Question about LG 42LE5500 42 in. TV
LED TV LG 42LE5500 soft touch keyboard blocked. i cant operate the tv because the buttons (touch sensitve at tvs front panel (power, volume)) behaves af if they were pressed and no other comen will take effect. the tv wont respond to the remote control neither. what can i do?
SOURCE: LG 37LC7D remote doesn't work
 I heard that Best Buy is still selling these models despite this known problem- I am trying to have mione fixed but was told the replacement part is on back order until DECEMBER!
Posted on Oct 31, 2007
jerryg50
  • 1667 Answers
SOURCE: LG TV 32LB9D VOLUME STUCK AT 100, NO RESPONSE TO REMOTES
The fault may be on the control board. Sometimes the button switches can be stuck, or there may be something causing some conduction on the control circuit board. It is also possible to have a component failure that is causing a continuous command to keep the volume to the high position.
Something that causes failures of controls in TV sets is when people clean the screen, they spray liquid cleaner on the screen. Some of it drips down in to the controls and on to the circuit board. This will usually cause damage, and thus the set will require shop service.
Jerry G.
Posted on Apr 10, 2009
  • 4 Answers
SOURCE: LG TV no longer responds to the remote control..
I have had the exact same problem with my 47LG70 after 13 months of use. I changed my remote control sensor but it did not help. Before you do that, try something simple which seems irrelevant. On this website, others have posted success by plugging in any standing set of headphones into the remote control or headphone jack on the rear TV panel. This solved my problem. So I proceeded to thoroughly dust all of the input/output component jacks on the rear and side of the TV with an air-can. This solved my problem and I do not need to have the headphones plugged in. So try these two things before changing the sensor.
Posted on Jan 23, 2010
SOURCE: LG 26lx1d tv will not turn on. Power supply is
Have an LG26Lx1D for about 3 years, dropped off by my son.(Figures).Power light just blinking, but went back to red.Removed back panel, and metal cover. Just above antenna/cable input, its a small fan,mine was full of dirt. Blow off dirt, and make sure its turning freely.
Install back the covers, an voila....its a miracle...its working again.
Good luck
Posted on Mar 21, 2010
  • 3 Answers
SOURCE: My New LG LED TV
you can down load your manual from this link, i did notice that your product number is not listed in full or has been removed . if you add 00 at the end you will still be able to receive a manuel with instrustions for the remote and resetting.
Posted on Oct 14, 2010
When turn on tv,i can see only LG paterrn and no volume no channel not working anythings but i can turn on/off with remote and on the tv
Main digital board fault. Contact any service technician to get it repaired. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jun 02, 2015 | LG 42LE5500 42 in. TV
47lx6500 buttons on tv don,t respond. Cannot switch of the television
touch button module isdead ir module also attached to the same board so replacing it might solve both of your problems
Jul 05, 2014 | LG 47LX6500 47-Inch 3D 1080p 240 Hz LED...
My television will not respond to either remote or button inputs. Is there a hard reset procedure that may possibly resolve this issue?
there's no such button to your tv set . theres a misfunction on your touch button module the solution is replacing it with a new one
Jun 19, 2014 | LG 42LE5500 42 in. TV
Lg tv 42le5500 restart when start use netcast youtube app
There is a mismatch of communication due to different formats. If you have followed guidelines contained in the operation manuals of both devices, this might require attention by a qualified service technician.
Jul 12, 2012 | LG 42LE5500 42 in. TV
I need help fixn a lg power button
Main ON/OFF switch or soft touch power On button on the front panel of the TV?
Jun 07, 2012 | Televison & Video
Le5500 led tv problem
What is the problem with your LED with bluetooth TV?
Apr 21, 2011 | LG 42LE5500 42 in. TV
I have a brand new Aquos 52" LED TV and I accidentally locked remote operation and THEN found out the front touch screen panel was broken. Any way to manually reset the TV or remote to gain access to...
While the set is turned on, you need to hold the power button until the set shuts off and the led in the middle of the bottom flashes once. Then quickly release the power button and press the vol - and input buttons together along with the power button. Your TV should then turn on and should show you a blue box with the letter K. Now press the vol- and channel- buttons at the same time. You should now be in the service menu. With your remote arrow up until the top line says industry init. Arrow to the right and hit enter. Screen should turn green and say factory init success. I hope this helps you.
Apr 04, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Just bought a 42 inch lg tv and cant programme my
please follow the steps below with you sky remote:
TV
RED + SELECT (hold these down until it flashes twice)
TV
0056
Try the volume button if this works then press SELECT. If it does not work then press TV again then try the volume ( repeat this step until the volume works. Dont forget to press the SELECT button to save the code to the remote.
This should sort you out. Please leave a thumbs up when you get it working.
Cheers Little Dish Fitter
Sep 24, 2009 | LG 42LC2D 42 in. LCD HDTV
Tv screen went blank
sound like the inverter circuit board problem. check & replace back same part# inverter circuit board. hopefully could help!!
Dec 29, 2008 | Vizio L32 32 in. LCD HDTV
LG 42LE5500 42 in. TV Logo
74 people viewed this question
Computer Repairing
Computer Repairing
