block of ice then it's another problem... the defrost cycle isn't working. Sooo... see if the fan is running in the freezer compartment first. See http://www.partselect.com/Schematics/Maytag/AA43-57.gif for fan location, item 18 is the fan motor. Let us know what you find out.
Jan 02, 2007 | Jenn-Air JFC2089HE French Door...
Maytag MFD2560HES Bottom Freezer French Door Refrigerator Logo
74 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
