Question about Bissell 1697-7 Powersteamer Pro Deluxe Vacuum
Does not spray when filled - Bissell 1697-7 Powersteamer Pro Deluxe Vacuum
  • Official Brand Answer
  • 315 Answers
Hi Lori! Not having spray when you're ready to clean can be frustrating. I'm sorry you've experienced difficulty.
Here's a quick link to our terrific FAQ that'll help you with the spray: http://www.bissell.com/FAQDetail.aspx?id=1052&cid=ccsocial
Posted on Jul 31, 2013
Water won't spray when I squeeze the trigger. How do I get it to spray the solution?
Hello, this is Ava with Think Crucial.
There are a number of reasons why your unit doesn't spray water. It could be that the !) water tank is empty which you can fill heavy duty bladder with hot tap water. 2) If Formula tank is empty, you can fill it with Bissell 2x formula for cleaning. 3) If tank may not be seated properly, turn the power off, remove and reseat the tank. 4) If pump may have lost prime, try to turn off and then turn on the unit, wait for one minute and depress trigger. If still nothing happens, I suggest you contact Bissell 1-800-237-7691 for further assistance.
I would like to let you know that you can order replacement parts for your vacuum needs. Please visit our website
http://www.thinkcrucial.com/search?type=product&q=bissell
As a special offer here is an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
Ava B.
Think Crucial Customer Care
Jun 10, 2016 | Bissell ProHeat Turbo Deep Cleaner Upright...
How to prime pump in bissell carpet cleaner
Turn off and unplug unit. Remove both tanks. Fill Solution tank and install it. Fill Heat Tank and install it. Plug unit in and turn on, wait one minute and engage sprayer till spraying. Stop sprayer. Consumer Care # 1-800-237-7691 for further assistance.
Aug 06, 2015 | Bissell Vacuums
Bissell pro heat wont spray water
Hi, it's Allie from Crucial Vacuum!
Your Bissell ProHeat 25A3 may have stopped spraying water for several reasons. Make sure the bladder or water tank of your unit is filled with water properly and that the 2-in-1 tank has been placed properly.
If the water tank/bladder is filled and the 2-in-1 tank is placed properly, your unit's pump may have lost prime, to check this turn your unit's power off and hold spray trigger for 30 seconds. Turn the machine back on and check the spray flow.
Another thing that may not be allowing your unit to spray properly or spray at all is having a clogged solution filter and may need to be cleaned.
Last, your unit's pump belt may be broken. To replace, turn off your unit and unplug from any electrical outlet. Use a flat head screwdriver into the slot of the belt access door to release where you should have access to your unit's pump belt.
You can purchase direct your replacement belts from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/bissell-proheat-2x-belts-2pk.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Alejandra (Allie) Sepulveda-Rivera
Crucial Vacuum Customer Care
Oct 05, 2014 | Bissell Pro Heat Deep Cleaner Model 25A3,...
Hoover floormate deluxe doesn't spray water
Fill tank with water.
Ensure the spray nozzle is not clogged from previous use. Refer to the manual for maintenance of the spray nozzle. Check YouTube for videos for this model. Contact Hoover website for support.
Aug 14, 2014 | Vacuums
MY LIBMAN SPRAY MOP WON'T SPRAY AND ITS BRAND NEW. i FILLED THE CUP UP AND PRIMED THE HANDLE AND STILL NOTHING.
Did you ever get a solution? I just bought it today, and am having the same problem. I also sent an email to Libman.
Oct 11, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
I fill the reservoir before beginning ironing and after I finish ironing there is almost the same amoount of water left in the resevoir. The only time I can spray water is when I press one of the spray...
Hi nananmm,
Try flushing the iron and clearing the holes by filling the iron with a mixture of half white vinegar and half water. Set it for steam and let it sit on an old cloth for about 30 minutes.
This should flush out any buildup in the iron and holes.
Hope this helps. If it does, I'd appreciate your vote. Thanks,
Handie Andie
Jun 13, 2011 | Vacuums
My Bissell does not spray fluid. I have a new pump
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
sdgfsh
Jun 07, 2010 | Bissell 1699 ProHeat Clear View Upright...
My bissell pro heat 2X will not work, no water or solution comes out, what can I do?
I think the instructions should have the user rinse the solution passage with water. The soap probably clogged your spray nozzles. I had the same problem, I used a toothpick to poke to hole open again. The solution sprays only. I can't figure out why the water is not spraying out though.
Jan 24, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
No spray in hands-free mode.
Hi, I had the same problem ... I tried hot water for 30 minutes with no sucess ... then opened the unit and could see nothing real obvious in the solution hoses ... so took the main hose off the valve from the solution tank ... then plugged in the unit over a towel (be careful) ... and selected clean ... the valve opened and a bunch of fluid flushed through - so I knew the valve was ok. I then blew through the remaining hoses and did seem to get some flow .... and reassembeled the unit ... and filled the tank with vinegar solution ... the manual spray immediately cleared with a bunch of dark flakes ... the regular brush spray worked fine.
Sep 11, 2008 | Bissell SpotBot Robotic Wet/Dry Vacuum
Bissell 1697-7 Powersteamer Pro Deluxe Vacuum Logo
49 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
