Elo et1727l-8cwf touch screen monitor blink and turn off display
SOURCE: When it's turned on, the light on my monitor blinks but the screen doesn't display anything. Why ....
REPLACE THE 3-470UF 25V CAPACITORS WITH R-SHACK
470UF 50V CAPS WORK GREAT!!!!!!!!!!!!!!
Posted on Apr 07, 2008
SOURCE: Elo Touch Screen wont stay on!!
Hoya
I spoke with ELO techsupport and they said that I have a bad backlight inverter. I am looking for replacement parts. Have you found anything? If not, would you be interested in selling your USB controller unit from your monitor? Wake
Posted on Oct 29, 2008
SOURCE: Elo 17" LCD Touch screen ET1725L Powers off after 1 second
Your problem lies ion either your back light inverter or in the backlight tubes ( bulbs) which are embedded in the LCD display. The display has 4 ccf tubes inside of it that provide the backlighting. if any of these tubes are bad the backlight inverter will shut off after about 1 second. Because there are 4 of these tubes inside the screen you may not notice ( brightness wise) if 1 of them is out.
You can buy another backlight inverter( about $70.00 US) however, from my experience that would be a waste of money. Unfortunately, I think your problem probably lies in your LCD and the backlight tubes are not replaceable.
Hope this helps all who have this problem.
Good luck
Jim
Posted on Jun 25, 2009
  • 7 Answers
SOURCE: Elo ET1725L with no video. Flash on screen on
When LCD's "turn on" momentarily before going blank again it is an indication that the backlights have worn out. Cold Cathode Floursecent Lamps (CCFL's) have a limited amount of hours which they can be in operation for before the mercury vapor in them breaks down (or leaks out). When that happens the backlights no longer look like a load the inverter (device inside the monitor which turns low voltage into high voltage) is programmed to look for, and long story short, the inverter does not keep the lamps illuminated because of this being a safety setting, if the load no longer looks like what the inverter is looking for, it could be sustaining an open arc which then leads to extremely high temperatures, and a possible fire. The flash you see is the "firing voltage" (I think that is what it is referred to in the industry) which is a very high voltage pulse used to create the arc between cathodes in the CCFL, creating the arc takes a much higher voltage than sustaining the arc, so even if the inverter successfully creates the arc and lights the cathodes, it quickly doesn't look like a proper load and then inverter quickly turns off to prevent damage.
In essence CCFL's are usually the weakest link in LCD monitors as far as what is most prone to failure, technology has been improving, but if you keep your monitor on all day long at full brightness, never shutting it down, don't expect more than 3 years out of it :( Some brilliant LCD manufacturers recognize this problem and even make the backlights replaceable!! What a novel concept!!! But due to price gouging, the replacement backlights are usually sold for a premium from resellers, better option than the majority of LCD displays which have the backlights so integrated that you end up destroying the LCD and introducing contaminates in the process of "reviving" the display...
Your best bet if the backlights are in fact shot, is, if you are handy with a soldering iron, get the LCD apart, get out the backlights (there are probably four in there, possibly 6) measure the diameter and length, and look on eBay to see if someone is selling the particular CCFL you need-- that may be the cheapest route if you are out of warranty...
Posted on Jul 25, 2009
SOURCE: How to adjust sensitivity on ELO Touch Screen monitors
you probably have a capacitive screen, it only responds to finger press. You need a resistive screen to be able to respond to finger, nail, or pen press.
Posted on Aug 27, 2010
I use a Mac Mini with Elo 1515L at its supported resolution for Mac. In the beginning, it turns on and I can see everything on the monitor, then it goes blank and gives me an "out of range" or "no...
An Elo 1515L has a set resolution of 1024 x 768. I'm not sure if there is something special with Macs, but you can check the OSD (On Screen Display) settings.
Apr 28, 2017 | Elo 1515L (Grey) (Dark Gray) 15" LCD...
My elo toch screen does not work right. when i touch it it is on the correct side from left to right, but it is opposite on the up and down. when i touch the top right side it shows in the bottom right...
The calibration is off. Go to start and then control panel. In control panel you should find an icon for ELO calibration. Click this and start the procedure. The calibration will ask for you to touch several places on the screen in little circles with bulls eyes. After this the screen should be corrrect.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Mar 18, 2010 | Elo CarrollTouch touch-screen Monitor
ELo touch screens not responding to the touch?
is the screen worn? you might need to replace the touchscreen glass
Aug 31, 2009 | Elo 15" Touch Monitor
Hoya
Jul 08, 2008 | Elotouch 17" LCD Monitor
Install software for touch screen elo
try this link : http://www.elotouch.com/Support/Downloads/dnld.asp
Jun 09, 2008 | Elo 15" Touch Monitor
Broken Elo Monitor Screen
Touch screens are even more expensive that straight LCD panels. This repair may cost more than the original monitor. Why do you need another panel? Is the panel cracked or is the touch screen portion not working correctly?
Dan
Mar 28, 2008 | Computers & Internet
Aug 28, 2007 | Elo 15" Touch Monitor
Computers & Internet Logo
80 people viewed this question
David Payne
David Payne
