Question about Boating
Bought a sevylor trolling motor, and the propeller fell off. They don't sell replacement props so instead I ordered one from watersnake. Its a 2 bladed propeller that came with a nut. The nut does not fit on my Sevylor motor, so instead I went to the hardware store and bought a nut that does fit. But instead of turning the blade the but spins so tight that it stops the prop from moving. I need help.
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
I bought a 6 dollar watersnake pos from wal mart of course it wasnt even close to fitting my old sevylor 12v. So I said wtf it I drilled out a 1 inch hole in that then filed off the old blades on old prop to the hub which was intact. I then used the old hub and cotter pin with liquid metal gobbed inside slid the new watersnake over top and centered and set it. The first problem is the blades are much bigger but wtf am I gonna do. To be continued. Haven't tried it yet..But the concept is sound. I used a paper ring to hold in the liq metal from leaking out while setting and can access cotter pin to boot!! I could file down and reshape blades as well if I find they are to big. But that might be unintelligent. Well more unintelligent than my other unintelligent idea. This is American ingenuity at it's best.!!!
Posted on Apr 19, 2017
    New Friend:
I have the same motor and looking for a replacement prop i found this website. They make custom props out of aluminum
Posted on Jun 08, 2015
5 Suggested Answers
SOURCE: Trolling motor will not spin with out being turned by hand.
This may sound really dumb but it's worth a shot. I bought a trolling motor and it did the same thing as yours. I put up with it until I broke a prop blade. When I was changing the prop I discovered about fifty feet of monofilament fishing line wrapped around the shaft, partially melted, hidden by the prop hub. Once removed, it worked fine. Hey, try it, can't hurt.
Posted on Dec 11, 2008
  • 4 Answers
SOURCE: minnkota trolling motor prop removal
remove the nut and the prop will come right off. Just be careful not to loose the shear pin.
Posted on Apr 30, 2009
  • 76 Answers
SOURCE: need bigger prop with same pitch as old one
Minn Kota doesn't supply any other props than the stock ones for a reason....if you install a larger prop, it takes more power to turn it at the same speeds. More power (amp draw) means more heat....more heat means blown electronics. Be careful, in their warranty they state that installing an aftermarket prop will void the warranty. For good reason too! I've seen the damage that can occur.
Best of luck
Posted on Sep 26, 2009
  • 71 Answers
SOURCE: Minn kota trolling riptide 70, prop spins freely, sheared pin, retaining nuts turns freely, cannot get prop off, any suggestions
Use a gear puller.
Posted on Jul 27, 2012
Only have a model number and need to order a Minn Kota electric motor propellor
Minn Kota go by the thrust which is mentioned on the top plate. I got mine off Craigs List as well.
  • Minn Kota Prop Compatibility Chart - Minn Kota Prop Compatibility Chart Minn Kota Prop Charts. ... Minn Kota with a serial number and they can recommend a compatible prop for your older Minn Kota motor. ...
  • Minn Kota Motors Prop Selection & Part ... Electric Anchor Winches; Shop All; APPAREL. ... A combination of a Minn Kota motor and foot controlled rudder steering allow you truly ...
  • Trolling Motor Replacement Props - Minn Kota Minn Kota builds the world's toughest ... Electric Anchor Winches; Shop All; APPAREL. Mens; Ladies; Youth; Shop All; WHAT MOTOR DO I NEED? LET US HELP YOU ...
  • Minn Kota Replacement Propellers - www.fishntech ... Minn Kota Electric Trolling Motor Replacement Propellers & Nut Kits, ... Minn Kota Replacement Propellers . ... Minn Kota Electric Trolling Motor Replacement ...
  • Minn Kota props replacement props for Minn Kota Minn Kota Replacement Props for propellor Weedless Wedge 2 Props ... Minn Kota MKP 3 Prop 2061151 ... MinnKota Trolling Motor Power Center $57.58; DeckHand Electric ...
  • MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ' ... Find best value and selection for your MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ... MINNKOTA MKP 37 2091170 TROLLING ... MINN KOTA ...
  • Jun 08, 2016 | Minn Kota Endura 30 Freshwater Transom...
    Motorguide trolling motor
    The first thing to check,(After making SURE the electricity is disconnected to the trolling-motor) remove the propeller and see if the shear-pin (Usually made of brass) in in place and not sheared/broken.
    If it is, your local marine shop should be able to provide a new one. I always carry spares. If the pin is OK, the windings may have an electrical fault that would require a factory-repair.
    Sep 05, 2014 | MotorGuide Transom Mount Great White...
    Where can I buy a sevylor propeller for a 12v motor
    Check here, if this isn't the prop, they may have others.
    Aug 26, 2014 | Sevylor 12-volt Electric Trolling Motor
    Bearings for trolling motor shaft?
    try a dealer who sells this machine or go on line to the maker and open up the spares section.
    Jun 22, 2013 | Boating
    Need Manual fo Sevylor 12V Trolling motor
    The Sevylor electric motor does directly mount to any Sevylor and Intex boat with out the need for an additional mount.
    Sep 29, 2011 | Sevylor SBM 12Volt Fishing Motor
    Sevylor motor mount instructions
    I dont believe a motor will mount to it. Sorry!
    Sep 30, 2009 | Sevylor 48 in Inflatable River Tube
    Minnkota trolling motor prop removal
    Apr 22, 2009 | Minn Kota Endura 30 Freshwater Transom...
    Replacement of motorguide trolling motor prop
    Motor Guide hubs come in two different sizes - 3" and 3.5". The 3" size is more for older and lower thrust models. Newer units use the 3.5. The size differences are between manufacturers too. MinnKota's are a little bigger. If you order a new prop, the only issue may be the depth of the prop. I had to use a longer prop nut wrench to tighten the Hydrilla Hacker I purchased.
    Mar 26, 2009 | Boating
    Boating Logo
    1,039 people viewed this question
    Top Boating Experts
    ray gallant
    Fabrice Wolters
    Are you a Boating Expert? Answer questions, earn points and help others
