Question about HP Office Equipment & Supplies
My HP photosmart 7510 makes a terrible noise when I try to print or use the supposedly easy Fax
headstrong
  • 233 Answers
SOURCE: Terrible noise when printing
turn off, remove the cartridge and turn back on, do you hear the noise? if no then it's the cartridge
hope this helps
Posted on Jan 07, 2008
rsmith972278
  • 160 Answers
SOURCE: HP Officejet 6210 will print but with terrible clicking noise
Ok this Sounds Crazy but it worked for me and its easy to try. Unplug the unit and pick it up and turn it side ways and gently shake it. Sometimes a small piece of plastic has broken loose and is interfering with the works and if you can dislodge it from its current location it will stop. Be careful not to hurt youself doing it. Also, I have one printer with a missing tooth on one of the gears and has been growling at me for a long time.
Best of Luck,
RSMITH972278
Posted on Oct 12, 2009
  • 7 Answers
SOURCE: HP Laserjet 1020 makes terrible squeaking noise
This may answer you question
Posted on Feb 10, 2010
Dicedonions
  • 118 Answers
SOURCE: HP Photosmart C6280 All-in-One making weird noises
this is hope, i had this problem once. what it was was a small piece of paper that was caught in the rollers. i know you said this, but check again, I am almost positive this is your problem
lastly, check the black cartridge, take it out make sure nothing is stuck to the ink dispensary for clear printing
hope this helps and good luck
Posted on Apr 29, 2010
SOURCE: HP photosmart C3180 makes a loud clicking noise
After inserting new cartridges in the photosmart C3180 and closing the door it makes loud clicking sound coming from the cartridge area and won't print.
Posted on Feb 24, 2011
HP photosmart 7510 new ink cartridges are loaded but a notice is given that no cartridges have been installed.
*Remove Protective Tape
*Reset Ink Cartridge Counter
*Run Extended Cleaning Cycle
*Diagnose Refilled Cartridge Problems
*Update printer drivers
*Check Hp Photosmart 7510 Manual- https://guideusermanual.com/product-name-photosmart-7510-e-all-in-one-printer-series-c311-manual&po=243459&lang=English to proceed to further options if above are not useful.
Feb 10, 2017 | HP Photosmart 7510 C311A Inkjet...
How to get my printer to print color pictures
Buy color ink at the store . Then install inside your printer.
Jul 15, 2015 | HP Photosmart 7510 e-All-in-One -...
Ink cartridges just replaced and print is coming out light gray. #2 When I print e-mails or documents from e-mails--advertisements and side bars print out on my documents? Can you help me fix these...
first off the side bars printing is the direct result of the settings you are using. and must be readjusted. accordingly. The light gray print sounds like a combination of 2 separate settings, the "economode" that is set on the printer itself, and a similar setting in your print mode on the computer (never use both, only one or the other).
Mar 27, 2015 | HP Photosmart 7510 e-All-in-One -...
My HP photosmart 7510 does not recognize the presence of any color cartridges. I use only HP 564 cartridges. It prints only black. What can I do with it?
Check this link for ink cartridge problems. The part on "older generation cartridges" is very interesting. It is located on page 39 of the manual (page 40 of the pdf).
http://h10032.www1.hp.com/ctg/Manual/c03011756.pdf
Jan 06, 2015 | HP Photosmart 7510 e-All-in-One Printer
My computer will not send a signal to my printer ,there for it will not print;
Dear User,
Kindly share the following details and try some steps of troubleshooting as I suggest below,
Info :
What is the OS (Operating System, windows, Mac, Linux, etc)
What is the file type you are trying to print (word,excel,pdf, etc)
Is this HP printer assigned as a default printer (you can see it on the print preview box)
Troubleshooting :
1. Try making this printer as a default printer - Right click & make as default in the Printer and faxes option under control panel.
2. Try printing a random word document
3. Try with another machine if you have one at home
Let us know further
Regards,
Sid
Nov 13, 2014 | HP Photosmart 7510 e-All-in-One -...
HP printer cartridge installed & won't work
Make sure ink cartrige connections are claen and touching.
Jul 08, 2014 | Computers & Internet
"Printer offline"
I would go onto
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?os=4063&lc=en&cc=us&dlc=en&sw_lang=&product=5070121#N305
Go ahead and download the firmware update and follow the directions. Hope this helps. Let me know!
Jan 31, 2014 | HP Photosmart 7510 Wireless e-All-in-One...
I just purchased a new printer the HP Photosmart 7510. When I try to add the device to my laptop, it asks me for a pairing code. It states that it may be found on the bottom of the printer or in the...
Any software related issues pl tell about your operating system, then it is easy to give better solutions by our team.
Dis connect the product to your laptop, go to control panel search for the printer software, if you found un install or remove the programme. Run driver CD,select auto run, let it run connect USB cable when device searching for the product, wait till completes, follow the dialog box, complete it.. shoot test page to print..Its normal process even if you are facing any kind of problems let give some more information about OS,printer connectivity,system permission etc..
Sep 04, 2012 | HP HEW CQ877A PHOTOSMART 7510 WIRELESS...
I can no longer print from my Mac to my HP Photosmart C4280. This happened after changing the ink. The following occurred when I tried to troubleshoot: Network Diagnostics was able to connect to the...
I can no longer print from my Mac to my HP Photosmart C4280. This happened after changing the ink. My HP icons are no longer in menu bar either. When I try to print the HP makes a loud noise and shoots the paper through at rocket speed with terrible print quatlity.
Aug 30, 2009 | HP Photosmart C4280 Aio Printer
44 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
