Question about JVC KW-AVX810 Car DVD Player
Hello, I have a JVC kw avx730 and the protect mode keeps flashing. I have tried to reset it and it and after it resets it still says protect. I have tried to hold multiple buttons at the same time...not sure what will work? please help me with some options to press. thankyou
SOURCE: HELLO
I also the same JVC XVS-500 DVD that flashes "hello" and then turns off. I took it apart and cleaned it and tried the test and reset; no change.
Posted on Jun 15, 2008
Lando93
  • 8 Answers
SOURCE: JVC KD-R200 won't power up for more than 5 seconds
Check your wires they might be touching steel around your car mostly look at your yellow and red wires those are the 1' that give it power and light to your radio also check your radio fuse in the back.
Posted on Jun 10, 2009
SOURCE: JVC KD-R610 is stuck in Protect mode
Try disconnecting your battery, reconnecting it, and resetting your stereo. If that doesn't work, the constant power (yellow wire) or ignition wire (red wire) may have come in contact with ground or isn't properly connected. Make sure everything is connected properly and try resetting your stereo. If it is still flashing "protect", the unit needs servicing Contact JVC Customer Care Center at: 800-252-5722.
Posted on Feb 07, 2011
kenw392
  • 2226 Answers
SOURCE: jvc kd- r311 lights up
Check your speakers and speaker wires to make sure there are no shorts or grounds. If the speakers and speaker wires check out, you probably have a bad internal output ic.
Posted on May 10, 2011
nicole_richi
  • 5 Answers
SOURCE: need a replacement faceplate for a JVC KW-AVX730
have you tried to contact jvc and get it fixeed under warrenty?
Posted on Jul 17, 2012
Get kw-nt500hdt out of demo mode
Hello Connie, Thank you for your question.
The JVC unit you have installed can detect when the car is in motion. If you are stuck in the DEMO mode start the vehicle and drive a short distance, once the system detects motion it should remove itself from the DEMO mode. I hope this helps =)
Nov 07, 2013 | JVC KW-NT500HDT In-Dash Car GPS Navigation
Buttons not working on JVC KW-AVX730
There must be some short circuit between the buttons. How much old it is?
Chevrolet Performance Chips
Aug 12, 2012 | JVC KW-AVX730 Car Video Player
Need a replacement faceplate for a JVC KW-AVX730
You can find replacement faceplate on amazon, take a look here: Amazon com JVC KW. Wish you best of luck. Joseph
Jul 17, 2012 | JVC KW-AVX730 In-Dash Double DIN 7"...
Reasons for black screen on jvc avx730 and how to fix it
sudos dispongo jvc kw-avx820 funciona la radio pero la pantalla no se prende gracias
Mar 09, 2011 | JVC KW AVX820 Car Video Player
My jvc deck says PROTECT on it and won't let me listen to music or anything! What should I do?
my jvc kd-s37 keep going into protect mode now how can i get it where it stays out i reset it several time but it still goes back into it
Nov 25, 2010 | JVC AM FM CD DET FACE CAR STEREO
Jvc kw-avx810
i think u need to reset the unit.
try another new RCA lead from some gud brand lyk rockford or jbl
Aug 01, 2010 | JVC KW-AVX810 Car DVD Player
Jul 22, 2010 | JVC AM FM CD DET FACE CAR STEREO
TV turned off itself and timer light (red) keeps blinking
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Feb 15, 2009 | JVC AV-35750 35" TV
HELLO
i had the exact same problem yesterday (4/8) and just playing with the open/close button several times the drawer finally opened completely and closed like it should. i then did the reset sequence and all is back to normal
Apr 03, 2007 | JVC XV-S500 DVD Player
JVC KW-AVX810 Car DVD Player Logo
26 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
