Question about Promise TECHNOLOGY VTRAK M500I RM 15 HSWAP-BAYS RAID SATA ISCSI Drive Case
Promise TECHNOLOGY VTRAK M500I lost raid config
2 Suggested Answers
SteveRand
  • 210 Answers
SOURCE: Conflict between Promise Ultra133 and SATA RAID controller
Check that your RAID controller and onboard SATA controller aren't in a compatibility mode. You can put them in this mode while you have no SATA driver installed in Windows.
This tricks Windows into seeing the SATA drives as regular IDE drives. Your BIOS then has a spasm when it see's another IDE controller there, and just uses the card instead.
Make sure the SATA drivers are installed first, otherwise anything SATA will stop showing up. (and your Windows just won't boot if it's on a SATA disk and you take compatibility mode off) =-]
Posted on Aug 20, 2008
Lost raid 0 config
RAID 0 provides no redundancy, it combines 2 volumes into one large volume with no parity.
Depending on what the problem is you may be able to recover your data . Having 2 different physical volumes might be tricky, but I have had success with EaseUS on similar problem with single disks (http://www.easeus.com/datarecoverywizard/)
I can't promise it will work, but it's worth a try.
For peace of mind, next time use an online backup service: Mozy, Carbonite, Etc.
Dec 16, 2013 | Gateway FX510XG PC Desktop
I have a hdd on promise supertrak ex4350 that has errors. There are 4 drive in raid5 config. The faulty drive is on port2. I replaced the drive but it still does not light up or show in the config. Not...
the drivers might be installed properly for this device
click start control panel administration tools computer management device manager scroll through all of your devices if you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver
if you can see your usb device but its not working sroll to Ports(Com&Ltd) right click to update driver
hope this helps you
Aug 30, 2011 | Promise SuperTrak EX4350 4-port Native...
Hi, within the previous 12hrs my e-series server bombed out - there are two issues (1) Memory DIMM malfunction (2) serveRAID-7k error 2807... I removed the faulty memory DIMMs, but the RAID error still...
You can recover RAID data from hard drive with RAID recovery software easily.
Tenorshare Data Recovery Enterprise is a comprehensive data recovery software that supports RAID recovery for RAID 0 and RAID 5. Lost data in RAID 0 and RAID 5 can be deeply scanned and restored immediately. Meanwhile, files and folders in RAID 0 and RAID 5 can be copied to other partitions directly. http://www.any-data-recovery.com/product/datarecoveryenterprise.htm
Aug 29, 2011 | IBM ServeRAID-7k Controller (71p8642) SCSI...
I need drivers for fastrak sx4100 for windows seven
There only seems to be one set of drivers available from Promise
http://www.promise.com/single_page_session/page.aspx?region=en-global&m=719&sub_m=sub_m_8&rsn=144
If this doesn't work in Win 7 try installing it in XP mode and see if that does the trick
Mar 23, 2011 | Promise FastTrak SX4100 Serial ATA RAID...
NO HARD DISK FOUND DELL POWERDGE 1600SC
Is the HD SAS/SCSI/SATA on a raid controller?
If so you need to enter the RAID config (not the bios, but there will be a RAID config option during the boot process CTRL+M I believe.. but it will say on screen.) Then you need to set up the raid config, then initialise, then the drive will be detected for loading the OS.
Either that or the drive(s) shafted.
What sort of disks are you using?
Aug 20, 2010 | Dell PowerEdge 1600SC Server
Files are disappearing and re-appearing. What is
posts disappearing and appearing on facebook home page
Feb 16, 2010 | Promise VTrak M500p Hard Drive Array
Aug 09, 2008 | Promise Ultra133 TX2 ATA Controller
K8T Neo Motherboard with Via and Promise SATA problems
http://www.versiontracker.com/dyn/moreinfo/win/140882
the above site has driver via Hyperion pro 11.5mb
http://www.soft32.com/download_170761.html
This one has promise fast trak driver
Hope this helps please post rating thanks
Aug 01, 2008 | MSI K8T Neo-FSR Motherboard
Using promise tx2 ultra133 ata/133 controller for raid (performance)
Well, first of all, the card only supports 2 drives from what I see... and secondly, the card doesn't do RAID either. This is the spec sheet that I made the determination from... http://www.promise.com/marketing/datasheet/file/Ultra133tx2DS_v3.pdf. If I'm mistaken about what the device is, please provide more information about the card that you have. If I have the correct card, then unfortunately you'll have to get another card. If you'll tell me what your technical requirements and financial restrictions are, maybe I can give you some advice on what to purchase.
Oct 26, 2007 | Promise Ultra133 TX2 ATA Controller
Computers & Internet Logo
Top Promise Computers & Internet Experts
Gareth Cockram
Gareth Cockram
C. David Graves
Are you a Promise Computer and Internet Expert? Answer questions, earn points and help others
