Question about b2Pad FArdermittel
It comes up 2 the keyboard screen. and locks up
How to unlock the lock screen on my HP
To unlock the lock screen on your HP desktop running Windows 8.1, you can follow the steps below:
1. Swipe in from the bottom edge of the screen to dismiss the lock screen. Alternatively, you can also press any key on your keyboard to dismiss the screen.
2. In the sign-in screen that comes up, you can sign-in to your computer using the method of your choice.
To know more about this, you can refer to the link below:
http://windows.microsoft.com/en-IN/windows-8/lock-unlock-pc
GuruAid.com
Oct 18, 2014 | Computers & Internet
My lock button as well as my sound buttons won't work
It sounds like you may have accidentally turned them off. To make sure the sounds are on, do the following:
1. Click on "Settings"
2. Select "Sounds"
3. At the bottom you will see "Lock Sounds" and "Keyboard Clicks".
If the sounds are on, I would then recommend preforming what's called a "Soft Reset". To preform this, do the following:
1.Press down the "Home" button and the "Lock" button at the same time.
2.Hold these buttons until you see the apple logo appear.
3.The iPhone may take up to 2 minutes to come back to your "Lock Screen"
This should fix your problem.
Oct 06, 2009 | Apple iPhone Smartphone
I have a hp pavilion dv5020 laptop. All of a sudden when I type j it types 1, k it types 2 etc. The scroll and num lock light is on and when I push it the scroll lock comes on or goes off. How do I turn...
Press the blue key marked Fn (should be bottom left, I believe) and hold it down. Then press the key that has blue writing that says 'NumLk' (or something similar to that). Should turn it off.
Sep 02, 2009 | HP Pavilion dv5020us Notebook
The arrows arent working, scroll lock must be on and I cant figure out how to undo. there is no scroll lock button
GOOD NEWS!
There is a scroll lock button on your computer and this is how you get to it.
Step 1
Click the Windows Start button which is located in the lower left corner of your screen.
Step 2
Click on All Programs. You will see a list of all the programs installed on your computer.
Step 3
Select Accessories from the list of available Programs. It is usually in the upper left on the list of available programs as the list is alphabetized.
Step 4
Select Accessibility, which is a sub-program of Accessories.
Step 5
Select the On-Screen Keyboard.
Step 6
Select the Scroll-Lock by clicking on the on-screen 'key' labelled 'slk' located upper right on the on-screen keyboard between the 'psc' and the 'brk' keys.
This should get that pesky scroll lock off right away!
Sincerely, CBR2009
Jul 16, 2009 | Logitech 967461-0403-PK Keyboard/Mouse
No keyboard instructions
You need to press the Function button, then the num lock button. The function button may be labeled FN or F in a different color, the same color as the num lock button.
If that doesn't work, go to start, all programs, accessories, accesibility, on screen keyboard....it will display a regular keyboard on your screen, then click on the num lock key on that keyboard.
May 24, 2009 | Compaq TC1100 (/) PENTIUM M 753 1.2GHZ...
My keyboard is not working!!?? :(
yikes it seems as if the keyboard themselves are damaged and need of replacement though you maybe able to use a USB plugged keyboard (or PS/2 keyboard if supported) but it does seem those keyboards are ruined
Mar 14, 2017 | Gateway 2520915 Keyboard
Keyboard Sequence for Compaq 4-Port KVM Switch (Series 4115)
Mine uses the "Print Screen" for the menu & "Print Screen" + 1, 2, 3, or 4 for direct access.
Feb 13, 2009 | Compaq (147092-001) 4-port KVM Switch
How to remove the keyboard to access the RAM memory slot
If you examine the area of the case above the keyboard (the small area between the keyboard and the screen hinges), you should see that it is a separate piece from the rest of the case. This small section of case should just pry off (be careful not to break it or the locking tabs). Once you have pried this off, you should see 2 or 3 screws holding the keyboard down. Remove these screws and the keyboard should come out. If you are just accessing the RAM, you shouldn't have to unplug the keyboard ribbon cable.
Sep 04, 2008 | ASUS M3000Np Notebook
Cannot unlock Keyboard Scroll lock - EX110
Found this little bomb shell after about 30mins of looking for an answer.
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=9220
To toggle your scroll lock key:
  1. Click on the Windows Start button.
  2. Select Run.
  3. Type 'OSK' in the dialog box.
  4. Click on OK.
  5. The Microsoft on-screen keyboard will open. Notice that the slk, or scroll lock, key (located in the top row of the on-screen keyboard as shown below) is turned on.
  6. Click on slk (in the top row of the on-screen keyboard). This will toggle the state of the scroll lock key. Notice that the scroll lock key is no longer outlined in red. Scroll lock is now off.
NOTE: If you have installed SetPoint (Logitech’s Mouse and Keyboard software) the confirmation message Scroll Lock Off will also be displayed for about 2 seconds on your monitor.
Yipee!!!
Aug 21, 2008 | Logitech Cordless Desktop EX110
"Reprogrammed" keyboard
Normal 0 Go to Control Panel.
1. Click on Keyboard.
2. When the Keyboard Properties come up, CLICK on Key Settings.
3. Then set up the Cap Lock key.
Hope this will help some. Bud
Feb 06, 2007 | Mitsumi (KFK-EA4XT/PS2) Keyboard
b2Pad FArdermittel Logo
Top b2Pad Apps Experts
Brett Duxbury
Brett Duxbury
Are you a b2Pad App Expert? Answer questions, earn points and help others
